maik005
Legende
- 39.550
@weihberg
ganz sicher keine Fehlermeldung beim S8+?
Vorwort beachtet? OEM Unlock aktiviert?
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
Installation
Make sure first that "OEM unlock" is enabled in your developer settings (if you don't understand what this means then probably this ROM is not for you).
Make sure to flash the Oreo bootloader (see post #2) if you come from Nougat.
- click WIPE and then FORMAT DATA (do this ONCE when you come from Nougat) => then reboot into TWRP
- Wipe /system, /data and /cache (for a normal clean install)
- put the googlewiz_oreo_vXX.zip onto your /sdcard
- wipe data, system, dalvik, cache
- flash bootloader (if you come from Nougat)
- flash ROM
- reboot
