bierma32
Enthusiast
- 1.074
Wichtiger Post von gr8nole zu den Problemen Customrecoverys,Bootloop, Bootloader und Ladefuntion.
Link nach xda.Information about T210(R) Custom Recovery, B… | Galaxy Tab 3 | XDA Forums
CUSTOM RECOVERIES
There appears to be two types of bootloaders that are currently in use. One that plays nicely with custom recoveries (such as CWM, Philz, and TWRP) and a newer one that doesn't. Even if you haven't flashed a new bootloader, your device may have been manufactured with it. If you flash the KitKat firmware package, you will definitely have the new bootloader. Flashing a rom (such as NoleKat) does not give you a different bootloader.
The newer bootloader will cause you to be stuck in a recovery bootloop if you use any recovery boot method other than the 3-button method. This appears to be caused by the bootloader expecting the recovery to perform a checksum that the custom recoveries do not perform. The checksum action looks to be coded into the stock recovery init binary (which we can not use).
For some reason, this only happens if you use a "software" method to boot into recovery such as the following methods:
Any app that reboots in to recovery
ADB Reboot Recovery
The "Reboot Recovery" option in your custom recovery
Embedded Reboot to Recovery options in the rom
If you get stuck in a recovery bootloop, you need to flash the stock recovery to be able to boot the OS. You can do that by using Odin or by finding a flashable zip containing your stock recovery.
Once you get your OS to boot, you can re-install your custom recovery. Remember, only use the 3-button method to boot into recovery.
There is currently no way of returning to the old bootloader that I am comfortable with trying. It may be possible by someone creating a backup of the old PBL, SBL, and SBL2 partitions, but I do not recommend messing with your bootloader.
CHARGING WITH THE TABLET OFF
Since the KitKat roms and kernels have been release, there has been an issue with charging while the tablet is powered off. If you still have the old bootloader, the tablet will power on and boot into the OS when plugged in to charge.
If you have the new bootloader, the tablet will charge as it previously did on 4.1.2. You will see the charging icon on the screen, but the tablet does not boot into the OS.
Der ursprüngliche Beitrag von 20:44 Uhr wurde um 20:55 Uhr ergänzt:
Frei Übersetzt.
Es sieht so aus das wir 2 verschiedene Bootloader nutzen Einer der sauber mit den Custumrecoverys CWM / PhilzTouch und TWRP harmoniert, und der neuere nicht.
Habt ihr keinen neueren geflasht , war er direkt vom Werk geflasht.Flasht ihr die neue KitKat Stock Rom bekommt ihr den neueren Bootloader.Flasht ihr ein Custumrom wie
Nolekat wird der bestehende, alte nicht geändert.
Mit dem neuen Bootloader bekommt ihr einen Bootloop wenn ihr eine andere als die 3 Tasten Kombination nutzt um in das Recovery zu booten.Mit dem neuen Bootloader wird eine Checksumen Überprüfung durch geführt die als Resultat den Bootloop zur Folge hat
Folgende Methoden führen zum Bootloop.
Alle Apps mit Funktion Boot to Recovery
ADB Boot to recovery
Rebootrecovery Funktion in eurem Customrom
Andere Rebootfunktionen im Custumrom zum Recovery.
Für den Fall das ihr in einen Bootloop gelangt, besteht die Möglichkeit durch flashen des Stockrecoverys mit Odin oder wenn eine flashbare Version vorhanden ist dieses mit dem Recovery zutun.
Nach dem OS wieder gestartet ist könnt ihr euer bevorzugtes Custumrecovery wieder flashen.
Wichtig: nun sollten ihr nur noch mit der 3 Tastenkombi ins Recovery booten.
Im Augenblick gibt es kein weg zurück wenn der neue Bootloader installiert ist,ausser es findet sich ein erfahrener User der ein Backup von old Pbl, Sbl und Sbl2 Partionen. erstellt.
Laden des Tab im ausgeschalteten Zustand
Seit die KitKat Rom und der neue Kernel erschienen sind haben wir das Problem das bei ausgeschaltetem Tab dieses startet. Das ist ein Merkmal das das Tab noch den alten Bootloader hat.
Seht ihr das Ladesymbol hat euer Tab den neuen Bootloader.
CUSTOM RECOVERIES
ADB Reboot Recovery
Frei Übersetzt.
