hallo, der dual-sim modus ist das problem ,habe mal ein wenig weiter gegoogelt das u8600 soll angeblich mit der s8600 rom starten jedoch wird die simkarte nicht erkannt . hier mal die build.prop einer mod s8600 rom:
ro.build.date=Sun Jan 15 17:20:11 CST 2012
ro.build.date.utc=1326619211
# begin of volatile config
# end of volatile config
#ro.build.date=Fri Jun 10 09:12:17 CST 2011
#ro.build.date.utc=1307668337
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=HuaweiS8600
#ro.build.display.id=msm7627_surf-eng 2.3.4 GINGERBREAD eng.hanping.20110610.090709 test-keys
#ro.build.version.incremental=eng.hanping.20110610.090709
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.4
ro.build.type=user
ro.build.user=hanping
ro.build.host=huawei-desktop
#ro.build.tags=test-keys
ro.product.model=S8600
ro.product.brand=Huawei
ro.product.name=S8600
ro.product.device=hws8600
ro.product.board=S8600
ro.product.cpu.abi=armeabi
ro.product.manufacturer=HUAWEI
ro.product.locale.language=zh
ro.product.locale.region=CN
#DTS2011081704728 tongxiaolu 20110822 begin
ro.product.locale.min_freq=7600
#DTS2011081704728 tongxiaolu 20110822 end
ro.wifi.channels=
ro.board.platform=msm7k
# ro.build.product is obsolete; use ro.product.device
ro.build.product=msm7627_surf
# Do not try to parse ro.build.description or .fingerprint
#ro.build.description=msm7627_surf-eng 2.3.4 GINGERBREAD eng.hanping.20110610.090709 test-keys
#ro.build.fingerprint=qcom/msm7627_surf/msm7627_surf:2.3.4/GINGERBREAD/eng.hanping.20110610.090709:eng/test-keys
# end build properties
# DTS2011051102205 zhangqijia 20110511 begin
# <TS2011022502432 m00170653 20110225 Begin
ro.nfc.port=I2C
ro.config.KeyPassToUser=true
# TS2011022502432 m00170653 20110225 End>
# DTS2011051102205 zhangqijia 20110511 end
# Begin
TS2010071300747 add Qualifier opt added by h00152727 20100713
ro.config.hw_opta=92
ro.config.hw_optb=156
# End
# DTS2011072700069 g00183846 for removing quick power on begin
# DTS2011012104419 s62695 for quick power on begin
ro.config.hw_quickpoweron=false
# DTS2011072700069 g00183846 for removing quick power on end
persist.sys.quickpoweron=normal
persist.sys.animationstart=false
ro.config.hw_poanimation=5000
# DTS2011012104419 s62695 for quick power on end
# <DTS2010111202622 x00174118 20110705 begin
ro.config.hw_proximity=true
# DTS2010111202622 x00174118 20110705 end>
# <DTS2011021202969 m00170653 20110212 Begin
persist.sys.powerup_reason=
persist.sys.user_set_airplane=
ro.poweroff_alarm=true
# DTS2011021202969 m00170653 20110212 End>
#DTS2011050304028 l00176215 20110506 Begin
persist.sys.actualpoweron=true
#DTS2011050304028 l00176215 20110506 End
#DTS2011072702639 x00186492 20110727 Begin
ro.config.hw_new_double_signal=1
#DTS2011072702639 x00186492 20110727 End
# system.prop for surf
rild.libpath=/system/lib/libril-qc-1.so
rild.libargs=-d /dev/smd0
# /*<DTS2010100802374 yangqinghua & wuwei 20101009 Begin*/
net.ntp.server=time.windows.com
net.ntp.server2=time.nist.gov
net.ntp.time=0
net.ntp.timereference=0
# /*<DTS2011101105602 l00190885 20111013 Begin*/
ro.config.hwdrm=false
# /*DTS2011101105602 l00190885 20111013 End>*/
#DTS2011021202775 gaoyun 20110214 begin
ro.config.hwdrm.set_contact=false
#DTS2011021202775 gaoyun 20110214 end
#DTS2011071306053 hejiabin 20110715 begin
hw_internal_sd=true
#DTS2011071306053 hejiabin 20110715 end
# /*DTS2010100802374 yangqinghua & wuwei 20101009 End>*/
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
ril.subscription.types=NV,RUIM
DEVICE_PROVISIONED=1
debug.sf.hw=1
debug.composition.type=mdp
# DTS2011060900877 h62583 begin
dalvik.vm.heapsize=35m
# DTS2011060900877 h62583 end
# system props for the cne module
persist.cne.UseCne=vendor
persist.cne.bat.range.low.med=30
persist.cne.bat.range.med.high=60
persist.cne.loc.policy.op=/system/etc/OperatorPolicy.xml
persist.cne.loc.policy.user=/system/etc/UserPolicy.xml
persist.cne.bwbased.rat.sel=false
persist.cne.snsr.based.rat.mgt=false
persist.cne.bat.based.rat.mgt=false
persist.cne.rat.acq.time.out=30000
persist.cne.rat.acq.retry.tout=0
persist.cne.fmc.mode=false
persist.cne.fmc.init.time.out=30
persist.cne.fmc.comm.time.out=130
persist.cne.fmc.retry=false
# DTS2011061406386 l40894 set S8600 DualSim by default begin
persist.dsds.enabled=true
# DTS2011061406386 l40894 set S8600 DualSim by default end
# system props for the MM modules
media.stagefright.enable-player=true
media.stagefright.enable-meta=false
media.stagefright.enable-scan=false
media.stagefright.enable-http=true
# system prop for opengles version
ro.opengles.version=131072
# system props for the data modules
ro.use_data_netmgrd=true
persist.data.ds_fmc_app.mode=0
# system props for IMS module
persist.ims.regmanager.mode=0
# system prop for Bluetooth Auto connect for remote initated connections
ro.bluetooth.remote.autoconnect=true
# System prop to enable/disable OMH. Enabled by default
#DTS2011061607225 j00108794 for 20110617 begin
#close omh feature in ap
persist.omh.enabled=0
#DTS2011061607225 j00108794 for 20110617 end
# system prop for Bluetooth FTP profile
ro.qualcomm.bluetooth.ftp=true
# system prop for Bluetooth Dialup Networking
ro.qualcomm.bluetooth.dun=true
# system prop for requesting Master role in incoming Bluetooth connection.
ro.bluetooth.request.master=true
# system property for Bluetooth discoverability time out in seconds
# 0: Always discoverable
debug.bt.discoverable_time=0
# < DTS2011050604848 x00174118 20110509 begin
ro.config.fm_type=libbcmfm_if
# DTS2011050604848 x00174118 20110509 end >
# DTS2011071101476 y00173857 20110711 start
# ro.config.hw_RemindWifiToPdp=true
# DTS2011071101476 y00173857 20110711 end
#DTS2010081400204 by h00152727&x00165767 20100814 begin
ro.config.hw_addsettingsdbex=1
#DTS2010081400204 by h00152727&x00165767 20100814 end
# DTS2011052402955 s00181365 20110715 begin
ro.config.hwft_MatchNum=11
ro.config.hwft_MatchNumShort=11
# DTS2011052402955 s00181365 20110715 end
# ADDITIONAL_BUILD_PROPERTIES
ro.config.notification_sound=Welcoming.ogg
ro.config.alarm_alert=Pmukkale.ogg
ro.config.ringtone=Simple_World.ogg
#ro.kernel.android.checkjni=1
ro.setupwizard.mode=OPTIONAL
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
# allow to tear down mobile data connection when device is idle
ro.config.hw_power_saving=true
# DTS2010092701023 mengxiaokun00172620 20100930 end
# DTS2011030204519 s00159653 20110310 Begin
ro.config.hw_menu_unlockscreen=false
# DTS2011030204519 s00159653 20110310 End
# DTS2010090602461 kange159607 20100906 begin
# DTS2010090602461 kange159607 20100906 end
# <DTS2011012801697 by xiongshiyi 20110125 BEGIN
ro.config.hw_virtualsdcard=true
# DTS2011012801697 by xiongshiyi 20110125 END>
# add the density begin by yezongbo 20110603 BEGIN
ro.sf.lcd_density=240
# add the density by yezongbo 20110603 END
# add keyguard by yezongbo 20110609 BEGIN
keyguard.no_require_sim=true
# yezongbo 20110609 end
# DTS2011060101232 dingxudong 183776 20110601, sync DTS2010122802640 begin
# true : enable device to unlock when PUK lock
ro.config.hwft_PinPukUnlockscr=true
# DTS2011060101232 dingxudong 183776 20110601, sync DTS2010122802640 end
# DTS2010101000085 xubaoshun 20101008 begin
ro.config.smsCoding_National=3
# DTS2010101000085 xubaoshun 20101008 end
# <DTS2011012701994 mengxiaokun00172620 20110127 begin
ro.config.hw_ascend_ringtone=true
# DTS2011012701994 mengxiaokun00172620 20110127 end>
# DTS2011012602222 linqing 20110126 begin
ro.config.hw_voicerecord=true
# DTS2011012602222 linqing 20110126 end
# DTS2011031401875 jiayanhong176905 20110314 begin
# default value for time of uncompleted SMS segment expired(ms), default 2 days
hw.sms.dellong.interval.time=172800000
# DTS2011031401875 jiayanhong176905 20110314 end
# DTS2010112201516 kange&huangkai 20101122 add for reject incoming call by message, begin
#begin DTS2010112000134 z00159681 20101105 add for ipcall
ro.config.hw_support_ipcall=true
#end DTS2010112000134 z00159681 20101105 add for ipcall
ro.config.ipcall=true
ro.config.hw_reject_message = true
# DTS2010112201516 kange&huangkai 20101122 add for reject incoming call by message, end
# /*<DTS2011012502617 yangqinghua 20110125 Begin */
#ro.config.srs.equalizer=true
#ro.config.srs.default.type=1
# /*DTS2011012502617 yangqinghua 20110125 End>*/
# DTS2011011203063 zkf28680 20100112 begin
ro.config.hw_proximitySensor=true
# DTS2011011203063 zkf28680 20100112 end
# DTS2011061505385 jiayinyuan 20110615 Begin
ro.cdma.home.operator.numeric=46003
# DTS2011061505385 jiayinyuan 20110615 End
# DTS2011071204084 z00118431 20110712 begin
ro.config.hw_lockscreen=true
# DTS2011071204084 z00118431 20110712 end
# <DTS2011012706064 wangzhenKF40344 20110128 begin
# <DTS2011032502728 mengxiaokun00172620 20110325 begin
# <DTS2011040701444 zhoujieKF43510 20110407 begin
ro.config.hw_toolbox=true
# DTS2011040701444 zhoujieKF43510 20110407 end>
# DTS2011032502728 mengxiaokun00172620 20110325 end>
# DTS2011012706064 wangzhenKF40344 20110128 end>
#DTS2010091300236 wKF31275 20100914 begin
ro.telephony.call_ring.multiple=false
#DTS2010091300236 wKF31275 20100914 end
# DTS2010072001659 kange159607 20100720 begin
# allow device to sent and receive MMS even data service is disabled while this variable is true
ro.config.hw_always_allow_mms=true
# DTS2010072001659 kange159607 20100720 end
#DTS2011061700372 h00136365 20100617 DualSim Call support begin
ro.config.hw_cdmagsm=true
#DTS2011061700372 h00136365 20100617 DualSim Call support end
# DTS2011030904510 zhangli 20110309 Frog for Gingerbread begin
ro.config.PopupTwink=true
ro.config.SetStatusbarText=true
# Whether use the way of resource customize
ro.config.hw_isCustomize=true
# The Customize Type we need,01:C8600-FROG,02-TMO
ro.config.hw_customizeType=01
# DTS2011030904510 zhangli 20110309 Frog for Gingerbread end
#<DTS2010092801811 GPSXtra y142196&q170606 20100928 begin
ro.config.xtra_support=true
# DTS2010092801811 GPSXtra y142196&q170606 20100928 end>
# DTS2011021604835 20110216 houyuchun begin
# DTS2011072102053 20110721 s00132155 begin
# DTS2011080200076 20110808 huguangyong begin
# DTS2011080905324 20110809 sujionjin begin
# DTS2011090604103 20110906 s00132155 beign
# DTS2011110405860 20111104 zhuweichen begin
ro.config.browser_useragent1=Mozilla/5.0 (Linux; U; Android 2.3.4; zh-cn; HW-HUAWEI_S8600/S8600V100R001C92B119; 480*800;
ro.config.browser_useragent2=CTC/2.0) AppleWebKit/533.1 Mobile Safari/533.1
# DTS2011110405860 20111104 zhuweichen end
# DTS2011090604103 20110906 s00132155 end
# DTS2011080905324 20110809 sujionjin end
# DTS2011080200076 20110808 huguangyong end
# DTS2011072102053 20110721 s00132155 end
# DTS2011021604835 20110216 houyuchun end
#DTS2011040704378 f00184878 20110714 begin
ro.config.hw_reject_message=true
#DTS2011040704378 f00184878 20110714 end
# DTS2011071203261 20110713 z00173123 begin
ro.dev.dmm.dpd.start_address=1
# DTS2011071203261 20110713 z00173123 end
# DTS2011041406206 mabing 20110416 BEGIN
# DTS2011101906121 x00186492 20111019 begin
ro.config.hw_hide_googleSearch=false
# DTS2011101906121 x00186492 20111019 end
# DTS2011041406206 mabing 20110416 END
# DTS2011072501609 20110726 z00173123 begin
ro.config.do_sdcard_upgrade=true
# DTS2011072501609 20110726 z00173123 end
# DTS2011082502505 s00132155 20110825 begin
#DTS2011073001925 s00132155 20110804 begin
ro.config.hw_browser_ua3g=http://nmsc.ctvap.cn/uaprof/HW/HW_HUAWEI_S8600_1_20110825.xml
ro.config.hw_browser_ua2g=http://nmsc.ctvap.cn/uaprof/HW/HW_HUAWEI_S8600_1_20110825.xml
ro.config.hw_use_browser_ua=true
#DTS2011073001925 s00132155 20110804 end
# DTS2011082502505 s00132155 20110825 end
#DTS2011080900527 dingji 20110810 C+W begin
#DTS2011012205342 wangtao 20110122 C+W begin
#DTS2010080501382 lijiangang 20100805 C+W begin
ro.config.hw_CplusW=true
#DTS2010080501382 lijiangang 20100805 C+W end
#DTS2011012205342 wangtao 20110122 C+W end
#DTS2011022802735 bihan 20110228 begin
ro.config.hw_cust_ap=telecom
#DTS2011022802735 bihan 20110228 end
#DTS2011080900527 dingji 20110810 C+W end
#To support the SINA SNS account shortcut on the launcher.
ro.config.hw_sns_acc_shortcut=0
ro.config.hw_sns_acc_support=32
# DTS2011081300257 20110813 l00190676 BEGIN
ro.config.oobe_set_account=Email
# DTS2011081300257 20110813 l00190676 END
# DTS2011091406842_w00174855_20110915 BEGIN
# DTS2011082605851_w00174855_20110827 BEGIN
# DTS2011090101773_w00174855_20110827 BEGIN
ro.config.pre_apn_unable=false
# DTS2011090101773_w00174855_20110827 END
# DTS2011082605851_w00174855_20110827 END
# DTS2011091406842_w00174855_20110915 END
ro.com.google.clientidbase=android-huawei
ro.com.google.clientidbase.yt=android-huawei
ro.com.google.clientidbase.am=android-huawei
ro.com.google.clientidbase.gmm=android-huawei
ro.com.google.clientidbase.ms=android-huawei
# DTS2011090904178 g00183846 20110913 begin
ro.config.hw_GSensorOptimize=true
# DTS2011090904178 g00183846 20110913 end
#DTS2011051804785 daizhipeng 20110518 begin
ro.config.delRawSmsOnReboot=true
#DTS2011051804785 daizhipeng 20110518 end
#DTS2011120701161 p00181310 20111207 begin
persist.data_netmgrd_mtu = 1500
#DTS2011120701161 p00181310 20111207 end
ro.build.version.incremental=20120115
ro.build.tags=ota-rel-keys,release-keys
ro.build.description=S8600-user 2.3-update4 ERE27 20120115 ota-rel-keys,release-keys
ro.build.fingerprint=Huawei/S8600/hws8600:2.3.4/HuaweiS8600/C92B131:user/ota-rel-keys,release-keys
ro.build.display.id=S8600V100R001C92B131
ro.modversion=Anzhi-Lesong-S8600
ro.confg.hw_appsbootversion=S8600V100R001C92B131_APPSBOOT
ro.confg.hw_appversion=S8600V100R001C92B131_KERNEL
ro.confg.hw_appfsversion=S8600V100R001C92B131_SYSIMG
ro.anzhi.rom.pk=2012_04_060
