Ein neuer Tipp von psyke83 bzgl CM7 (vom 14.08.2012)
Android-Freak2012
Android-Freak2012
Zitat von psyke83:
I'll be catching up on the latest replies soon, but in the meantime, I have a suggestion for you to try with the latest build.
Delete this file: /system/etc/sysctl.conf
You can do it via Root Explorer, or via the terminal:
Code:
su
mount -o remount,rw /system
rm /system/etc/sysctl.conf
Changes will take effect after rebooting. Please let me know if you see any performance or stability improvements.
Erfahrungsberichte von xda-Nutzer:
- So far no lags while typing sms, no lags at all. I believe that loading apps from sdcard after startup is faster too (phone does not freeze for minute or two after launcher is started after boot)
- Sysctl hack does seem to make phone much snappier (merely subjective pov)
- I think the launcher startup on boot is faster than usual, but I'm not. too sure ...
- I can say that the loading of ADW Launcher after SIM unlock is a ton faster, scrolling seems faster too (both web and app drawer/homescreens.)
- after deleting systctl and rebooting almost everything runs fine or maybe faster.
Ich habe es auf meinen beiden 858ern getestet und habe auch das Gefühl, dass der Boot-Vorgang an sich und der jeweils verwendete Launcher schneller/flüssiger läuft...
Claus3006
Claus3006
derBasty
  • eisbaer73
Android-Freak2012
Android-Freak2012
