[ROM] Novo7 Aurora - Android 4.0.1 Essential Clean ROM v0.1
gromicx
gromicx
Ich hab mal bei der Konkurenz geräubert und die Files bei anderen Hostern hochgeladen. Falls ich etwas falsch verlinkt habe oder bei anderen Fehlern, bitte melden!
Ich habe die Files und die Tutorials nur kopiert und noch nicht getestet, da ich noch auf mein Aurora warte.
Benutzung auf eigene Gefahr!
Hello SLD Users.
my personal customized rom released.
does not touch the kernel, performance is the same. but optimize apps and add gapps.
and some changes. please visit more details to list.
Base ROM:
Android 4.0.1 - Stock Firmware​
Feature List (Android 4.0.1 Rom)
Remove Chinese Application
Remove Games (AngryBirds,FruitNinja,TheLastDefender)
Remove Application (ES Files,Task)
Goolge Apps
Market (Full Market Access)
Gmail
Calendar (Sync Working)
YouTube
Superuser
Wi-Fi Location Support
VoiceSearch
build.prop Tweak
and some change...
Issues:
same issues official rom.​
Installation:
You can install using the Live Suit.​
Support Device:
Ainol Novo 7 Aurora (Tested)​
special thanks
Roman2025
ainolmodder
FezzFest
and all developers​
sorry my poor english. have fun
Quelle: Android Tablet Forum : Forums covering all Android Tablets User: android-kun
Download Android 4.0.1 Novo 7 Essential Clean ROM v0.1 for Aurora:
Rapidshare
Download LiveSuit v1.07:
Rapidshare
Mediafire
Download USB-Driver for Novo7 Aurora:
Rapidshare
Mediafire
Installation:
1. Check the current baseband/firmware installed. Go to Menu > Settings > About Device.
Turn-On Tablet, go to Settings > Applications > Development. = For Gingerbread​
Turn-On Tablet, go to System Settings > Developers Option. = For Ice Cream Sandwich​
Turn-ON USB Debugging & Stay Awake.​
2. Connect the Tablet to PC and double-click "dpinst.exe" to install the required USB Driver for your OS.
3. After installation, disconnect your Tablet to PC and Turn it OFF.
4. Extract the Livesuit Pack into a folder on your PC. Place the Firmware .img file inside the Livesuit Pack folder and double-click Livesuit.exe:
1st pop-up window click YES.
2nd pop-up window click FORMAT.
3rd pop-up window click NEXT.
4th pop-up window click YES.
5th pop-up window locate your selected FW image file and click OPEN.
6th pop-up window click FINISH.​
5. On your Tablet, press and hold the Back Button and connect the Tablet to PC.
6. As soon as you connect the USB Cable to PC, rapidly press the Power button 5 times without releasing the Back button.
7th pop-up window click: (YES = Upgrade/Downgrade) (NO = Re-Flash to same Firmware)
8th pop-up window click: (YES = Upgrade/Downgrade)​
7. You can now release the Menu button and wait for the upgrading to get finished.
9th pop-up window click FINISH or OK.​
Gingerbread 2.3.4 After Finishing Firmware Upgrading:
1. Disconnect the tablet to PC and Power-ON your Tablet.
2. Go to Settings scroll down upto bottom and locate the [A] icon to change the Language.
3. Touch the very 1st option and choose English (US).
4. Go to Settings > Wireless and Networks > Wi-Fi Settings and Press Menu.
5. Click Advanced > Wi-Fi Sleep Policy and set it to NEVER.
6. Go to Settings > Applications > Development and turn-ON Stay Awake.
7. Go to Settings > Display > Screen Timeout and set it to 2mins above.
8. Go To Settings > Sound and disable Haptic Feedback (Vibrate).
9. Reboot your Tablet.​
IceCreamSandwich 4.0.3 After Finishing Firmware Upgrading:
2. Go to System Settings scroll down upto bottom and locate the [A] icon to change the Language.
4. Go to System Settings > Developers Option > Turn-ON USB Debugging & Stay Awake.
5. Go to System Settings > Display >Sleep and set it to 2mins above.
6. Go To Settings > Sound and set Vibrate to Never and Disable Vibrate on Touch.
7. Reboot your Tablet.​
IF Firmware Upgrading Fails, just press Power button + RECV button (using plastic stick on tiny hole) for 10seconds and do the Firmware Upgrading
again.
danke dir darauf habe ich schon gewartet, ich habe gar nicht mitbekommen wann "android kun" den 4.0.3 build fertig gebraucht hat.
cheers auf Android Kun und natürlich auch auf dich.
ich werde nun gleich beginnen zu testen !!!
orginal thread: [ROM] Novo 7 Essential Clean ROM v0.1 for Aurora - SlateDroid.com
auebanane
gromicx
sinus61
sinus61
LouCipher
LouCipher
LouCipher
