wasabi8912
not work:
3G, bluetooth, camera, hardware accelerated video, GPS, HDMI, and many things which you expect to work
work:
accelerometer, audio, gapps, internal NAND flash, SD card, touchscreen with calibration app, USB host/device, wlan
How to install ClockworkMod Recovery 5
how to operate: MENU/VOL- = next(down), SEARCH/VOL+ prev(up), HOME/POWER = select, BACK = back
*1 if recovery is 3e, you can put it with any name on any directory in SD card
*2 some tablets/roms mount internal storage as /sdcard. confirm update.zip exists on root of SD card.
*3 some tablets/roms have system update function in Settings to install update.zip
How to install CyanogenMod 7
*5 only if you are using resistive touchscreen or misaligned capacitive touchscreen. if calibration is not needed, press BACK to cancel calibration.
http://forum.xda-developers.com/showthread.php?t=1101094
work:
- make backup of stock recovery
- download recovery.zip and put it as update.zip on root of SD card (e.g. /sdcard/update.zip) *1 *2
- install update.zip from stock recovery *3
- install ClockworkMod Recovery 5
- reboot recovery
- make backup of stock ROM
- wipe data/factory reset *4
- install cyanogen.zip
- reboot
- touchscreen calibration *4 *5
