1. joker.20, 15.09.2011 #1
    joker.20
    joker.20 Threadstarter Erfahrener Benutzer
    Hier mal eine liste mit tweaks und scripts. hab selbst die meisten ausprobiert und hab bisher keine probleme.
    [TWEAKS][SCRIPTS] Collection of 'em all - build.prop; init.d; etc. On my ROMs adventure I've been collecting some tweaks and scripts and seems to me it's now time to share it. While some values in terms of optimization might fluctuate from device to device, I've found these pretty consistent throughout many.
    Build.prop
    (edit your /system/build.prop with a file manager with root access)
    Careful for already existing settings. In this case, just change the values.
    1. Force launcher into memory
    Code:
    ro.HOME_APP_ADJ=1
    2. Raise JPG quality to 100%
    Code:
    ro.media.enc.jpeg.quality=100
    3. VM Heapsize; higher the RAM, higher the hp can be
    Code:
    dalvik.vm.heapsize=48m
    4. Render UI with GPU
    Code:
    debug.sf.hw=1
    5. Decrease dialing out delay
    Code:
    ro.telephony.call_ring.delay=0
    6. Helps scrolling responsiveness
    Code:
    windowsmgr.max_events_per_sec=150
    7. Save battery
    Code:
    wifi.supplicant_scan_interval=180 pm.sleep_mode=1 ro.ril.disable.power.collapse=0
    8. Disable debugging notify icon on statusbar
    Code:
    persist.adb.notify=0
    9. Increase overall touch responsiveness
    Code:
    debug.performance.tuning=1 video.accelerate.hw=1
    10. Raise photo and video recording quality
    Code:
    ro.media.dec.jpeg.memcap=8000000 ro.media.enc.hprof.vid.bps=8000000
    11. Signal (3G) tweaks
    Code:
    ro.ril.hsxpa=2 ro.ril.gprsclass=10 ro.ril.hep=1 ro.ril.enable.dtm=1 ro.ril.hsdpa.category=10 ro.ril.enable.a53=1 ro.ril.enable.3g.prefix=1 ro.ril.htcmaskw1.bitmask=4294967295 ro.ril.htcmaskw1=14449 ro.ril.hsupa.category=5
    12. Net speed tweaks
    Code:
    net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960 net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960 net.tcp.buffersize.umts=4096,87380,256960,4096,16384,256960 net.tcp.buffersize.gprs=4096,87380,256960,4096,16384,256960 net.tcp.buffersize.edge=4096,87380,256960,4096,16384,256960
    13. Disable blackscreen issue after a call
    Code:
    ro.lge.proximity.delay=25 mot.proximity.delay=25
    14. Fix some application issues
    Code:
    ro.kernel.android.checkjni=0
    15. Phone will not wake up from hitting the volume rocker
    Code:
    ro.config.hwfeature_wakeupkey=0
    16. Force button lights on when screen is on
    Code:
    ro.mot.buttonlight.timeout=0
    17. Disable boot animation for faster boot
    Code:
    debug.sf.nobootanimation=1
    18. Miscellaneous flags
    Code:
    ro.config.hw_menu_unlockscreen=false persist.sys.use_dithering=0 persist.sys.purgeable_assets=1 dalvik.vm.dexopt-flags=m=y ro.mot.eri.losalert.delay=1000
    19. Specifics to some LG devices
    Code:
    persist.service.pcsync.enable=0 persist.service.lgospd.enable=0 user.feature.flex=true user.feature.lgdrm=false user.feature.lgresource=false user.feature.lgpoweroff=false user.feature.ls_event=false user.feature.ls_normal=false user.feature.sui=false
    Init.d
    (needs ROM with init.d access and busybox, open empty file, insert header #!/system/bin/sh and put these there, save in /system/etc/init.d and name it something like 77tweaks)
    1. strict minfree handler tweak
    Code:
    echo "2048,3072,6144,15360,17920,20480" > /sys/module/lowmemorykiller/parameters/minfree
    2. internet speed tweaks
    Code:
    echo "0" > /proc/sys/net/ipv4/tcp_timestamps; echo "1" > /proc/sys/net/ipv4/tcp_tw_reuse; echo "1" > /proc/sys/net/ipv4/tcp_sack; echo "1" > /proc/sys/net/ipv4/tcp_tw_recycle; echo "1" > /proc/sys/net/ipv4/tcp_window_scaling; echo "5" > /proc/sys/net/ipv4/tcp_keepalive_probes; echo "30" > /proc/sys/net/ipv4/tcp_keepalive_intvl; echo "30" > /proc/sys/net/ipv4/tcp_fin_timeout; echo "404480" > /proc/sys/net/core/wmem_max; echo "404480" > /proc/sys/net/core/rmem_max; echo "256960" > /proc/sys/net/core/rmem_default; echo "256960" > /proc/sys/net/core/wmem_default; echo "4096,16384,404480" > /proc/sys/net/ipv4/tcp_wmem; echo "4096,87380,404480" > /proc/sys/net/ipv4/tcp_rmem;
    3. vm management tweaks
    Code:
    echo "4096" > /proc/sys/vm/min_free_kbytes echo "0" > /proc/sys/vm/oom_kill_allocating_task; echo "0" > /proc/sys/vm/panic_on_oom; echo "0" > /proc/sys/vm/laptop_mode; echo "0" > /proc/sys/vm/swappiness echo "50" > /proc/sys/vm/vfs_cache_pressure echo "90" > /proc/sys/vm/dirty_ratio echo "70" > /proc/sys/vm/dirty_background_ratio
    4. misc kernel tweaks
    Code:
    echo "8" > /proc/sys/vm/page-cluster; echo "64000" > /proc/sys/kernel/msgmni; echo "64000" > /proc/sys/kernel/msgmax; echo "10" > /proc/sys/fs/lease-break-time; echo "500,512000,64,2048" > /proc/sys/kernel/sem;
    5. battery tweaks
    Code:
    echo "500" > /proc/sys/vm/dirty_expire_centisecs echo "1000" > /proc/sys/vm/dirty_writeback_centisecs
    6. EXT4 tweaks (greatly increase I/O)
    (needs /system, /cache, /data partitions formatted to EXT4)
    a) removes journalism
    Code:
    tune2fs -o journal_data_writeback /block/path/to/system tune2fs -O ^has_journal /block/path/to/system tune2fs -o journal_data_writeback /block/path/to/cache tune2fs -O ^has_journal /block/path/to/cache tune2fs -o journal_data_writeback /block/path/to/data tune2fs -O ^has_journal /block/path/to/data
    b) perfect mount options
    Code:
    busybox mount -o remount,noatime,noauto_da_alloc,nosuid,nodev,nodiratime,barrier=0,nobh /system busybox mount -o remount,noatime,noauto_da_alloc,nosuid,nodev,nodiratime,barrier=0,nobh /data busybox mount -o remount,noatime,noauto_da_alloc,nosuid,nodev,nodiratime,barrier=0,nobh /cache
    7. Flags blocks as non-rotational and increases cache size
    Code:
    LOOP=`ls -d /sys/block/loop*`; RAM=`ls -d /sys/block/ram*`; MMC=`ls -d /sys/block/mmc*`; for j in $LOOP $RAM do echo "0" > $j/queue/rotational; echo "2048" > $j/queue/read_ahead_kb; done
    8. microSD card speed tweak
    Code:
    echo "2048" > /sys/devices/virtual/bdi/179:0/read_ahead_kb;
    9. Defrags database files
    Code:
    for i in \ `find /data -iname "*.db"` do \ sqlite3 $i 'VACUUM;'; done
    9. Remove logger
    Code:
    rm /dev/log/main
    10. Ondemand governor tweaks
    Code:
    SAMPLING_RATE=$(busybox expr `cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency` \* 750 / 1000) echo 95 > /sys/devices/system/cpu/cpufreq/ondemand/up_threshold echo $SAMPLING_RATE > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/sampling_rate
    11. Auto change governor and I/O Scheduler
    a) I/O Scheduler (Best: MTD devices - VR; EMMC devices - SIO) - needs kernel with these
    Code:
    echo "vr" > /sys/block/mmcblk0/queue/scheduler or echo "sio" > /sys/block/mmcblk0/queue/scheduler
    b) Governor (Best: Minmax > SavagedZen > Smoothass > Smartass > Interactive) - needs kernel with these
    Code:
    echo "governor-name-here" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    12. Auto-zipalign on boot
    (needs zipalign bin)
    Code:
    [Q]zipalign on boot code - xda-developers
    13. Loopy Smoothness tweak
    Code:
    http://forum.xda-developers.com/show....php?t=1137554 http://forum.xda-developers.com/show....php?t=1205744
    14. Move dalvik-cache to cache partition (if it's big enough) to free up data partition space
    Code:
    CACHESIZE=$(df -k /cache | tail -n1 | tr -s ' ' | cut -d ' ' -f2) if [ $CACHESIZE -gt 80000 ] then echo "Large cache detected, moving dalvik-cache to /cache" if [ ! -d /cache/dalvik-cache ] then busybox rm -rf /cache/dalvik-cache /data/dalvik-cache mkdir /cache/dalvik-cache /data/dalvik-cache fi busybox chown 1000:1000 /cache/dalvik-cache busybox chmod 0771 /cache/dalvik-cache # bind mount dalvik-cache so we can still boot without the sdcard busybox mount -o bind /cache/dalvik-cache /data/dalvik-cache busybox chown 1000:1000 /data/dalvik-cache busybox chmod 0771 /data/dalvik-cache else echo "Small cache detected, dalvik-cache will remain on /data" fi
    15. Disable normalize sleeper
    Code:
    mount -t debugfs none /sys/kernel/debug echo NO_NORMALIZED_SLEEPER > /sys/kernel/debug/sched_features
    16. OOM groupings and priorities tweaks - SuperCharger
    Code:
    [Script][Update 9 Beta 6!] V6 SuperCharger! The ONLY Android MEMORY FIXER! 3G & KAK! - xda-developers
    GPS.conf
    (create or edit your /system/etc/gps.conf with a file manager with root access)
    For improving GPS lock time and signal.
    a) European NTP server (replace for america or asia in your case)
    Code:
    NTP_SERVER=europe.pool.ntp.org XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
    b) SE supl for A-GPS (better than Nokia's or Google's)
    Code:
    SUPL_HOST=supl.sonyericsson.com SUPL_PORT=7275
    Other tweaks or guidelines
    1. Patch your hosts file for blocking Ads
    (please think before doing this; many developers are supported through this way)
    Code:
    You can use AdFree application for this or changing manually your hosts file. Here are some databases: http://www.mvps.org/winhelp2002/hosts.txt Ad server hostnames for blocking ads (format: hosts -- in hosts file format)
    2. Use CyanogenMOD's APN list file - it's one of the most complete.
    Code:
    It's located in /system/etc/apns-conf.xml
    3. Use UOT kitchen for basic theming on your device.
    Code:
    UOT Kitchen
    4. Use Google's dns servers
    Code:
    Create an empty file, name it resolv.conf and put there these 2 lines: nameserver 8.8.8.8 nameserver 8.8.4.4 Save to /system/etc/.
    5. Update Superuser and su binary to latest version (3.0 beta)
    Code:
    goo-inside.me - superuser downloads
    6. Disable sync feature in sqlite
    (author: ownhere - needs a source for your device so you can compile the /system/lib/libsqlite.so)
    Code:
    Patch file here: [dev][sqlite3] 21/Jan, how to disable sync in sqlite3 without pragma - xda-developers
    7. Do not use task killers.
    Alright, I think this is it for now.
    If you have any other tweaks or better values, you can PM me and I'll include them.
    Jackthecrack bedankt sich.
  2. Blame, 23.11.2011 #2
    Blame
    Blame Android-Hilfe.de Mitglied
    Nur zwei Fragen...
    1. Was hat es mit folgenden Codes auf sich?
    Code:
    Code:
    2. Schaltet der code debug.sf.nobootanimation=1 nur die Animation aus oder auch rein zufällig den Startsound? (Benutze zwar Silentboot, aber das könnte man sich ja dann ersparen.)
  1. init.d script android collection
  2. mtk build prop
  3. init.d scripts tweak
  4. tweak system bin android,
  5. Tweak collection for android,
  6. ipv4 script initd,
  7. network tweak bin system android,
  8. script tweak ipv4 xda,
  9. best tweak ipv4 android,
  10. Init.d Tweaks,
  11. tweak 3d android,
  12. tweak internet android,
  13. best build.prop tweaks,
  14. init d tweak host android,
  15. huawei mate 8 build.prop xda
Du betrachtest das Thema "[TWEAKS][SCRIPTS] Collection" im Forum "Root / Hacking / Modding für das LG Optimus 3D",
  1. Android-Hilfe.de verwendet Cookies um Inhalte zu personalisieren und dir den bestmöglichen Service zu gewährleisten. Wenn du auf der Seite weitersurfst stimmst du der Cookie-Nutzung zu.  Ich stimme zu.
