1. Hast Du Lust, bei uns mitzuarbeiten und das AH-Team zu verstärken? Alle Details zu dieser aktuellen Herausforderung findest Du hier.
  1. plastikcity, 19.03.2012 #1
    plastikcity
    plastikcity Threadstarter Gast
    Hi habe gerade gesehen das es für das Atrix die 7.2.0 als RC2 gibt.
    Allerdings laufen die Downloads unter den Codenamen der einzelnen Geräten. Also für das Atrix = Olympus
    Link:http://get.cm/get/RC/update-cm-7.2.0-RC2-olympus-signed.zip
    7.2.0
    CHANGELOG
    • New devices: Samsung Galaxy Ace, Mini, and Epic. LGE Optimus Black, 3D, Hub, Pro, Sol, and One. Motorola Atrix. Sony Ericsson Xperia Live, Pro, and Active. Huawei U8150
    • Common: Updated translations - (everyone)
    • Common: T9 predictive Phone dialer - Danesh M, Pawit Pornkitprasan
    • Common: Media player and recorder fixes for a number of corner cases - CAF, Danny Baumann
    • Common: Profile resets - Ladios Jonquil
    • Common: Assorted Wifi fixes
    • OMAP Common: Support for recent OMAP3/OMAP4 devices - omapzoom
    • Common: Control haptic in quiet hours - Danesh M
    • Common: Lockscreen updates and new styles - Andrew Sutherland, Danny Baumann, Danesh M, Sven Dawitz, Taichi Nishimura
    • Common: Bluetooth MAP support - Jonathan Bensen
    • Common: ICS telephony fix backports - Spencer Oliver
    • Common: Support for Bluetooth GPS dongles - Cuong Bui
    • Common: Better support for mouse and usb keyboards - Emilio Lopez, Tanguy Pruvot
    • Common: Fix timezone detection in Hawaii - Warren Togami
    • Common: ICS Transition effects backport - Russ Underhill
    • Common: ICS Rotation effects backport - Tanguy Pruvot
    • Common: Allow photo storage selection when possible - Greg Kochaniak
    • Common: Improved Calendar reminder options - Danny Baumann
    • Common: Fix color banding in Gallery while displaying 32bpp images - Sang Tae Park
    • Common: ADB over network
    • Common: Improved AVRCP 1.3 compatibility
    • Common: Improved external keyboard and mouse behaviour on some corner cases - Tanguy Pruvot
    • Common: Status bar battery icon configuration - Simon Davie
    • Samsung Galaxy S GSM devices: Fix emergency dialing
    • p990: Add FM Radio support
    • p990/p999: fix background calls, fix HDMI output in 1080p
    • zeppelin, morrison, motus: Fixed camera zooming issues
    • Samsung Galaxy S devices: Add tv-out
    • Several devices: Fix device identification on Android Market
    • crespo, jordan, blade, v9, Samsung Galaxy S devices: Device specific settings section
    Zuletzt von einem Moderator bearbeitet: 14.05.2012
    swentzi gefällt das.
  2. pixi123, 19.03.2012 #2
    pixi123
    pixi123 Neuer Benutzer
    ^^irgendwie startet bei mir der download nicht...
    hat jemand das selbe problem?
  3. plastikcity, 19.03.2012 #3
    plastikcity
    Ja seltsam habs mir heute früh Heruntergeladen. Vielleicht sind die Server im Moment überlastet.
    Versuchs am besten morgen nochmal, oder später.
  4. pixi123, 19.03.2012 #4
    pixi123
    danke, dachte schon das geht gar nicht...
  5. JonnyBlue, 19.03.2012 #5
    JonnyBlue
    JonnyBlue Android-Hilfe.de Mitglied
    Wofür steht das "RC"?
    Edit: Ok, steht für "release candidate".
  6. plastikcity, 20.03.2012 #6
    plastikcity
    Habe die Version seit gestern mit dem aktuellen Faux Kernel Laufen, und konnte bis jetzt keine Bugs feststellen. Läuft genauso gut wie die letzte weekly. Zum Akkuverbrauch kann ich noch nichts sagen da ich nach dem flash immer einen Wipe vornehme. Im Moment habe ich nach 13 Stunden noch 70%. Habe gestern aber auch ziemlich viel gemacht.
    Mal schauen.
  7. plastikcity, 20.03.2012 #7
    plastikcity
    Oh Mann 70 Prozent nach 13 Stunden. Davon kann ich nur Träumen. Bei mir ist nach 12 Stunden Schluss. Und ich habe auch schon einen Wipe gemacht. Selbst wenn ich gar nichts mache und kein einziges App Installiert habe hält der Akku Maximal 20 Stunden. Es ist echt zum Heulen. Vielleicht wird es ja mit der Version besser.
  8. Arek81, 20.03.2012 #8
    Arek81
    Arek81 Neuer Benutzer
    Hallo Leute,
    könnt Ihr mir sagen, wie und woher ich den Market, Googlemail, Konto etc instaliere?
  9. plastikcity, 20.03.2012 #9
    plastikcity
  10. Arek81, 20.03.2012 #10
    Arek81
    Besten Dank!!
  11. sunfreak1, 20.03.2012 #11
    sunfreak1
    sunfreak1 Fortgeschrittenes Mitglied
    wie läuft das bei der rom mit dem kernel, bleibt einfach der alte erhalten oder bringt cm7.2 einen mit?
  12. detlefroeckert, 20.03.2012 #12
    detlefroeckert
    detlefroeckert Junior Mitglied
    Also ich habe die ROM seit heute früh drauf und habe bis jetzt noch keinerlei Probleme.
    @sunfreak1: cm7.2 bringt einen Kernel mit, der mit 1GHz taktet, und zwar steht bei mir:
    2.3.6.57-MB860-CM7-g06f7d49
    root@laptop#46
    - was immer das auch heißen mag. Hier mal ein Screenshot:
    sunfreak1 gefällt das.
  13. Michail90, 20.03.2012 #13
    Michail90
    Michail90 Neuer Benutzer
    wie sieht es mit dem Akkuverbrauch aus?
  14. sunfreak1, 20.03.2012 #14
    sunfreak1
    wie schaut das mit dem fingerprintsensor und der camera aus, volle unterstützung?
  15. Merza29, 21.03.2012 #15
    Merza29
    Merza29 Android-Hilfe.de Mitglied
    Bei mir vibriert das Handy bei Benachrichtigungen wie SMS nicht mehr egal was ich einstelle?
  16. Arek81, 21.03.2012 #16
    Arek81
    Wie läuft das rom bei euch? Bis auf 2 Reboots habe ich bisher keine Probleme, ausser schlechten Empfang mit O2 :( aber das war mit dem originalen rom auch schon so.
    Kann man eigentlich die Auflösung ändern wenn das Ding am Dock hängt?
  17. detlefroeckert, 21.03.2012 #17
    detlefroeckert
    :crying:Akkuverbrauch ist relativ hoch, hatte letzte Nacht in 8 Stunden (nur 3G) rund 18% Verbrauch. Ist mir zu hoch. Und einen Reboot hatte ich auch schon. Einfach so, aus heiterem Himmel. Habe jetzt die neue NEUTRINO (http://forum.xda-developers.com/showthread.php?t=1398819) drauf, mal sehen, wie die so ist.:confused2:
  18. plastikcity, 22.03.2012 #18
    plastikcity
    Reboot hatte ich noch keinen. Akkuverbrauch ist mit dem Faux 024r2 Kernel Super. Nach knapp 20 Stunden bin ich bei 80% und ich habe gestern viel gemacht inkl. Nandroid Backup, und mehrfachen Neustarts.
  19. plastikcity, 22.03.2012 #19
    plastikcity
    Bei mir auch keine Reboots. Akkuverbrauch ist auch super. Mache jetzt immer einen Wipe wenn ich ein neues Rom flashe und seit dem gehts auch mit dem Akkuverbrauch.
    @detlefroeckert Neutino basiert auf der Aktuellen CM7.
  20. cybot, 22.03.2012 #20
    cybot
    cybot Android-Experte
    Akkuverbrauch mit dem Faux Kernel ist phänomenal gering.
    Auch sonst insgesamt verbessert im Vergleich zu den Weeklys (gefühlt)
    Fingerprint läuft. Kamera läuft.
Du betrachtest das Thema "CyanogenMod 7.2.0 RC1 ist da" im Forum "Root / Hacking / Modding für das Motorola Atrix",
