Odys Loox - Thread for international users [English]
  • 26 Antworten
  • Neuester Beitrag
Diskutiere Odys Loox - Thread for international users [English] im Root / Hacking / Modding für das Odys Loox im Bereich Odys Loox Forum.
hävksitol
hävksitol
Ehrenmitglied
Hello,
as a German-language discussion board, we attach great importance to ensuring that all contributions are written in German. If you can't speak German, please post your questions and answers in English and only in the current thread; otherwise they will be deleted.
Thank you for your understanding.
Kind regards,
AH-Team
cmd77
Hei Oma,
thanks for CM9. It looks nice.
First problem after installing - adobe flash player. I opened the browser, it installed adobe flash 11 (it is showed in downloaded apps) but sites with flash requiring not working). Also in apps something it looks strange becouse data is 0 cache is 0.
Do I make something wrong?
Thanks
netlars
@cmd77
hey,
flash player it's a bug, we are working on it.
mvandrei
Hello,
I am sorry I am not writing in german. I thought of using google translate, but the translation is not that accurate.
I have installed the latest version of 4.0.4 on my Odys LOOX, but I don't have the keyboard. When I try to write the password for wireless connection, or to connect with gmail account, only the microphone option pop-ups. If I close it, and press on show password, then the keyboard sign appears on the left, and when I press it, nothing happens.
Any ideas what can I do to fix it please?
Thanks in advance,
Andrei
Oma7144
Oma7144
Lexikon
Install the JellyBean Keyboard.apk (see post #1036) and enable it under Language & input.
:thumbup:
mvandrei
Hey,
thanks for the quick reply:smile:!
Can you please help me with that post?
As far as I understand, I have to copy Grandma - Format_NAND to SD? (internal I believe).
If it's correct, how can I do that? What's the procedure?
Thanks,
Andrei
Oma7144
Oma7144
Lexikon
No copy it to external sd-card. Change card from Loox to PC.
:thumbup:
Der ursprüngliche Beitrag von 19:14 Uhr wurde um 19:17 Uhr ergänzt:
wagi72 schrieb:
Mein Bildschirm steht seit ca. 20 Minuten beim Oma-Screen, nach den Blitzen. Ist das normal?
Nein, da ist dann was schief gegangen. Versuche noch mal von vorne:
- Netzteil angeschlossen?
- EraseIDB ausgeführt?
- Loader mit geflasht?
- Fix format_NAND ausgeführt?
:thumbup:
mvandrei
:thumbup:
OK. I did that. I installed it. The only remaining problem is the keyboard. Where I must place the .apk file and how do I install it please? I read that article several times now, and I still don't get it!
Thanks.
Andrei
Oma7144
Oma7144
Lexikon
Copy the .apk to sd-card. Open File Manager navigate to sd-card and touch the .apk to install.
:thumbup:
mvandrei
:thumbup:
Thank you SO MUCH! I don't know why and how, but the first time I tried, the files were not displayed! After changing form the theme style, I found them on the SD.
Is the apk virus-free? No keylogger? :)
Thanks a lot again!!!!! You're the best! German people rock :):thumbsup:
Oma7144
Oma7144
Lexikon
You are welcome. Where are you from mvandrei?
:thumbup:
mvandrei
Bucharest, Romania.
Why?
denys_only4u
HI OMA sorry for english i am new here and i need help with usb stick 3G conection not working but with ICS OMA 1.2.5 it was working help me please?
maxb2000
And when will be ready to download or 1.2.8a is this version?
Thanks you! Very good job.
calinux
hi,
tried two times the PPP widget, first time ver. 0.98 from this forum and second time ver. 1 from play, had to unistall both times because of severe interference and lags this widget is procuring everytime something gets on/off USB, including internal wifi switch.
haven't found a way to stop the daemon when i don't need 3G - most of the time i'm on wifi.
regarding performance, none of huawei E220 or E272 which worked with stock rom and doesn't on 1.2.8 are not driven by PPP widget, same for a new K3772 and another new model.
what worked really well thru PPPwidget and would have been a nice option was my old Nokia 5230 which connected all the times without a glitch.
maxb2000
Thanks you! I flashed JB without problems.
Z
zogzog
Bug report (in english, I'm deeply sorry)
- rootfs still have TWO toolbox !! (please get rid of the buggy toolbox!) (try 'ls -t' then 'busybox ls -t')
- AFAIK 1.2.8 don't have a stock soft keyboard but voice recognition witch make entering password really really really hard. (please get rid of the bloatware and keep the stock apps)
Anyway that's a superb rom, keep the good work guys.
Have a nice day.
