[ROM] Corvus5 (newbe5 and Corvus teamed) ROM
ooolli
ooolli
Eine neue Version des Corvus ROM, bzw. der Nachfolger des CorvusVegaRom_0.5
Link zum Thread und Download im xda Forum
[ROM] Corvus5 (newbe5 and Corvus teamed ROM) - xda-developers
Informationen zum ROM
Features:
(Old features from CorvusVegaRom 0.5)
NTFS, CIFS, and some other kernel tweaks
Patched against last malware (search xda for info)
CWM recovery added directly in the installation, and app to access it too.
Full Market working
Automount of FAT and NTFS devices
CIFS/NFS support (with Mount Manager from market)
VPN support (replace tun.ko module in /system/lib/modules with the one in the modules.zip)
Sqlite3 exec for modify app databases
gps.conf updated for better fixing
apns-conf.xml updated for 3G dongles
Reboot option added to shutdown menu
Fix BSOD when reboot, no more black screens...
Multitouch for Google Maps
Ads blocked using host file. (If you have any problem with this go to /system/etc/hosts and delete any problematic line).
Screen calibration app added.
Added a script to know if we are in host or slave mode, and GscriptLite that is needed.
Added Wfi Ad-Hoc support, so now can connect to ad-hoc networks.
(NEW in Corvus5)
Updated kernel with overclocking to 1.4Ghz
Performance boost, now in smartbech 2011 we get +4000/+2000 points !!!
UTF8 support
Added scripts to check/switch the way accelerometer works (game mode or mouse mode, so this can be selected)
Added TapNTap keyboard from Viewsonic G Tab
Replaced Gallery3D with 32bit-Gallery3D
Updated Clockwork Recovery to 3.0.2.4 (this still shows as 2.5.1.4 in ROM manager, but it is updated)
Removed Paul's Recovery Tool
Added ROM Manager (this can reboot you into recovery, so no need for 2 tools)
Removed Phone related APK's (Battery AHOY! This should increase battery life significantly, definately has for me!. This files can be added again using 3gFiles.zip attached)
Disabled Setup Wizard (will ask for google account information when you first run Market)
Removed VTL Launcher (All users have their own preference, so you can install which launcher you like)
Removed Task Manager (Pretty useless app imo, install better a one from the Market if you need one)
FIXED ACCELEROMETER!! This is now 100% working with perfect sensitivity for games etc, you MUST disable screen auto-rotation in settings for this to work properly.
*To help the above, newbe5 have created an auto-rotate on/off widget with a theme to match the rest of the ROM. Add it to your home screen from the Widgets menu as normal.This widget is a modified version of the one released on the Market for free by Jason Hull. Thanks Jason!
THEME! A whole new theme has been created from scratch specifically for this ROM. This theme was created by newbe5 and is called: GRID.
As part of the theme, most (if not all) of the transition animations have been changed to smoother ones.
EXPERIMENTAL:
I have compiled a bunch of modules lile tun, eyetoy module, some modules for dvb-t dongles and some for gamepads. They are attached, but no support for them... use at your risk.
BEFORE MAKE ANYTHING, PLEASE READ THIS FULL POST AND DO A NANDROID BACKUP (WITH CWM). I WILL NOT TAKE ANY RESPONSABILITY IN ANY WAY IF YOU BRICK, EAT, OR SIT YOUR TABLET
NOTES
For enter usb host mode:
Press power button, once display get power (you will see the diference), press back button and hold until finish booting.
For know usb mode:
In Gscript Lite, we only need to create a new script and use "cat /data/var/mode" without quotes and with "Needs SU?" marked. It will return in what mode are we, slave or host.
For 3g Dongle (with 3gFiles.zip added):
Start in host mode (back button pressed until vega boots) with 3g dongle inserted.
Once started, extract and put back 3G dongle. If you have PIN it will ask for it.
Test dongle (mine green is working, light blue is detected, but not connected, dark blue is connected). If it stalls in light blue, you have a problem with apns, edit /system/etc/apns-conf.xml or pm me.
For Links2SD:
In Links2SD you get an error first time you start it... reboot tablet and works ok.
If no music or wallpapers are show:
Load "Dev Tools" and restart the media scanner and once completed everything was shown
For check/change accelerometer mode:
With connectbot exec...
/system/bin/MouseGameModeChecker.sh to see in what mode is your tablet.
/system/bin/MouseGameSwitcher.sh to switch from game to mouse and back.
For overclocking:
Method 1:
Put the setcpu.txt file attached in the root of your sdcard and then start setcpu (if you have started earlyer, must press menu and press the left button "device") then select the bottom button (custom freqs) then you can move the slide to 1400000.
Method 2:
Download CPU Meter from market. It must detect the freqs and let you use them. Dont change any other parameter, use at your own risk.
Reaktionen: tendo2008
Ich finde solche infos sehr gut....
Aber... für die leute die nicht zu den profis gehöhren... also ich...:thumbdn:
Würde ich mir wünschen eine kurze deutsche beschreibung um dieses rom auf mein pov zu bringen.
Sonst kann ein anfänger nichts damit anfangen, oder soll dieser beitrag nur für profis sein.
Dann müßt ihr die tropfnasen ausschließen aus diesem bereich.
:love:
Reaktionen: kaulquap
ok ich habe es mal ausprobiert.
datei corvus5 runtergeladen und auf meinem pc entpackt.
pov mobii tegra 2 am pc mit usb kabel verbunden.
dann in einstellung - anwendung- entwicklung usb-debugging einen hacken gesetzt.
anschließend habe ich die entpackte datei install-windows gestartet und das update hat gearbeitet. nach einer weile wurde das system neu gestartet und siehe da, es funktioniert. :love:
ich habe gleich die 1.4 Ghz angeschmissen und es klappt. läuft sehr schnell das system.
die 3g geschichte habe ich noch nicht hinbekommen, wenn jemand einen tip hat, dann bitte...
und danke für die hilfe!? selbsthilfe:sneaky:
aber der tip war gut
3g über clockwork installieren .. zipdatei ist im xda doch angehängt ..
3g ist deaktiviert in der rom .. zwecks akkulaufzeiten ..
Danke, das habe ich hin bekommen. Mein usb funktioniert nicht mehr. Kann kein usb stick mehr anschließen. Und das usb tool funktioniert nicht mehr. Wie ist das mit der powertaste und rücktaste gemeint. Diese auswahlfunktion beim starten. Oder habe ich da was falsch verstanden.:huh:
.. wenn du im anderen modus starten willst .. also entweder slave oder master .. dann musst du, nachdem du dein tablet einschaltest.. den powerknopf loslassen und bis das android geladen ist den finger auf der rücktaste lassen .. also booten mit gedrückter rücktaste ..
Reaktionen: dg5fdg
Danke für deine schnelle antwort. Habe gestern noch std. Versucht das hin zu bekommen. Es funktioniert.
Diese rom ist wirklich super und sehr schnelll. Ich habe aber keine wipe gemacht, ist das schlimm? Es läuft aber sehr gut.:lol::love::thumbsup:
nein hab ich auch nicht .. solltest du aber in betracht ziehen wenn es zu untypischen fehlermeldungen kommt .. also das android selber anfängt zu spinnen... das es mal apps gibt die nicht so wollen .. damit kann man leben ..
So nach 2 tagen testen muß ich sagen, dass ist die beste rom für das pov mbii tegra 2.
das rom läuft sehr flüssig und schnell.
Schön ist auch die 1400Khz dröhnung die geht richtig ab.
Meine volle empfehlung für Corvus 5.:thumbsup:
stimmt das rom ist derzeit das beste was man fürs tablet kriegen kann aber ich krieg meinen 3g dongle nicht zum laufen.
ist ein Huawei e220 der unter modaco r8 problemlos funktioniert.
hab 3g.zip richtig installiert, LED blinkt auch blau oben in der taskleiste taucht immer für ein paar sekunden die signalbalken auf aber ich kann mich nicht ins netz einlogen. hab auch schon die APN-Config.xml getauscht aber das hilft gar nix....hat wer von euch einen tipp für mich!!!!!....lg
Gibts schon erfahrungen mit dem overclocking? Wie siehts mit der Akkulaufzeit aus besser oder schlechter?
Danke
Akkulaufzeit ist etwa gleich zur Vorgängerversion, ich nutze aber kein Overclocking.
Die letzten Tage ist mir aber öfters mal ein "einfrieren" des Tablets aufgefallen, das hatte ich beim Corvus 0.5 nie. Hat das sonst noch jemand? Kann aber auch daran liegen, dass ich meine Apps inkl. Daten mit TitaniumBackup wiederhergestellt hab.. also keine 100% saubere Installation.
Sent from my HTC Desire Z
Das kann ich nicht bestätigen. Ich habe es über die modaco r8drüber installiert und es rennt wie sau.:thumbsup: übertakten läuft sehr stabiel auch beim spielen. Aku laufzeit min.4 std. Und mehr . Bin sehrr zufrieden.
Hast du alle Apps sauber neu installiert, also ohne TitaniumBackup inkl. der App-Daten?
Nach etwas Kampf mit mir und der Software ist sie nun drauf. Läuft recht gut und schnell.
Weiß jemand wie man die 3G Software mit dem internen Modem vom POV bzw. Smartsurfer ans laufen bekommt? Installiert ist sie, aber es taucht kein 3G im Setup auf.
Nein habe ich nicht. Einfach drüber installieren un fertig. Habe keine wipe gamacht. Hatte mich auch gewundert das es stabiel läuft.
Die geschichte habe ich auch noch nicht zum laufen bekommen. Bei der modaco lief es schon nicht.
jetzt geht 3G bei mir mit dem Corvus :)
nur das GPS will nicht, eventuell ist doch keines eingebaut...
"geht nicht" ist auch immer der klassiker bei support-anfragen :thumbsup:
also wenn man probleme hat .. ist es hilfreich .. zu schreiben was man installiert hat .. und was man versucht hat, das problem zu lösen ..:huh:
Hat jemand eine Idee wie man ein QWERTZ Keyboard mit Corvus hinbekommt?
Semmeln
mutzsow
remmi-z
