[GT-P6200][WIP] CyanogenMod 9 (developer preview)
Ace9876
Ace9876
29
Aorth hat soeben den Thread auf XDA erstellt (01.04.2012 21:06 Uhr). Es handelt sich um Cyanogenmod 9 für das GT-P6200.
14.05.2012
Nun ist es endlich soweit, Cyanogenmod 9 ist jetzt für das GT-P6210 erhältlich, es gab zwar vorher auch CM9 für das P6210 aber es war lange nicht so gut wie das vom P6200.
Hier als Zitat:
aorth schrieb:
Hear ye, hear ye! I've started porting CyanogenMod 9 to the Galaxy Tab Plus. While it's up and running (and actually quite usable), this is really only a developer preview. Please understand that this is a very rough initial port, and lots of stuff doesn't work.
Warning! Do not flash!
Do not flash this unless you know how to backup your data and especially unless you know how to get back to stock. If you don't already know how to do this, you might want to [thread=1517934]familiarize yourself with the process now[/thread], while the other developers and me get CM9 to a more "daily driver" state. I don't have time to help n00bs unbrick their devices. No offense!
Like I said, this is an extremely early alpha preview. It's a proof of concept, not a finished product. I repeat, this is not anywhere near a daily driver yet. In any case, here's a list of what's working so far (by no means a comprehensive list)...
What's working:
  • Accelerometer
  • Proximity sensor
  • Torch app
  • Touch input
  • Vibration
  • Physical buttons (volume + power)
  • Sound
  • Telephony (voice, sms, data)
  • GPS
  • USB tethering
  • Bluetooth
What's kinda working:
  • USB mounting of sdcard (removable sdcard, not internal "sdcard"!)
  • Camera (low resolution for back camera only, and easily crashable!)
  • Hardware-accelerated video (simple stuff like mp4)
What's not working:
  • Wifi
  • Ambient light sensor
Download (P6200)
ROM (June 13, 2012): goo-inside.me (md5: e752faa9ed411c77f88295ccfbad1e2c)
ClockworkMod Recovery (5.5.0.4): goo-inside.me / MediaFire (md5: 60517dc528c983ec9d8832c9a48934e5)
Google Apps: Goo.im Downloads - Browsing gapps (use the CyanogenMod 9 one)
Download (P6210)
ROM (June 10, 2012): goo-inside.me / ccore.tk (md5: 6816a2684f41bc39d21b99cf0661c5d7)
ClockworkMod Recovery P6210 (5.5.0.4): goo-inside.me / Mediafire (md5: 91abb149a266beee7f32126442c4e84a)
Old
ROM (June 10, 2012): goo-inside.me / ge.tt / ccore.tk (md5: 3d2821d62bfad6295bdf5acaf2766d1e)
P6200 (DP3.2, May 19, 2012): goo-inside.me / ge.tt (md5: 1271d226e74a96341d75a8439735eac1)
ROM (DP3.2, May 19, 2012): goo-inside.me (md5: 38ed64d1f625ef7d5d174007139f008e)
P6200 (DP3.1, May 17, 2012): goo-inside.me / get.tt / mirrors wanted! (md5: 30a854a829e8d7c5dfb12fc85fd2671a)
P6210 (DP3.1, May 17, 2012): goo-inside.me / mirrors wanted! (md5: 4807a596ad017dfccf1c9351edde671b)
Flash
Flash from ClockworkMod Recovery 5.5.0.4 (probably works with 5.0.2.x, but I use 5.5.0.4 so your mileage may vary). Make sure to wipe data/factory reset. No whining if it eats your homework.
Changelog
June 10, 2012
  • Bluetooth is working
  • Sync with latest upstream CM9 (new Apollo music player, CRT Off animation, new Cid boot animation, etc)
  • Seems I broke low-power mode charging...
DP3.2 Hotfix 1 (May 27, 2012)
  • P6200: New kernel with mic fix
DP3.2 (May 19, 2012)
  • Rear camera working again (regression in DP 3.1)
DP3.1 (May 17, 2012)
  • Off-mode charging now works
  • Sync'd with latest upstream repos (a few new high-res icon graphics, not too noticeable)
DP3 (May 13, 2012)
  • Rebased work ontop of the 3.0.x-based smdk4210 kernel
  • RIL working again (now using Galaxy S II RIL blobs)
  • GPS working again
  • Some hardware-accelerated video should work (not all video/audio codecs are working yet)
  • Rotation animation doesn't glitch anymore
  • Camera kinda works... strong emphasis on "kinda"
  • Ditto for wifi
DP2 (April 13, 2012)
  • Audio working
  • GSM partially working (calls, SMS, and some USSD requests). Getting data working on this one is trivial if you're [post=24796497]not afraid to use adb[/post].
DP1 (April 1, 2012)
  • Initial preview
Sources
We share a LOT of similar hardware with other Exynos 4210 / Mali 400MP devices. Right now we're sharing lots of code with the Tab 7.7 people. Here is a list of where you can find my/our code.
Credits
  • ohanar -- set up the initial device tree for the GT-6810 (Tab 7.7 Wifi). Huge help and time saver!
  • teamhacksung -- badass dev dudes who have a dream
  • goo-inside.me -- hosting
Donate
I do this for fun (I have a day job that pays me). If you're able to donate, donate to one of the following organizations, without whom none of this would be possible:
Reaktionen: TimoBeil und Beutelbär
Hier ein paar Bilder(aus XDA entnommen)
aorth schrieb:
Reserved for changelog, detailed flashing instructions, etc. :)
Screenshots to tide you over!
Reaktionen: Beutelbär
Danke für die Info :)
Klingt spannend - hoffentlich wird das auch kompatibel zum GT-P6201 werden...
BB
Müsste kompatibel zum P6201 sein, da die Hardware ja die gleiche ist. Beim P6210 und P6211 sieht es wiederum anders aus.
Ace9876 schrieb:
Da es für das Samsung Galaxy Tab 7.0 Plus kein Root/Hacking/Moding Unterforum gibt, poste ich es einfach hier hin, hoffe es stört niemanden.
Nein, das stört niemanden. Ganz im Gegenteil: da du der erste bist, der ein solches Unterforum in Sachen CustomROM mit Leben füllt, war dies der Anlass, diesen Bereich zu eröffnen und deinen Thread sogleich hierher zu verschieben.
Reaktionen: Ace9876
Ja, "müßte" halt... Mal schauen, wenn ich mich dann irgendwann mal traue werde ich berichten :)
Interessant! Was ist denn zwischen den beiden der Unterschied? Sind ja beide die WiFi only Version, oder? :confused:
BB
BB
Ich würde an deiner Stelle noch abwarten, die Liste von den nicht Funktionierenden Sachen ist leider noch größer als die von den Funktionierenden :D
P6200/P6201 ist die 3G Version und die P6210/P6211 ist die WiFi only Version. Wenn man das falsche flasht ist das Tab im Ar***.
Also kann mann das auch für das 6201 3g nehmen?
Und noch ne blöde frage gibt's denn schon CWM Version für uns?
Weil wer toll mit der stand Version komm ich nicht so klar.
Danke schon mal.
Gesendet von meinem GT-P6201 mit Tapatalk
Danke schon mal.
Ich weiß nicht ob es mit dem 6201 klappt, aber da es die gleiche Hardware hat müsste (muss aber nicht) es funktionieren. Ich übernehme keine Haftung falls was schief geht. Habe selbst leider nur das 6211 und kann es nicht testen.
CWM gibt es. [GT-P6200][CWMRecovery][ROOT]ClockworkMod Recovery and Root - xda-developers
Kannst dich mal schlau machen, hab es selbst noch nicht auf meinem 6211.
Muss ich das mit odin Flaschen die cwmr?
Hmm also ich bekomme immer error das das nur für das 6200 ist da ich das 6201 hab geht das woll nicht :(.
Wobei bekommst du den einen Error?
CM9 installieren? Im Updater Script steht bestimmt P6200 drin, darum geht das nicht...ich schau mir das mal morgen an.
Sent from my GT-P6211 using Tapatalk 2 Beta-5
Ne also root hab ich aber bekomme das cwmr nicht installiert da bricht der dann ab mit error scribt Fehler.
Nja nicht so schlimm eilt ja auch nicht so. Sind ja noch zu viele Fehler drin.
Dank dir aber.
Im Updater Script stand P6200 drin, deswegen ging es nicht. Hab aus dem P6200 -> P6201 gemacht. Habe es aber selbst nicht getestet.
Wichtig: Sei dir im klaren, das es dein Tablet zerstören kann, falls es nicht geht.
  • CWM-P6201.zip
Danke das geht........... jetzt jetzt brauch ich nur die originale fw für das tab ^^.
Ich teste das mal gut das ich das versichert hab das tab.
Edit test
Also CWM geht Backups und resote gehen.
Edit test
Backup und Restore geht? Hab in XDA nämlich gelesen das das nicht korrekt funktioniert. :thumbup:
Geht alles nur das die cm9 ne wifi only is schade.
Bin auch wider auf das Backup von der offiziellen Rom.
Geht alles wie wie mann das gewohnt is.
CM9 ist WiFi + 3G, darum ja auch nur für das P6200/P6201.
Danke für die Info. :thumbup:
Also bei mir war nur wifi.. Komisch nacher noch mal testen
Muss ich außer der Rom noch was runterladen?
baerchen
baerchen
firefox1970
  • firefox1970
firefox1970
firefox1970
NewTab
