OpenVPN will nicht starten
  • 3 Antworten
warp2
ich habe soweit ich sehen kann, das OpenVPN soweit auf mein htc desire z bekommen.
Nur starten will es offenbar nicht.
So sieht das Log aus:
Code:
 D/OpenVPN-Settings( 1877): onResume()
D/OpenVPNDaemonEnabler( 1877): Received OpenVPN daemon state changed from Unknown to Disabled
D/OpenVPNDaemonEnabler( 1877): Received OpenVPN network state changed from Connecting to Unknown
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): attach(): using management port at 45610
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): attaching to OpenVPN daemon: /[URL="http://127.0.0.1:45610/"]127.0.0.1:45610[/URL] - Connection refused
W/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]( 1877): start(): choosing random port for management interface: 36740
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon( 1877): invoking external process: /system/bin/su
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon( 1877): invoking command line: modprobe 'tun'
D/su      ( 2216): 10092 de.schaeuffelhut.android.openvpn executing 0 /system/bin/sh
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stderr( 1877): modprobe: chdir(/lib/modules): No such file or directory
I/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): terminated
I/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stderr( 1877): terminated
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon( 1877): invoking command line: /system/xbin/openvpn --cd '/sdcard/openvpn' --config 'bridgecert.ovpn' --writepid '/data/data/de.schaeuffelhut.android.openvpn/files/com.d/_sdcard_openvpn_bridgecert.ovpn-pid' --script-security 1 --management 127.0.0.1 36740 --management-query-passwords
D/OpenVPNDaemonEnabler( 1877): Received OpenVPN daemon state changed from Unknown to Startup
D/su      ( 2222): 10092 de.schaeuffelhut.android.openvpn executing 0 /system/bin/sh
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 OpenVPN 2.1.1 i686-pc-linux-gnu [SSL] [LZO2] [EPOLL] built on Feb  2 2010
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 MANAGEMENT: TCP Socket listening on [URL="http://127.0.0.1:36740/"]127.0.0.1:36740[/URL]
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 WARNING: file 'client01.key' is group or others accessible
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): started
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): attach(): using management port at 36740
V/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): Successfully attached to OpenVPN monitor port
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 WARNING: file 'key' is group or others accessible
D/OpenVPNDaemonEnabler( 1877): Received OpenVPN daemon state changed from Unknown to Enabled
V/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): Socket IO established
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 Control Channel Authentication: using 'key' as a OpenVPN static key file
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:31 2011 Control Channel MTU parms [ L:1591 D:168 EF:68 EB:0 ET:0 EL:0 ]
D/OpenVPNDaemonEnabler( 1877): Received OpenVPN network state changed from Unknown to Connecting
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:32 2011 Note: Cannot open TUN/TAP dev /dev/tun: No such file or directory (errno=2)
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:32 2011 Note: Attempting fallback to kernel 2.2 TUN/TAP interface
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:32 2011 Cannot allocate TUN/TAP dev dynamically
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-daemon-stdout( 1877): Wed Jan 12 14:55:32 2011 Exiting
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): Lost connection to OpenVPN daemon
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): java.net.SocketException: Connection reset by peer
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at org.apache.harmony.luni.platform.OSNetworkSystem.readSocketImpl(Native Method)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at org.apache.harmony.luni.platform.OSNetworkSystem.read(OSNetworkSystem.java:358)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at org.apache.harmony.luni.net.PlainSocketImpl.read(PlainSocketImpl.java:561)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at org.apache.harmony.luni.net.SocketInputStream.read(SocketInputStream.java:88)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at java.io.InputStreamReader.read(InputStreamReader.java:275)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at java.io.BufferedReader.fillBuf(BufferedReader.java:182)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at java.io.BufferedReader.read(BufferedReader.java:261)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at java.io.LineNumberReader.read(LineNumberReader.java:117)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at de.schaeuffelhut.android.openvpn.service.ManagementThread.block(DaemonMonitor.java:468)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at de.schaeuffelhut.android.openvpn.service.ManagementThread.monitor(DaemonMonitor.java:438)
E/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): at de.schaeuffelhut.android.openvpn.service.ManagementThread.run(DaemonMonitor.java:363)
D/OpenVPN-DaemonMonitor[/sdcard/openvpn/bridgecert.ovpn]-mgmt( 1877): terminated
D/OpenVPN-Settings( 1877): onPause()
Ich habe die config vorher bereits auf einer xp-Maschine getestet. D.h. ich habe die Config voher getestet. Das Ergebnis war erfolgreich, so dass eine Verbindung aufgebaut worden ist.
Was läuft hier auf dem Desire schief?
Falsches Unterforum, hier ist das Desire-Forum. Hier wärst du richtig gewesen.
Spiele ein hoffentlich vor dem Kernel-Update angelegtes nandroid-Backup wieder zurück zurück. Wenn du dummerweise kein Backup gemacht hast, hilft nur, ein ROM neu zu flashen, dabei gehen natürlich die installierten Apps verloren.
Hallo Zipfelkklatscher. Das urpsüngliche Problem konnte ich so beheben, wie du es gesagt hast. So dass ich gleich dass Openvpn-Problem hier rein gepostet habe. Das ist noch aktuell.
Könnte es daran liegen, dass das tun device fehlt? Wenn dem so ist, wie kann ich das auf einem desire z "einbringen"?
