1. Hast Du Lust, bei uns mitzuarbeiten und das AH-Team zu verstärken? Alle Details zu dieser aktuellen Herausforderung findest Du hier.
  1. dawkon13, 09.07.2012 #1
    dawkon13
    dawkon13 Threadstarter Android-Hilfe.de Mitglied
    [​IMG]
    SlimDroid v 7.20
    BEFORE FLASH MAKE BACKUP (SD 7.20 HAVE FORMAT SCRIPT!!!)!!!
    INSTALL VIA STOCK RECOVERY!!!
    CWM= [​IMG]:p
    STOCK RECOVERY (INSTALL VIA CWM) FOR:
    GB:
    http://sdrv.ms/P2XX8S
    ICS: http://a1.cu2.at/A1_ICS_Stock_Recovery.zip
    Changelog:
    -based on latest firmware (014)
    -fixed compilation number (013->014)
    -re-partition script
    -new partition table (anddior- thanks :D ):
    [​IMG]
    1.System
    2.cache
    3.Storage (for apps)
    4..secure
    5.Internal storage
    -bugfree :D
    -removed apps (google books, google videos,...)
    SDcard not working= install SDcard fix! :)
    Download (no mirrors!!!)
    SlimDroid v7.20
    Rootfiles:
    A1_rooter.zip
  2. anddior, 09.07.2012 #2
    anddior
    anddior Android-Lexikon
    Why you think that otg would work?
    I dont beleave that otg will ever work on cable select.
    If you schort otg Pin to ground there will be no reaction at all in Kernel on Pin read function.
    So this could be an Hardware issue and not Software.
  3. dawkon13, 09.07.2012 #3
    dawkon13
    I don't know if it works- it's other kernel- this it's JUST suggestion :cool2:
    Hardware problem = :( :( :( :( :( :( and bye bye Lenovo :p
    Software problem = Maybe works :)
    Der ursprüngliche Beitrag von 18:07 Uhr wurde um 18:34 Uhr ergänzt:
    Update- v5.0 :D
  4. anddior, 09.07.2012 #4
    anddior
    did you made some changes to A1_Rooter or why did you Post a mirrow / your Version?
  5. dawkon13, 09.07.2012 #5
    dawkon13
    sometimes I wanted to download the file it was error:
  6. anddior, 09.07.2012 #6
    anddior
    Why dont deliver your ROM as Rooted?
  7. dawkon13, 09.07.2012 #7
    dawkon13
    I'm trying but not "read" root
    SU and BusyBox isn't installed :(
    I will try something next time :)
  8. anddior, 09.07.2012 #8
    anddior
    Just copy those 3 Files like i do in A1_Rooter
  9. dawkon13, 10.07.2012 #9
    dawkon13
    Neue versionen :)
    @anddior
    I tried copy su.apk,su,busybox but no root :(
    v5.1 it's with rootpack :)
  10. stefek, 20.07.2012 #10
    stefek
    stefek Neuer Benutzer
    Hallo erstmal
    Nach viel stöbern im Forum möchte ich mich auch mal zu Wort melden.
    Vielleicht bekomm ich ja nen Tip....
    SlimDroid 5.1 gefällt mir schon mal einiges besser, als das "...091" von Lenovo, da das Wlan überhaupt keine Probleme macht.
    Finds nur schade, daß keine Livewallpaper mehr wählbar sind.
    Mit der "wp clock 2" aus dem market sah das Tab echt viel nobler aus ;)
    Habe schon versucht die benötigten Dateien (livewallpapers.apk+.odex sowie livewallpaperspicker.apk+.odex) aus dem Lenovo-Rom in die Slimdroid-Rom einzufügen.
    Ohne Erfolg....:(
    Das Gerät hängt in der Bootschleife fest.
    Hat einer ne Lösung parat?
    Zum laufen bekomme ich es ja ohne Probleme über den CWM.
    Nur mein geändertes Rom nervt.... Keine Ahnung, was ich falsch gemacht habe
    Über Hilfe wäre ich sehr dankbar :D
    PS: Habe gelesen, daß ich das geänderte Rom signieren müsse. Hat mir allerdings nicht weitergeholfen
  11. dawkon13, 23.07.2012 #11
    dawkon13
    SlimDroid v7.20 it's available :D
  12. dawkon13, 24.07.2012 #12
    dawkon13
    Re-upload 7.20 version :)
