1. Hast Du Lust, bei uns mitzuarbeiten und das AH-Team zu verstärken? Alle Details zu dieser aktuellen Herausforderung findest Du hier.
  1. mimm.m, 22.06.2011 #1
    mimm.m
    mimm.m Threadstarter Android-Experte
    Project Utopia by Miroslav_mm
    CyanogenMod 6 Froyo 2.2.1
    Original_Thread_4PDA
    Screenshot:
    Was funktioniert:
    • GSM, MMS, APN
    • Bluetooth
    • Sensors (accelerometer);
    • Camera (records in MP4 (1.5Mbs, 640 * 480))
    • SD, reads a partitioned card
    • USB
    • GPS
    • Wi-Fi
    • Wired headset
    • Second Line (What's this?)
    • Network selection
    • Radio
    • Screen calibration
    • Video codecs (hardware only H263)
    • 3D
    • Rebooting in Recovery menu
    • Kernel with all the buns (ext3/ext4, netfilter / iptables / cifs / tun /, itd.itp.)
    • Overclocking (up to 1000 MHz. Please note, if you have a phone. unstable even at 825 works, do not try to overclock up to 1000! Added support for the lucky who works steadily at 900!)
    Added Apps:
    QQPlayer, DroidWall, MyPhoneExplorer, SmartKeyboard (+ dictionaries en / rus / ukr), SystemAppRemover, Fancy Widget, Select screen Widgets messages and notes, LauncherProPlus, Calibration, Glossary, Terminal.
    Funktioniert nicht:
    • Bluetooth headset
    • DivX / Xvid (use QQ Player)
    • Native USB and WiFi tethering
    • Pcsuite (use MyPhoneExplorer instead)
    • The penultimate position of the volume (during a call) is not working (HZ libaudio citation needed)
    • Vibrootklik soft keys (menu, back)
    • If after flashing the battery holds a little something to do calibrate the battery
    Download:
    Fastboot:Fastboot_non_Mirror | Fastboot_Mirror
    Recovery: 2011-06-21.13.11.12.zip | http://api.viglink.com/api/click?fo...xt=http://depositfiles.com/ru/files/mi59stb14 - Mirror
    TO SUPPORT MIROSLAV_MM, PLEASE DOWNLOAD FROM THE ORIGINAL LINK, NOT FROM ANY OTHER MIRRORS
    Die angefügten Links sind keine Drittanbierter Mirrors sondern einfach von Miroslav_mm erstellte, da er so viele downloads hatte.
    Donate Miroslav_mm
    Z385011021297
    R105928067702
    E355930075366
    U267621943817
  2. theares2014, 22.06.2011 #2
    theares2014
    theares2014 Fortgeschrittenes Mitglied
    So, was soll ich zu dieser Rom sagen, außer dass ich begeistert bin.
    Endlich eine gute, mir gefallende 2.2 Rom.
    Bis jetzt kann ich mich nur über die russischen Links beschweren... Des weiteren sind mir noch keine großen Kritikpunkte aufgefallen, bis auf zwei (kaum nennenswerte) kleine Sachen, wie etwa dass LauncherPro installiert ist oder anders gesagt, der klassische Launcher noch installiert ist. Des Weiteren mag ich Smartkeyboard Pro nicht, da trotz guter Kalibrierung tippen zur Glückssache wird. Geschwindigkeit, Aussehen und Batterielaufzeit (muss noch Kalibrieren) gehen gut in Ordnung...
    Will be edited...
    mimm.m der Fastboot Mirror ist kaputt, da ich die Datei gelöscht habe, weil miroslav es nicht wollt :/
    mimm.m gefällt das.
  3. email.filtering, 22.06.2011 #3
    email.filtering
    email.filtering Gast
    Eigentlich mag ich ja Leute mit vielen Ms im Namen, wie unseren mi..mm, aber bei diesem "Miroslav mm" wäre mir echt lieber, der würde mit Lego-Bausteinen spielen, statt ständig an Betriebssystemen herummodden. Bekommt nichts gescheit auf die Reihe, aber jedesmal feste von vorne anfangen ... :sneaky:
  4. Braver, 25.06.2011 #4
    Braver
    Braver Neuer Benutzer
    Bekomme bei dem ROM keine WLAN Verbindung.
    Meldung: Scan konnt nicht durchgeführt werden. Danach
    stirbt ein Prozess ab.
  5. theares2014, 25.06.2011 #5
    theares2014
    Das habe ich nicht... probiers mal mit einem Neustart oder einem Wipe.
  6. Braver, 25.06.2011 #6
    Braver
    Bin Neu. Was ist ein Wipe.
    -> Werkseinstellungen?
  7. mimm.m, 25.06.2011 #7
    mimm.m
    eig schon ... mach bei recovery einen factory wipe -> werkseinstellungen
    Braver gefällt das.
  8. Braver, 25.06.2011 #8
    Braver
    Jupp, rennt nun.
    Danke
