[Anleitung] Zurück zum Standard ROM - [Eternity Project]
TheProdigy
TheProdigy
Enthusiast
1.626
Hab hier eine ganz gut beschriebene Anleitung gefunden...für die, die in einer Bootloop etc. hängen und wieder zurück aufs Stock-ROM wollen.
sevenup30 schrieb:
Hi everybody,
first of all, i dont create anything i just see every day new user unable to flash fastbootfile because they dont know how to.
This will work on GSM EU devices, dont know for the other.
All the credit are for The Eternity Project Team.
I flash a bad OTA/ROM/ Want to went back/ bootloop etc... And i don't know how to do that :(
Ok ok, don't worry, take a deep breath and follow this tutorial.
STEP 1
-You need to download the AlternateFlashScript(from eternity project) attached below.
-You also need the right fastboot file: you can find it here
For GSM EU user i recommand you this one
STEP 2
-You need to extract the fastboot file and the script in the same directory (VERY IMPORTANT)
STEP 3
-boot your RAZR into fastboot mode
a) Hold down Power and vol- button for 10sec
b) Hold down power and vol-/vol+ button
c) When you have a black screen with white inscription on it, navigate with vol- to "AP fastboot" and select with vol+
STEP 4
-run the script, for windows just double click
-For linux you have few more steps
a) open terminal
b) enter those line
Code:
cd /yourdirectory/fastbootfile/
sudo chmod a+x FlashItLinux.sh
./FlashItLinux.sh
-Just wait. it take easily to 10mn or more, once the script is over your phone reboot
STEP 5
Your phone should reboot into recovery (black screen with a bugdroid)
-press vol-/vol+ button
-navigate to "Reboot" with volume button and select with power button
Now you're phone should reboot(let it 10mn to first boot) and you're now back to 73.30 with android 2.3.5
Credits:
Source
Downloadlinks im Originalthread: [HOW TO] back to stock rom with Eternity project Script - xda-developers
Wenn euer Akku leer ist braucht ihr ein Factory Kabel
Anleitung gibts hier: [GSM/CDMA] How to flash a via RSD when you read "Cannot program" or "Battery LOW" - xda-developers
Viel Spaß :winki:
Reaktionen: HFT
~db~
tubser
  • -Allrounder
Nockz
