Chris123456
Bedankt euch nicht bei mir, sondern bei arco68 im Originalthread!!
XDA-Originalthread von Arco
Installieren könnt ihr es über diese Anleitung von THE-E.
Was funktioniert:
Audio
Anrufe empfangen und tätigen
GPS
Kompass
Annäherungssensor
WLAN
Bluetooth
USB mass storage
HW accelerated gui
HW accelerated video
Kamera
Taschenlampe
Wifi/USB tethering
USB OTG
Vsync
Hybrid ION/PMEM
Ärgerliches:
Movie Studio ist unstabil und wird beendet oder kann das Handy einfrieren
Screenshots:
-> im Anhang
Download:
- 2014-01-10: CM-11.0 20140109-UNOFFICIAL [DOWNLOAD] [MIRROR]
MD5SUM: 5688ddd7efccbfdf3d485804543fe8b3
- Enable TARGET_USE_QCOM_BIONIC_OPTIMIZATION
- Possible workaround for the graphic glitch
- Updated media profiles
- Increased minimum CPU frequency to 368 MHz
- Lowered zRAM size to half of what it was
- Kernel 3.4.76
- 2014-01-06: CM-11.0 20140106-UNOFFICIAL [DOWNLOAD]
MD5SUM: 588e8977250194cb3bd8bedfc6e29c8c
- Fixed storage swapping
- 2014-01-05: CM-11.0 20140105-UNOFFICIAL [DOWNLOAD]
MD5SUM: c577b62973aac5099bdea60b20e3073d
- Fixed bluetooth tethering
- Implemented storage switching
- Increased zRAM allocation and changed setup according to KK specs (old method is removed from CM11)
- 2014-01-01: CM-11.0 20140101-UNOFFICIAL [DOWNLOAD]
MD5SUM: 57e225a2955e15236c37abb00072ee9d
- Switched back to updated camera app (fixed issue with preview)
- Allocated more memory for PMEM (should fix issues like switching to video mode in camera app after taking pictures)
- 2013-12-31: CM-11.0 20131231-UNOFFICIAL [DOWNLOAD]
MD5SUM: 26910b9933dce0ff01137f278c6b49d7
- Fixed activity indicators for mobile data
- Fixed preview in camera after taking a picture
- Enabled ZRAM by default
- 2013-12-28: CM-11.0 20131228-UNOFFICIAL [DOWNLOAD]
MD5SUM: 9f2c2aae9fa3143c69537e7f67b51ac1
- Initial release
- Beim Upgrade ebenfalls wichtig:
- gapps version 20131208 (Not ART compatible)
MD5SUM: a387243442413f0a9153ab1bad149199
Für mögliche Fehler oder Verluste trage ich keinerlei Verantwortung. Alles auf euer eigenes Risiko!
