markus75
Stammgast
- 105
da ich apps2sd selbst nicht nutze, kann ich dir nur sagen was ich so gelesen habe :
wenn du nur LeshaK´s neuen Kernel Spica v.LK2.02 - Root, Recovery, Apps2SD, Busybox, Wifi tether etc [04/15/2010] [EN] oben hast, und die sd mit 2 partitionen formatierst, sollten deine apps beim ersten reboot automatisch auf die sd wandern.
beim samdroid mod [Mod] SamdroidMod v 1.0.3 - LK2.03.3 + Root + more... [05/06/2010] [EN] ist apps2sd standardmäßig deaktiviert, nach dem partitionieren und beim ersten reboot sollte nichts passieren.
siehe :
--- apps2sd is disabled by default, even if you have second partition (turn on via SamdroidTools)
--- apps2sd moves dalvik-cache to SD, freeing internal memory, decreasing performance, but not significantly. (turn on via SamdroidTools, description below)
Backup/Restore
Ability to make a backup of user's programs to SD /data/app & /data/app-private -> /sdcard/samdroidtools/app,app-private and then restore them back, you can use it for disabling Apps2sd, i.e. backup first, then disable apps2sd, reboot, then restore and reboot.
apps2sd controls:
SD card shows, how many free is space available at SD card for programs (2nd partition)
Internal storage make a copy of information from Settings, and shows how many free space available at i5700 internal memory.
Apps2sd settings controls only of apps2sd enabling, or + moving of dalvik-cache.
And I want to show amount of internal memory with:
1. apps2sd is disabled 2. apps2sd is enabled 3. additionally dalvik-cache is moved to SD
siehe :
Backup/Restore
apps2sd controls:
