1. xn0live, 06.05.2012 #1
    xn0live
    xn0live Threadstarter Ambitioniertes Mitglied
    Hi, Leute
    --- Wollte heute mein Xperia Ray Rooten ---
    Easy rooting toolkit (v4.0)
    created by DooMLoRD
    using exploit zergRush (Revolutionary Team)
    Credits go to all those involved in making this possible!
    [*] This script will:
    (1) root ur device using latest zergRush exploit (21 Nov)
    (2) install Busybox (1.18.4)
    (3) install SU files (binary: 3.0.3 and apk: 3.0.6)
    (4) some checks for free space, tmp directory
    (will remove Google Maps if required)
    [*] Before u begin:
    (1) make sure u have installed adb drivers for ur device
    (2) enable "USB DEBUGGING"
    from (Menu\Settings\Applications\Development)
    (3) enable "UNKNOWN SOURCES"
    from (Menu\Settings\Applications)
    (4) [OPTIONAL] increase screen timeout to 10 minutes
    (5) connect USB cable to PHONE and then connect to PC
    (6) skip "PC Companion Software" prompt on device
    CONFIRM ALL THE ABOVE THEN
    Drücken Sie eine beliebige Taste . . .
    --- STARTING ----
    --- WAITING FOR DEVICE
    * daemon not running. starting it now *
    * daemon started successfully *
    --- creating temporary directory
    mkdir failed for tmp, File exists
    --- cleaning
    rm failed for *, No such file or directory
    --- pushing zergRush
    cannot open 'files\zergRush': No such file or directory
    --- correcting permissions
    --- executing zergRush
    --- WAITING FOR DEVICE TO RECONNECT
    if it gets stuck over here for a long time then try:
    disconnect usb cable and reconnect it
    toggle "USB DEBUGGING" (first disable it then enable it)
    --- DEVICE FOUND
    --- pushing busybox
    550 KB/s (1075144 bytes in 1.906s)
    --- remounting /system
    mount: permission denied (are you root?)
    --- checking free space on /system
    27 KB/s (439 bytes in 0.015s)
    --- Free space on /system : 175816 bytes
    --- no cleanup required
    --- copying busybox to /system/xbin/
    /system/xbin/busybox: cannot open for write: Read-only file system
    --- correcting ownership
    Unable to chmod /system/xbin/busybox: No such file or directory
    --- installing busybox
    /system/xbin/busybox: not found
    --- pushing SU binary
    failed to copy 'files\su' to '/system/bin/su': Read-only file system
    Unable to chmod /system/bin/su: No such file or directory
    --- correcting symlinks
    rm failed for /system/xbin/su, Read-only file system
    link failed Read-only file system
    --- pushing Superuser app
    failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only
    file system
    --- cleaning
    --- rebooting
    ALL DONE!!!
    Laut beschreibung steht da nun !ALL DONE! aber wenn ich einige Rootprogramme starte steht da immer NO ROOT
    Hab ich etwas falsch gemacht?
  2. statler, 06.05.2012 #2
    statler
    statler Lexikon
    hast du vielleicht die .62 od. .69 Firmware ?
  3. xn0live, 06.05.2012 #3
    xn0live
    hab die 42.firmware also android 2.3.4 (habe grad unter telefoninfo nachgeguckt)
  4. statler, 06.05.2012 #4
    statler
    statler Lexikon
    versuche es mit dem Flash tool zu rooten.
    (Schloss Butten)
  5. xn0live, 06.05.2012 #5
    xn0live
    gibs hier ne anletiung da ich ein anfäner im gebiet rooten bin :D
  6. statler, 06.05.2012 #6
    statler
    statler Lexikon
    mit ein bisschen suchen findet man das hier an Board.
    bisschen runter scrollen.
  7. xn0live, 06.05.2012 #7
    xn0live
    mit dem Flashtool funzt es auch nicht:
    06/047/2012 20:47:53 - INFO - <- This level is successfully initialized
    06/047/2012 20:47:54 - INFO - Flashtool Version 0.7.0.0 built on 2012-04-14 11:34:01
    06/047/2012 20:47:54 - INFO - You can drag and drop ftf files here to start flashing them
    06/048/2012 20:48:02 - ERROR -
    06/048/2012 20:48:06 - INFO - Device connected with USB debugging on
    06/048/2012 20:48:09 - INFO - Connected device : ST18
    06/048/2012 20:48:09 - INFO - Installed version of busybox : N/A
    06/048/2012 20:48:09 - INFO - Android version : 2.3.4 / kernel version : 2.6.32.9-perf
    06/048/2012 20:48:21 - INFO - Pushing C:\Flashtool\.\devices\ST18\busybox\1.19.0\busybox to /data/local/tmp/busybox
    06/048/2012 20:48:24 - INFO - Pushing C:\Flashtool\.\custom\root\psneuter.tar.uue to /data/local/tmp
    06/048/2012 20:48:28 - INFO - Running part1 of Root Exploit, please wait
    06/048/2012 20:48:28 - INFO - Running rootit
    06/048/2012 20:48:30 - INFO - Waiting for device
    06/049/2012 20:49:32 - INFO - Forced stop waiting.
    06/049/2012 20:49:32 - INFO - Running part2 of Root Exploit
    06/049/2012 20:49:33 - INFO - Running rootit2
    06/049/2012 20:49:33 - ERROR - Cleaning rootit files
    Mounting /system R/W
    FTError
  8. kuemmeltuerk, 06.05.2012 #8
    kuemmeltuerk
    kuemmeltuerk Experte
    genau an die anleitung gehalten?
    USB Debugging an, unbekannte Herkunft erlaubt?
  9. statler, 06.05.2012 #9
    statler
    statler Lexikon
    stöpsel mal an und warte bis es vom pc erkannt wird.
    überprüfe den USB Verbindungsmodus.
    MTP und MSC brauchst du glaub ich.
  10. xn0live, 06.05.2012 #10
    xn0live
    kuemmeltuerk@ jap bei beiden ist ein haken
    statler@ Ich kann nur ein von beiden anklicken, also MTP oder MSC?
  11. statler, 07.05.2012 #11
    statler
    statler Lexikon
    ja, es geht immer nur einer
  12. xn0live, 07.05.2012 #12
    xn0live
    habe es mit beiden versucht aber funzt immernoch nicht
  13. statler, 07.05.2012 #13
    statler
    statler Lexikon
    für es mal mit ADMI rechte aus
    ggf deaktiviere mal dan Antivi. Programm
  14. DaHandy, 10.05.2012 #14
    DaHandy
    DaHandy Neues Mitglied
    Du hast keine verbindung war bei mir auch so
  15. id.goPLAY, 22.05.2012 #15
    id.goPLAY
    id.goPLAY Erfahrenes Mitglied
    Habe das problem auch... gibt's eine loesung? Danke
    PS: Bin neu mit Xperia Ray
Du betrachtest das Thema "Fehler beim Rooten" im Forum "Root / Hacking / Modding für Sony Ericsson Xperia Ray",
  1. Android-Hilfe.de verwendet Cookies um Inhalte zu personalisieren und dir den bestmöglichen Service zu gewährleisten. Wenn du auf der Seite weitersurfst stimmst du der Cookie-Nutzung zu.  Ich stimme zu.
