Doomkernel v6.1 + full touch recovery - nur für unlocked Bootloader! 25/03/2012
Q
quercus
Gast
Quelle: XDA
DOOMKERNEL V6.1!!! (V6 + FULL TOUCH RECOVERY) (all credits to doom, i only compiled) i put doomlord's full touch recovery into v6 doomlord (for unlocked bootloader
full touch means.. yes full touch...not just on screen buttons
[ANDROID] Team UtterChaos CWM Based Full Touch Recovery (work in progress, test device: Xperia Play) - YouTube
[ features ]
  1. Honeycomb themed FULL Touch interface
  2. swipe gesture support!!! - the hotspot for this is across full screen
    • swipe left to GO BACK/ Scroll UP
    • swipe right to Scroll Down
  3. paging support when there is too much text to be displayed on screen (e.g. when browsing folders)
  4. haptic feedback - when u touch screen the device will vibrate little bit
  5. shows current time (time when the recovery was entered/started)
  6. uses new Roboto FONT (from latest CWM repo)
  7. new "select update.zip menu": it will give u a new option - "show file details" - which will display the size (in bytes) and the MD5SUM of the selected file
  8. added prompt to display the "backup folder name" when user starts restoring a backup
  9. added a warning and option to abort backup if space on sdcard is < 150 MB
  10. current battery level/percentage displayed (based on amit.bagaria implementations for his CF-Root kernel for SGS-SL)
  11. removed Wipe cache partition from main menu (u can format /cache from "Mounts & Storage" menu)
  12. moved "Power Off" under "reboot options" menu
  13. changed text of most menus to fit the new honeycomb inspired design
  14. the Nandroid backups & restore now show/displays which files were used to restore/what the backup is called (folder name)
  15. added "advanced backup" menu (based on amit.bagaria implementations for his CF-Root kernel for SGS-SL)
    • now u can selectively choose which partitions to backup
    • its like a toggle
    • once u have finished choosing which partitions u want just click on "perform backup" and only those partitions will be backed up!!!
  16. when any update.zip is selected its complete file name will now be displayed (right at the top) before flashing begins
  17. along with most other features of my older modCWM recovery
[ requirements ]
  1. UNLOCKED BOOTLOADER
  2. new 2.3.3 GB firmware
  3. ROMs based on 2.3.3 SE firmware
  4. Flashtool
it contains this recovery
http://forum.xda-developers.com/show....php?t=1561554
i'm too excited to write intro here
file uploading
this is full oc (and i have tested it to work)
http://hotfile.com/dl/150193496/1ec2...ERNEL.ftf.html
or mirror
https://rapidshare.com/files/325395310/CHAMPKERNEL.ftf
this is half oc version
http://hotfile.com/dl/150195051/1791...alfoc.ftf.html
and mirror
https://rapidshare.com/files/2367675...nel-halfoc.ftf
oh and finally the fs version
http://hotfile.com/dl/150196007/00c6...el-fs.ftf.html
and mirror
https://rapidshare.com/files/1772403...pkernel-fs.ftf
please test!!!!
update : all tested..all running nice
use wifi modules from here
http://forum.xda-developers.com/show...postcount=1356
Q
quercus
Q
  • Handy61
Handy61
Q
quercus
Q
