High Performance SE replacement ROM (XDA)
Q
quercus
Gast
für die Freunde die sich gerne mal wieder mit nem Flash bereichern wollen, folgender Beitrag, gefunden bei Xda:
[ROM] kX10 - High performance SE replacement ROM - xda-developers
mfg Quercus
ps
sorry für die Formatierung (Breite)
kX10 Custom SE ROM
Disclaimer: Please be aware that any time you flash a custom ROM, you are modifying system files that are required for your phone to operate correctly. Use this (and any other) ROM at your own risk. I am not responsible for bricking your phone, voiding your warrenty, or male pattern baldness. Thanks.
Introduction
This is a modified and optimized version of the stock 2.1 Generic 2.0.2.A.0.24 Sony-Ericsson ROM. This is intended to give everyone dev-level performance out of the box, and give themers and modders a base ROM to start with.
You need to be running a 2.1 2.0.2.A.0.24 ROM already BEFORE flashing this ROM. If you aren't, see this thread first: http://forum.xda-developers.com/showthread.php?t=885956
PLEASE MAKE REQUESTS. I want this to be the ROM SE should have made.
*Note that you cannot TYPE Emoji with this ROM, it only displays Emoji sent from an iPhone.
Credits
A huge thanks to:
zdzihu for xRecovery, JIT enabler v2, and rooting the Generic 2.0.2.A.0.24 firmware; and
MrRusch for framework-res work
svtfmook for help with system apps
Modifications
  • 2.1 Generic Firmware (2.0.2.A.024), Rooted with xRecovery, JIT v2, SuperUser, and busybox installed;
  • SuperCircle Battery / Reboot option mod;
  • Nexus S boot animation;
  • Ubuntu system fonts with Emoji support (display only)
  • All APKs zipaligned / All non-essential system APKs moved to /data/app for easy uninstall and apps2sd support
build.prop Modifications
  • windowsmgr.max_events_per_sec=220 - Makes scrolling smoother
  • wifi.supplicant_scan_interval=180 - Slows down the WiFi scan to every 3 minutes, saves battery
  • dalvik.vm.heapsize=26m - Optimal heapsize for most X10s
  • mot.proximity.delay=150 - Makes the screen off/on proximity sensor more responsive
Removed
Timescape, Playnow, CrashSMS, Backup and Restore, Chinese / Japanese / Korean IMEs, EManual / userguide, Moxiermail, SE PC Companion, SEMCHomeL, WisePiolot, Quadrapop, OMAClientProvisioning, qcsemcservice, SemcCheckin, SnsContactImageCacheProvider, uWlopProvider
Pre-Installed APKs
*** I know this is a lot of apps, but these have all been zipaligned. If you use these apps, they will perform better than market versions. If not, delete them! **
LauncherPro, adbWireless, Adobe Reader, AndroZIP, Angry Birds, AppBrain, Barcode Scanner, Barnacle WiFi Tether, Battery Doctor, CamScanner, City Caller ID, Dialer One, Documents to Go, Dolphin Browser, drocap2, Dropbox, Facebook, Gallery3D, Google Goggles, Google Sky Map, Handcent, K-9 Mail, LinkPush, Linpack for Android, Neocore, No Lock, OI File Manager, Pandora, Quadrant Standard, Rage Faces, RWiimote, Shazam, ShootMe, Smart Keyboard Trial, SMS Backup+, Spare Parts, Stumble Upon, SwiFTP, Terminal Emulator, Titanium Backup, Video Player, Vlingo, Voice, Voice Dialer, Voice Search, Wallpaper Set & Save, WiFi Browser Login, Winamp, Work Email, XDA Developers App, Yelp, Zedge
Installation
  1. Be on a rooted 2.1 2.0.2.A.0.24 ROM
  2. Download ROM and place on your SD card
  3. Boot into xRecovery
  4. Do a factory reset (full wipe) and wipe Dalvik cache
  5. Flash the attached file with xRecovery by using "Install custom zip"
  6. Reboot and be patient. First boot can take several minutes at the boot animation. This is normal.
Check out this link after installation for tips on LauncherPro: http://androinica.com/2010/08/23/11-...f-launcherpro/
I recommend at least changing the opening Speeds to 10 (Prefrences > Advanced Settings > Opening speed). That makes the phone feel a lot more responsive.
Change Log
Release 1 Build 009 (Current)
- Added TrackID and Soundhound
- Updated Zedge
Full Change Log: http://inniscope.com/android/changelog.txt
Future Plans
- More optimization
- LauncherPro and SpareParts pre-configured
- app2sd version
Downloads:
R1B009 Full - 194.42MB - http://www.multiupload.com/P6ZYGN6AO3
R1B008 Lite - 116.42MB - http://www.multiupload.com/FF9U7NOJED - No 3rd Party APKs
Zipaligned APK Pack v3 - 120.30MB - http://www.multiupload.com/D1XYNGMECJ - All the APKs from R1B009 Full - NOT flashable
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
smokie.jo
  • smokie.jo
Ky Mani
  • Benyamin.S
Benyamin.S
