1. Hast Du Lust, bei uns mitzuarbeiten und das AH-Team zu verstärken? Alle Details zu dieser aktuellen Herausforderung findest Du hier.
  1. quercus, 07.01.2011 #1
    quercus
    quercus Threadstarter Gast
    Ich habs im Sony Blog gefunden - und es klappt tatsächlich.
    Allerdings scheint es abhängig von der Rom (Custom, usw) zu sein.
    Versucht mal Euer Glück
    QuellUrl: Xperia X10: Increase Head Phone Volume For X10
    mfg Quercus :smile:
    Here is a quick fix to increase the headphone volume on the X10, and this will work on other Android devices as well. So go to your market and install a application called "Louder Volume Hack", "hint google is your friend.
    After installing it press on the speaker and you will get the following screen.
    [​IMG]
    Note - Do not play anything and have headphones plugged in when doing this ​
    Now in order from top to bottom hit the circled buttons. After you press a button it will apply the mod to your phone and then on the bottom of your screen you will get a message saying "successfully applied to phone" or something. If you get a error message just try it again until you get the successfully applied message. Once you are done hit exit and you are done. ​
    I tried this method when I was on the bus to see if it works, and surprisingly it did. I noticed a significant increase in headphone volume. I am not sure about the head set volume thou. ​
    Zuletzt von einem Moderator bearbeitet: 07.01.2011
  2. UKSheep, 07.01.2011 #2
    UKSheep
    UKSheep Android-Lexikon
    "kuhl" wäre noch die Quell-URL :) Damit man sich auch das mal anschauen kann.
    MfG
    UKSheep
Du betrachtest das Thema "Increase Head Phone Volume x10" im Forum "Root / Hacking / Modding für Sony Ericsson Xperia X10",
