[Kernel][Wolf] 13/06/2011 FreeKernel mod3.50 - FPS uncapped, UV OC UC TIPP !!!
Q
quercus
Gast
Quelle: XDA
Autor: J,Z,Wolfbreak
Link: [Kernel][Wolf] 13/6 FreeKernel mod3.50 - FPS uncapped, UV OC UC!
[Kernel] 13/6 FreeKernel mod3.50 - FPS uncapped, UV OC UC!
All creds go to tkymgr, tsuyo.kou and hrsy96
From tkymgr: All ROM developers, feel free to use this in your own ROM.
Confirmed working with:
-Wolfbreaks TW CyanogenMod 6 006
-Wolfbreaks TW CyanogenMod 6 007 testmod
-Wolfbreaks v007 (TestMod) + DooMLoRD's Dualboot RDANNARS 2.1 ROM (Kernel works on both dual-booted ROMs)
-TripNRaVeRs CyanogenMod 6
-TripNMIUI 1.6
-Achotjan_Froyo_2.2.1 2.2
... Pretty much all 2.2 ROMs, and most 2.3 one's.
.. Feel free to try on other ROMs, and report back in this thread.
Guide on how to use:
1. You will need BB 52! (http://www.mediafire.com/?a4t6h1t6357xzl6)
2. If you do get signal with the above baseband on your ROM, skip this step.* Install Baseband patch: http://www.multiupload.com/U020F08R3N
3. Flash this kernel with xRecovery!
4. Enjooooy!
Specs:
-Call volume fix NEW!
-implemented netfilter (Droid wall, native USB/wifi tethering etc.)
-CIFS
-Undervolted
-Overclocked to 1.1 ghz
-Downclocked to 128MHz NEW!
-Swap on (automatic making root directory) NEW!
-remove swap area(but swap is available) NEW!
-FPS caps removed
-NetFilter&IpTables
-dm-crypt,dm-mod,twofish,twofish_common includes
Download link v 3.50-fix1 "FROYO":
http://www.megaupload.com/?d=9AN6O1QO
Download link v 3.50-fix1 "MIUI MOD":
http://www.mediafire.com/?c3u9168n067j0re
OLD!
Download link v 3.50 "MIUI MOD":
http://www.mediafire.com/?ndzkaanfpg3363p
OLD!
Download link v 3.50 "FROYO":
http://www.megaupload.com/?d=8LQKRNQZ
OLD!
Download link v 3.49:
http://www.megaupload.com/?d=42YUN32E
OLD!
Download link v 3.47:
http://www.mediafire.com/?ej9zjm9euj43j7l
Changelog in 3.50-fix1:
Camcorder bug fixed!
Changelog in 3.50:
Coming soon!
Changelog in 3.49:
128MHz CPU Clock removed. (Because it is unstable at the time of return)
64MB swap area
app2sd fixed
BACK TO STOCK KERNEL DL link:
This package does what the name says.
It gets you back onto stock kernel. You flash this in xRecovery!
FreeKernel Mod 3.50 SOURCE:
This is for developers only, dont try to flash this via xRecovery or something.
Der Download-Link in deinem Beitrag funktioniert nicht, quercus.
Und der Kernel funktioniert mit der FreeX10beta4 nicht (BB .52). Keine Chance mehr was zu machen. Darf neu machen die Firmware. :D
Thx, den Download hab ich jetzt als Anhang und was die Beta4 betrifft:
-TripNMIUI 1.5.6​
einfach in seinem Thread auf XDA darauf antworten - die oben genannten funktionieren, und für andere heisst es versuchen, wie er es eben beschrieben hat.
Gibt es irgendwelche negativen Sachen, die die neue BB mit sich bringt? bzw. die ältere? (hab 54)
gibt es ne anleitung, wie ich diese flashe?
läuft es damit merklich schneller?
und wie ist der akku verbrauch?
Was negatives wäre mir jetzt nicht aufgefallen - ausser die Arbeit - :).
Die Anleitung dafür steht im Post oben.
Das Ganze ist eher für erfahrene Anwender und Flash/Freaks die ein wenig Firm mit dem Kernel und dabei eventuell entstehenden Problemen sind.
Das Handy ist wesentlich schneller und flüßiger als zuvor. Kein Stocken bei längerer Betriebsdauer in div. Anwendungen. Der Batteriverbrauch bei gleicher Anwendung als vorher, ist wesentlich besser.
Das wars auch schon - ich beziehe mich hier auf die neue - die 3.49er!
  • rec0rdzz
rec0rdzz
  • rec0rdzz
rec0rdzz
Q
quercus
Q
