1. Hast Du Lust, bei uns mitzuarbeiten und das AH-Team zu verstärken? Alle Details zu dieser aktuellen Herausforderung findest Du hier.
  1. quercus, 19.02.2012 #1
    quercus
    quercus Threadstarter Gast
    Quelle: XDA
    [PORT] 2.3.4 Keyboard Working, ADDED FIX
    [PORT] 2.3.4.KEYBOARD WORKING!!!!!
    CREDIT TO _SMURF FOR STARTING THE IDEA FIRST
    I HAVE MANAGED TO PORT THE NEW KEYBOARD TO OUR BELOVED X10.
    HERE ARE THE FILE THAT NEED TO BE CHANGED AND ADDED.
    FOR REFERENCE ONLY
    2.3.4 KEYBOARD FILES.rar <------------- 1
    [MIRROR]
    !!!!!!!!!NEW!!!!!!!!!!
    FIXED PACKAGE
    FLASH VIA XRECOVERY
    [PORT] SWIPE 2.3.4 KB FIX.zip <-------------- 2
    !!!!!!BELOW!!!!!!
    FOR PEOPLE WHO HAVE FLASHED FACEBOOK 2.0 AND THEME MANAGER V2 AS YOU WILL HAVE THE UPXRES FRAMEWORK ALREADY
    FLASHABLE ZIPS. FLASH VIA XRECOVERY. ZIPS MADE BY DIKEJ. THANKS D
    KEYBOARD FILES
    Keyboard_2.3.4_X10.zip
    TEXTINPUT.TNG.APK (INSTALL USING ROOT EXPLORER OR ANY FILE MGR)
    textinput-tng.apk
    INSIDE THE RAR FILE YOU WILL SEE 4 FILES AND 1 FOLDER. THE FOLDER HAS THE NEW LAYOUT AND LANGUAGE FILES. THERE IS ALSO A PERMISSIONS XML AND A FRAMEWORK FILE.
    !!!!!!!!!DISCLAIMER. I AM IN NO WAY RESPONSIBLE IF ANYTHING IS TO HAPPEN. FOLLOW THE INSTRUCTIONS AS LAYED OUT. YOU KNOW THE RISKS!!!!!!!!!
    FOR REFERENCE ONLY
    FOLLOW THE EXACT INSTRUCTION.
    1. OPEN THE XT9 FOLDER AND COPY AND PASTE ALL THE FILES INSIDE TO /SYSTEM/USR/XT9/
    2. COPY AND PASTE THE FRAMEWORK (.JAR) TO /SYSTEM/FRAMEWORK/
    3. COPY AND PASTE THE PERMISSIONS FILE (.XML) TO /SYSTEM/ETC/PERMISSIONS/
    4. COPY AND PASTE THE XT9ENGINE.SO FILE TO /SYSTEM/LIBS/ IT WILL ASK YOU IF YOU WANT TO OVERWRITE THE EXISTING FILE, SELECT YES.
    5.REBOOT INTO XRECOVERY AND FIX PERMISSIONS.
    6. REBOOT AND THE INSTALL THE .APK PROVIDED.
    7. ENJOY.
    IF SOMEONE CAN MAKE A FLASHABLE ZIP AND PM ME THE LINK I WILL ADD TO THE OP AND GIVE YOU CREDIT.
    THANKS
    Here's the keyboard in black, Flash the one i op first, download here, <-------------- schwarzes Keyboard
    If u already have the one in op, just flash this over
    Zuletzt von einem Moderator bearbeitet: 19.02.2012
Benutzer fanden diese Seite durch die Suche nach:
  1. swype android 2.3
Du betrachtest das Thema "[MOD] 2.3.4 Keyboard mit Swype für Stock-Roms 19/02/2012" im Forum "Root / Hacking / Modding für Sony Ericsson Xperia X10",
