davidhellmann
Mal eine Frage rein aus interesse. Würde man das OSX auf dem G1 irgendwie zum laufen bekommen? Von was hängt das ab?
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
davidhellmann schrieb:Mal eine Frage rein aus interesse. Würde man das OSX auf dem G1 irgendwie zum laufen bekommen? Von was hängt das ab?
Autarkis schrieb:You would need further:
* exact type of processor: type, version, frequency
* exact type of GSM hardware, including version and subversion PLUS an appropriate radio flash or source therof or something making the Radio stuff work
* architecture of memory / flash
* chip and version of the USB subsystem: EHCI, OHCI or UHCI ?
* video chip: type, architecture, speed, version
* chip and version of the WiFi subsystem PLUS the orginal manufacturer's firmware
* sound chip: type, version - how does it interact with the GSM Radio subsystem?
... and so on, and so on. It would be nice to have a test cell tower simulator. But then, who would'nt like to have one?
Once you get this data (it's probably easiest to get an original schematic - from the manufacturer or from somewhere else), you can check each of the hardware components if they're supported in Android, if not, if they are supported in Linux. If not, you might be able to code them yourself.
Brace yourself. This will be a project using up about 1-5 man-years (and I'm talking about 5 days / wk, 8-hour days, not 1-3 evenings a week) depending on the amount of hardware support that already exists. Furthermore, it will be beyond a lot of peoples abilities (including mine) to assist you in any way. This is one hell of a tough job you're facing (barring the magical event that the phone accidentally is virtually a G1 clone. ).
I guess what I'm saying is: It's not worth the trouble. Once you've done all this, Android 5.0 will be running World of Warcraft II .
davidhellmann schrieb:So krass ist das? Wie gesagt, war rein interesse halber. Da es ja zum Beispiel bei Rechnern auch "relativ" einfach möglich ist. Das es so krass ist hätte ich nicht gedacht.
Autarkis schrieb:Ja unter "Rechnern"... aber nur unter PCs mit standardisierter Hardware!
Eine passendere Analogie wäre z.B. wenn du ein AS/400 Betriebssystem auf deinem Laptop installieren möchtest. Oder ein Cray-Betriebssystem auf deiner Game-Desktop-Kiste oder Linux auf deinem Nintendo Wii.
Bonko schrieb:
lustig, woher ist das?Lucas de Vil schrieb:Obwohl, 'wir haben einen Mann zum Mond und lebend wieder zurück zur Erde gebracht. Dieses Problem hier dürfte wesentlich schneller und weitaus günstiger zu lösen sein.'
