1. Hast Du Lust, bei uns mitzuarbeiten und das AH-Team zu verstärken? Alle Details zu dieser aktuellen Herausforderung findest Du hier.
  1. Technoolli, 29.07.2011 #1
    Technoolli
    Technoolli Threadstarter Erfahrener Benutzer
    [ROM][GB 2.3.5]GRP Present CyanogenMod 7.1.0 D/S [07/27/2011]
    [​IMG]
    UPDATE 07/27/2011
    USE CLOCKWORKMOD RECOVERY! OR YOU CAN SIGN IT! ILL FIX ON NEXT RELEASE.
    SUPPORTED SPL'S
    1.33.0013|1.33.2013|1.33.3013|1.33.0013d
    I WILL BE ADDING MORE SUPPORTED SPL'S SOON!
    FEATURES
    ~Android 2.3.5
    ~Apps2SD no Apps2SDEXT for that use the apps below!
    ~JIT on/off
    ~Surface dithering on/off
    ~Compcache Settings
    ~VM Heap Settings
    ~Swipe to clear Notifications
    ~SetCPU Settings
    ~Tablet Tweaks
    ~Slide status bar to adjust brightness
    ~Option to disable Wallpaper
    ~CyanogenMod extra rotation settings
    ~Built in Screenshot app. Hold in Power button for option
    ~And Many more....Flash to find out! Full changelog at the bottom of post.
    APPS2EXT APPS
    S2E (simple2ext) Will be included after i get a word back from developer.
    FreeSpace
    Use this for Sdext Info! Has a great widget.
    ROM, KERNEL AND GAPPS
    update-cm-7.1.0-RC1-DS-signed.zip MD5 SUM-4276b98983bdad17ca4821511574575c
    ezgb-2636-v1.5_S.zip MD5 SUM-00841def2178c96500d585eaa385c4ba
    Gapps-GB-20110613-signed.zip
    EXTRA
    New Android Market 3.0.26
    Gallery 2D
    INSTRUCTIONS FOR INSTALL
    1.Flash The ROM
    2.Flash alternate kernel if desired!
    3.Flash Gapps
    4.Reboot
    HOW TO PARTITION SDCARD FOR APPS2EXT
    OR USE ROM MANAGER
    ‪How to Partition Your SDCARD‬‏ - YouTube
    SOURCES
    https://github.com/CyanogenMod|ROM
    https://github.com/ezterry|Kernel
    CREDITS
    ~CyanogenMod for there awesomeness and all their work!
    ~Ezterry for the 2.6.36.4 kernel!
    ~Google for Open Source
    CHANGELOG
    Code:
    07/27/2011 ~Android 2.3.5 (Google) ~Bug fixes 07/22/2011 ~Android 2.3.4 (Google) ~Bluetooth mouse support - Scott Brady ~Improve notification swipe-to-clear - Evan Charlton ~Improve album-artist support in media scanner - Paul Crovella ~Profile improvements and bugfixes - Martin Long ~RTL text improvements - Eyad Aboulouz, Eran Mizrahi ~Wake on volume key option - Sven Dawitz ~Support for revoking application permissions - Plamen K. Kosseff ~Latest Superuser app - ChainsDD ~Control brightness by sliding on statusbar - Danesh M ~Add "copy all" to context menu - Danesh M ~Lockscreen haptic and statusbar indicators toggle - Danesh M ~Nicer timepicker/datepicker - Jiri Tyr ~Configuration 0/90/180/270 rotation - Jonas Larsson, Scott Brady ~DSP Manager bugfixes and improvements - Antti S Lankila ~Support for launching apps via gestures in the background - Jiri Tyr ~Option to hide hold button during call - Roberto Leinardi ~Allow using wildcards for call blacklisting - Nihanth Subramanya ~Option to allow in-call lockscreen to match main lockscren - Sven Dawitz ~Option to notify about incoming call only in background when screen is on - Pavel Kucera ~ADWLauncher- Transitions, catalog improvements, bugfixes - John Van Etten ~Optional GMT correction for SMS/MMS timestamps - Terry Hau ~Add FM Seek for TI devices - KalimochoAz ~Add FM support for SI4708 devices (Blade, V9, Racer) - Stéphane Konstantaropoulos ~Add FM seek implementation to FM application - Tom Giordano ~Show current FM status on lockscreen - Tom Giordano ~Camera touch-to-focus - cyanogen, arcee, m0viefreak, Danny Baumann ~Screenshot feature via power menu - arcee ~WEBP backport - Vikas Arora ~Add CM copyright noticies - arcee ~Skia/Zlib/libcore ARM optimizations - 0xlab ~Bluetooth tethering - Stéphane Konstantaropoulos
    Wie findet Ihr die neue Version ?
    Quelle: http://forum.xda-developers.com/showthread.php?t=1185027
    Zuletzt von einem Moderator bearbeitet: 17.06.2015
  2. DiSa, 29.07.2011 #2
    DiSa
    DiSa Android-Experte
  3. Rushness, 01.08.2011 #3
    Rushness
    Rushness Android-Experte
    Wäre schön wenn man die XDA-Threads nicht einfach nur hierrein kopiert sondern sie vielleicht auch noch ins deutsche übersetzt, wenn man sie schon kopieren MUSS...
  4. norbert, 01.08.2011 #4
    norbert
    norbert Ehrenmitglied
    oder wenigstens erkennbar ergänzt, das von XDA kopiert wurde :glare:
  5. Technoolli, 04.08.2011 #5
    Technoolli
    Sorry vegessen, so erledigt.
Du betrachtest das Thema "[ROM][CyanogenMod 7.1.0 DS][Android 2.3.5][Unofficial][07/27/2011]" im Forum "Root / Hacking / Modding für T-Mobile G1",
