Kino Joe
Stamm-User
- 134
[ROM] JACxHEROSkiv2.2- JAC/CC (JAC-SKI HTC KERNEL BFS-240) Dream/Mytouch 9/30/09
DOWNLOADS
JACxHEROSki-v2.2a
http://www.justanotherdev.slackdev.com
JACxHEROSki-v2.2b
WWARNING:You must Have The Correct Radio and Latest SPL! You can find them here (RADIO MUST BE INSTALLED FIRST) You can find it here
PLEASE DO YOUR RESEARCH BEFORE FLASHING ANY ROM INCLUDING MINE IT WILL SAVE YOU AND OTHERS TIME AND HEADACHE!!!
First A big thanks to Haykuro for providing the system dump of the latest known Hero build. Great contributions from Haykuro always!!! Make sure to thank him!!!
This ROM is based off the latest "HTC" ROM leak 2.83.x.x with tons of mods enjoy!!
DO NOT RUN ANY OTHER APPS2SD APPLICATIONS ON THIS BUILD. YOU WILL BREAK YOUR SYSTEM. THEY ARE NOT NECESSARY BECAUSE THIS ROM WILL DO A2SD AUTOMATICALLY AND BETTER!
NOTES:Swap is linux-swap by default. Edit the user.conf in /system/bin to change swappiness etc. Compcache modules built with the latest source are included if you want compcache or compcache with backing etc. Run sh /system/bin/swap -s to check swap status and other mod values.
JacHEROSki-v2.2 - Experimental A & B
-2.6.29.6-jac-ski root@DesertLake-Labs
-BFS 240
-supports MyTouch out of the box!
-MT
-various ramconsole and usb patches
-other things I can't think of
-same as A with the 10MB RAM hack (10 extra MB of RAM)
KNOWN ISSUES
-This ROM will auto-mount, so when flashing make sure it isn't plugged into your computer!
-People search still force closes.
DOWNLOADS
JACxHEROSki-v2.2a
JACxHEROSki-v2.2b
-BFS 240
-MT
KNOWN ISSUES
