[Rom] JesterBlur v1.1.5 10-20-09 (Experimental)
  • 5 Antworten
  • Neuester Beitrag
Diskutiere [Rom] JesterBlur v1.1.5 10-20-09 (Experimental) im Root / Hacking / Modding für T-Mobile G1 im Bereich T-Mobile G1 Forum.
PlaYOuT
PlaYOuT
Dauergast
Shout outs to my Homie Drizzy Drake Rogers!
also to MLIGN, Ma3stro, Cyanogen, JAC, Stericson, Twisted, Ccyrowski, Barak, AndroidSpin, @allroid_org, and the XDA community! you all Rock!
now... your going to need the following:
>Root
>3 partitions (Currently i have 48/512)
>Latest Radio
>Cyanogen's 1.4 recovery or higher
>Haykuro's SPL <-- otherwise you get Xbin error on flash
>Some Smarts
lol
This requires a wipe...
alt-w - wipe
alt-x command prompt...
#mount -o rw /system/sd
#rm -rf /system/sd/*
#reboot recovery
Then...
alt-w wipe again
then alt-f repair ext filesystems
Flash! Good!
JesterBlur is not in themes because hero roms boot loop
when you apply the update to them.
V1.0.5
:updated all images in all APK's that i could
:Custom Made Tray Handles w/Floating Buttons (just for looks)
:Removed HTC Sync
:custom LockScreen w/ moto logo
:Custom In-Call Screen with Blur Look
:Added Blur Wallpapers
: Modified GMail status notification to have a RED "@" and white background
:Fixed FC on Wallpaper Gallery
:Fixed FC on People
:For the most part is great for everyday use, my testers say is pretty stable
:Works both in Portrait and Landscape perfectly When using keyboard
:Tested on G1 - Magic users report if it works, i don't have a mytouch myself.
V1.1.0
:Updated HTC Sync with blur images
:Updated Mail with Blur Tray Icon
:Added Blur Animations! Yay!
:Added Quick Office
:Added Weather Widgets <--like my newest screenshot
:Led's Still dont work <-- this hero is different than the others so, will fix it soon!
:MT3G Users reporting that its working excelent! Thanks TeCH NiNJa,wicked_beav,solaresdonis & XxKOLOHExX keep us posted on MT3G status
V1.1.5
:Overhauled Rosie w/ all new images
:moded all apk`s associated with setup
:removed QuickOffice
:Full LED`s
:HomeScreen Buttons work!
:New Dial Pad
:Opening Blur Animated Boot Sequence
:Factory Ringtones
will still work on getting bluetooth working in future updates. again this is experimental but is stable for daily use!
Hatte leider noch keine zeit es auszuprobieren!
Hier der Orginal link: [Rom] JesterBlur v1.1.5 10-20-09 (Experimental) - xda-developers
Download der neuen Version Hier : http://www.androidspin.com/downloads.php?dir=jesterdroid/ROM/&file=JesterBlur-v1.1.5.zip
lg
PlaYOuT
PlaYOuT
Dauergast
hat das eigendlich jemand mal geflasht?
lg
endLess_story
endLess_story
Bei Android-Pit gab es zwei Videos zur Experimental Build. Finde den LInk leider nicht. War ein Blogeintrag - da lief es recht stabil.
PlaYOuT
PlaYOuT
Dauergast
oki,würde es ja gerne flashen aber immoment fehlt mir dia zeit dafür!
deswegen frag ich lieber vorher ob es jemand schon drauf hatte!
lg
cipher
Stammgast
Ich hatte es Gestern mal ausprobiert. Ist halt ein Hero-ROM mit der Blur-Grafik.
Die weather.apk fehlt und es ist auch nicht schneller, als MLIGN-2.5.7. Von daher habe ich es dann wieder runtergeworfen.
Stabil scheint es zu laufen, jedenfalls sind mir keine gröberen Fehler aufgefallen.
Mir selbst bietet es allerdings nicht genügend Gründe, um es dauerhaft zu nutzen. Ich bleibe derzeit beim MLIGN-2.5.7, das ist immer noch eines der besten HERO-ROMs, die derzeit zu bekommen sind.
PlaYOuT
PlaYOuT
Dauergast
Ich danke dir fuer den kurzen einblick fuer dieses rom!
Lg
