cipher
Stammgast
- 42
Ja, die 2.5.5 kann man wirklich gut benutzen.
Leider haben alle Non-Hero-Roms dieses O2-MMS Problem ...
Nachtrag:
habe jetzt folgende user.conf installiert und es läuft noch einen Tick besser:
Datei umbenennen in "user.conf" und dann nach /system/bin speichern.
Nachtrag:
Code:
# General parameters
general{
apps2sd=0 # this is useless here, require a modified a2sd script
dalvik2sd=0 # relinks the dalvik to sd if /system/sd/dalvik-cache exists
data2sd=0 # moves the data to sd if user enables
smsurgent=1 # sets the sms to urgent priority if user enables
lednotify=1 # activates led notification if user enables
#compcache related parameters
compcache{
compcache_en=0 # enable(1) or disable(0) compcache
cc_disksize=48 # Ram swap disksize - any number between 1 to 95 should work
cc_memlimit=48 # Limit the memory usage for backing swap (cc .5x known issue-defaults to 15% of total RAM)
cc_backingswap_en=0 # enable(1) or disable(0) backing swap
cc_backingswap=/dev/block/mmcblk0p3 # pointing to the backingswap partition device
cc_swappiness=45 # default 60
#Linux swap parameters
# linux swap can only be enabled if cc_backingswap_en is set to "0"
linux_swap{
linux_swap_en=1 # enable(1) or disable(0) linux swap
linux_swap_partition=/dev/block/mmcblk0p3 # swap partition device
#virtual memory
sys_vm{
sys_vm_en=1 # enable(1) or disable(0) virtual memory configurations
page_cluster=3 # default 3, (0 since CM3.9.6+)
laptop_mode=0 # default 0
dirty_expire_centisecs=4000 # default 3000
dirty_writeback_centisecs=650 # default 500
dirty_background_ratio=5 # default 5
dirty_ratio=10 # default 10
#cpu clock
proc_cpu{
proc_cpu_en=1 # enable(1) or disable(0) user cpu configurations
# freqency options
# 19200
# 122880
# 128000
# 245760
# 384000
# 528000
scaling_min_freq=384000 # default 245760
scaling_max_freq=528000 # default 528000
sampling_rate=3000000 # default 2000000 depending on kernel version
powersave_bias=0 # default 0, (200 since CM3.9.6+ )
up_threshold=35 # default 40, percent cpu usage before going up a speed step
