Touchscreen Empfindlichkeit
  • 1 Antworten
  • Neuester Beitrag
Diskutiere Touchscreen Empfindlichkeit im Root / Hacking / Modding für T-Mobile G1 im Bereich T-Mobile G1 Forum.
clemser
Gast
Hallo Zusammen,
ich hab beim googlen entdeckt das man bei manchen Touch Handys die Empfindlichkeit ändern kann.
jetzt wollt ich mal wissen ob es auch bei meinen guten alten g1 geht?
und wenn es geht, wie es funktioniert.
vielen dank im voraus
clemser
k3v.4
k3v.4
clemser schrieb:
Hallo Zusammen,
clemser
i have the same "problem", if you wanna call it that. to my understanding, the g1 does not have the option to calibrate it manually, its a finger touch screen, not a pressure sensitive screen. phones like the g1 and the iphone automatically calibrate themselves because the screens are finger (electrically) sensitive, which means that the screen translates the static electricity in your fingers into movement gestures on the screen, thats why you dont get a response from the screen if you touch it with a stylus. other phones such as the lg voyager and samsung instinct need manual calibration because they are pressure sensitive, also on pressure sensitive devices, if you hold the screen to an angle, you will see a bunch of little tiny dots all over, those dots are the sensor grid for the phone. so all in all, the g1 has an advantage being that its a finger sensitive screen. maybe with the next update, they will send a patch to help this problem.
Das sollte deiner Frage beantworten, eine Sekunde Google : "g1 touch kalibrieren", 2. Link.:sneaky:
