1. Mitglieder surfen ohne Werbung auf Android-Hilfe.de! ✔ Jetzt kostenlos Mitglied in unserer Community werden.
  1. MarciWoi, 29.11.2010 #1
    MarciWoi
    MarciWoi Threadstarter Android-Lexikon
    Xillius200's, Mikeyman77's, Spikeynick94's XMN 2.1 DroidEris
    ABOUT XMN 2.1 DROIDERIS
    I dont know about any of you, but i love sense. however sense has never met my standards in terms of speed, and stability.. well thats what i want to fix. this has been a little project of mine for a few weeks, hope you like and enjoy
    as Zach has left I have tried to speak to him doubt he will ever come back so in terms of this day R.I.P ZX but hello XM ^^
    Xillius200: Rom developer + Porter
    Mikeyman: Rom Developer + Porter
    Spikeynick94: Theme creator + apk resizing (hdpi to mdpi etc.)
    Steps to a successful install:
    0 format sd card and setup the sd card with ext4 of 512mb or above and the swap with 128mb
    0.1 go here 2708+ enabled kernel [14MB ram with radio 2.22.27.08/2.22.28.25 & hboot 1.33.0013d] - xda-developers
    0.2 follow steps upgrade spl an radio
    1. Head over to Firerats MTD page
    2. Download FR_Boot_v1.5.6 and FR_Recovery_v1.5.6 to your sd card
    3. Create a text file called mtdpartmap.txt with the "mtd 145 2" inside of the txt file without the quotes
    4. Download the rom below to sd card
    5. enter recovery and wipe cache,data,system
    6. Flash FR_Recovery_v1.5.6
    7. Wipe cache,data,system
    8. reboot but back into recovery
    9. Flash Rom
    10. Flash FR_BOOT
    11. Reboot phone and enjoy ^^
    done
    BE AWARE ROM IS NOW 2708 ONLY "NO NEED FOR EZTERRY ANYKERNEL" STILL NEEDS MTD BOOT ^^
    Zitat:
    XMR45: More of a fixed up release
    - new widgets
    - footprints
    - friendstream
    - Slight optimization to apps now lol - can be optimized more next build ^^
    - wifi fixed
    - landscape could be fixed needs checking ^^
    - Service seems good lol but was for me anyway so needs testing ^^
    - Not the last
    - etc.
    not working:
    - Camera
    - Camcorder
    - BT
    v5 - Speed Boost release - (12/01/2011)
    - Alot more speed
    - different kernel
    - etc.
    Download und Installation:
    Beste Einstellungen bei SetCPU:
    Max.: 614 MHz
    Min.: 245 MHz
    Threshold: 35
    ignore nice load: 1
    Ich habe bei dieser Version immer noch den Service-bug, der seit der neuen Base auftritt.
    Landscape-mod funktioniert auch nur sehr beschränkt (unbrauchbar^^)
    WLAN funktioniert jetzt, bei version 4 hat es Probleme auf dem G1 gegeben.
    Infos und Download hier:
    http://forum.xda-developers.com/showthread.php?t=807183
  2. Mace89, 29.11.2010 #2
    Mace89
    Mace89 Erfahrener Benutzer
    ja wollte ich aber mtd funzt net keine ahnung warum dann steht bei mir die fehlermeldung
    E:Can´t chown/mod /system/xbin
    (no such file or directory)
    E:Failure at line 14:
    set_perm_recursive 0 2000 0755 06755 System:xbin
  3. Mace89, 29.11.2010 #3
    Mace89
    kennt jemand das problem? und kann mir helfen?
  4. CoronaLife, 29.11.2010 #4
    CoronaLife
    CoronaLife Android-Hilfe.de Mitglied
    Hast du vorher auch auf deiner SD/Karte eine Datei erstellt mit dem Namen mtdpartmap.txt und 161 4 reingeschrieben?
  5. Mace89, 29.11.2010 #5
    Mace89
    hat sich erledigt hab was gefunden nur so zur info
    6) Run 'adb shell' in the tools folder of the sdk installation to start interactive mode.
    7) Now run these commands:
    mount -o rw -t yaffs2 /dev/block/mtdblock3 /system
    mkdir -p /system/xbin
    touch /system/xbin/removeme
    chmod 755 /system/xbin
    chmod 664 /system/xbin/removeme
    exit
    8) Restart phone. Verify that /system/xbin folder is present and contains removeme file
  6. Mace89, 29.11.2010 #6
    Mace89
    eine frage noch habe ja bereits den ezterry kernel und radio usw. wie mache ich ein system wipe im recovery?
    9. Flash Rom
    10. Flash FR_BOOT
    done [​IMG]
  7. Mace89, 29.11.2010 #7
    Mace89
    noch ne doofe frage reboot ins recovery mit annehmen-menü-power? und dann home gedrückt halten?
  8. Mace89, 30.11.2010 #8
    Mace89
    So hab es endlich geschafft.
    + schöne optik
    + htc sense
    + geschwindigkeit
    + keine fc´s
    - 67 mb intern
    - kein Bluetooth
    - kein froyo
    - kein multilanguage aber more loacale2 aus dem market macht so gut wie alles auf deutsch
    - akku
    mfg Marcel
  9. MarciWoi, 30.11.2010 #9
    MarciWoi
    aber nach meiner meinung der beste hero sense ui rom :)
    mfg marcel
  10. Mace89, 30.11.2010 #10
    Mace89
    :)ja find ich auch ist hammer. kann man net mit normalen roms vergleichen
  11. MarciWoi, 02.12.2010 #11
    MarciWoi
    neue version :
    ROM DOWNLOAD: xm3_5_signed.zip
    Best Settings:
    Animations: OFF
    Setcpu: 576mhz and interactive I think is good lol ^^ but up to you lol - the ones on by default I find good [​IMG]
    XMR3.5
    Fix to widget problems in framework - hopefully xD
    ALOT More speed lol
    A few other things modded for better stability ^^
    faster keyboard - If keyboard don't work adb push replacement lol
    renice tweaks
    etc.
    LÄUFT NOCH BESSER :OO
  12. Mace89, 02.12.2010 #12
    Mace89
    ja läuft wirklich besser akku laufzeit heute 55% verbrauch bei gleicher nutzung vorher ende des tages nur 15 %
    mfg Marcel
  13. MarciWoi, 08.12.2010 #13
    MarciWoi
    Kleine INFO :
    4.0 wird im dezember erscheinen :)
  14. artMkiss, 10.12.2010 #14
    artMkiss
    artMkiss Junior Mitglied
    einmal "mtd 145 2" einmal "161 4" ...
    und da heist es, man kann nicht lesen. Also was jetzt ?
    EDIT:
    Hat sich erledigt ! mtd 145 2 ist richtig.
    Andere Frage:
    Kann es sein dass bei diesen ROM der Internetzugriff für Apps gesperrt ist ?
    Go Chat! ect. funktionieren nicht !
    Ansonst super Sense-ROM !
  15. MarciWoi, 12.12.2010 #15
    MarciWoi
    ich weiß nicht genau , aber solche probleme hatte ich nicht :o
  16. artMkiss, 12.12.2010 #16
    artMkiss
    Go!Chat, imo-App funktionieren nicht .. dass sind beide Chat-Apps für verschiedene Netzwerke.
    => "Trillian" funktioniert , hab gerade getestet.
    Weis jemand wie man beim SMS schreiben diesen automatischen Vorschlag-modus (T9 oder sowas kA) deaktivieren kann ?
    Wenn ich unter Language & Keyboard => Device keyboard => "Auto-replace" deaktiviere, dann ändert dass irgendwie nichts.
    mfg
  17. Schmalzstulle, 13.12.2010 #17
    Schmalzstulle
    Schmalzstulle Android-Lexikon
    Findeste doch sowieso gleich allein raus.....Alleinunterhalter ;)
  18. Mace89, 13.12.2010 #18
    Mace89
    mhh bei mir gehts einwandfrei unter Einstellungen=>Sprache und Tastatur=>Tastatur des Gerätes und alles deaktiviert, im vormenü hab ich auch Touch input deaktiviert.
    mfg Marcel
  19. artMkiss, 13.12.2010 #19
    artMkiss
    Find ich nicht xD
    Hab im xda-Forum nachgefragt ... und zufälligerweise bekam ich dort schneller eine Antwort.
    Natürlich Poste ich dann auch hier die Antwort, falls wer die selbe Frage hat. Das ist doch der Sinn vom Forum ;)
  20. artMkiss, 15.12.2010 #20
    artMkiss
    Das ROM läuft super, am anfang halt..
    Nach dem ich 1-2 Apps installiert hab, sagt er "Out of Space"
    Hier das logcat beim installieren:
    "Couldn't clear application caches" kommt mir verdächtig vor ^^
    Zu meinem G1:
    Partitionen sind auch in ordnung:
    Weis wer was da falsch ist ? hab es schon öfters installiert... immer das selbe.
    mfg
Du betrachtest das Thema "Xillius200's,Mikeyman77's,Spikeynick94's DroidEris 2.1r3 ("MTD+2708") (26/11/2010)" im Forum "Root / Hacking / Modding für T-Mobile G1",
  1. Android-Hilfe.de verwendet Cookies um Inhalte zu personalisieren und dir den bestmöglichen Service zu gewährleisten. Wenn du auf der Seite weitersurfst stimmst du der Cookie-Nutzung zu.  Ich stimme zu.
