[ROM] MMod 1.2 Hero 2.1 WWE + Legend mix
Gani
Gani
Dauergast
342
Ein neues ROM welches mal wieder zum Teil auf dem HTC Legend
basiert ist nun erschienen.
Selbst habe ich es noch nicht getested,aber hört sich auch
interessant an.
Sreenshots findet ihr hier:
Picasa-Webalben - c.brueggemann94 - ROM
Link zum Thread bei den XDA Devs:
[ROM] [276 MB free on DATA!] MMod 1.2 [Hero 2.1 WWE + Legend mix] - xda-developers
Features:
- Based on Smoki 0.7.6 for the HTC Sapphire/Magic
- 2.1 Sense
- Multilanguage - Credit goes to: capychimp
- Much faster and more stable than Froyo ROMs
- Sexy Droid X-HTC mix boot animation <3
- Live Wallpaper support in ADW, LauncherPro, etc (Quite fluid)
- Friendstream
- FULLY working Gallery3D
- HTC Newswidget & Google GenieWidget
- Chinese supported
- Zipalign-on-boot for better performance
- No compcache
- Protected apps working, use Market Access app if you can't access them in your country
- Powertop for battery monitoring
- HTC Desire lockscreen, looking much better
- Newest YouTube app with HQ button
- WiFi-Tethering via aNetShare working
- Cronos Kernel, OC support via Overclock Widget (included)
- Jonasl's HTC_IME mod
- Adblocking-hosts file
- Fully odex'ed so you get more free space on /data & Fast first boot
- SwiFTP server included, no need to mount your phone via USB anymore
- Battery percentage indicator
- Quickoffice, PDF-Viewer & Teeter can be uninstalled
- Apps2SD should be working, untested (confirmed by some users)
- EVO-like settings widgets
- 276 MB FREE SPACE ON DATA!
Removed:
- Stocks + Widget
- Footprints + Widget
- Java ME
- Ringtones
- "Get more Widgets"-Widgets
- Google Maps, get it from the Market
Known bugs:
- adb remount doesn't work, use adb shell mount -o rw,remount /system
Version 1.2.1 nun erschienen!
1.2 - 1.2.1
- Fix 5 MP photos
- Added package to fix the FC on boot, if you get it, flash it!
- Phone should now identify itself as HTC Hero
1.1 - 1.2
- 276 MB free on /data !!
1.0 - 1.1
- Fixed some HTC widgets
- Canadian Locale, confirmed
- Updated Market Access application
- Updated APN list
- New JIT package, disabler now available too
- Updated openGL driver
Neue Version wieder erschienen!
Changelogs:
1.2.2 - 1.2.3
- Fixed the CPU frequency issues
1.2.1 - 1.2.2
- Changed Kernel to one based on Ninpo's (due to GPL violation of Feeyo's kernel)
- Added several governors, including interactive governor
(conservative is now default),removal of most debug functions and more.
This also fixes the 'adb remount' command.But also adding one bug for me,
check 'Known bugs'
- Added en_MY (Malaysian locale)
- Removed unstable Overclock Widget, better get SetCPU from the Market
Schon mal jemand ausprobiert?
Selber nicht,aber man sollte dies beachten:
Installing / First Install of 1.2+ Guide:
1) Flash RecoveryMod.zip (credit to Klothius), you won't be able to install other custom ROMs than mine (unless they use the same MTD config as I do) until you revert the RecoveryMod!
Why is the RecoveryMod necessary?
The ROM is using a modified Kernel commandline to change the partitioning, to be exact, it changes the sizes so you get more space on /data.
A custom recovery is needed, because a normal recovery would flash to wrong sectors in the NAND, so the flashed boot.img, which contains initialization scripts, wouldn't be able to recognize and read the system files.
Revert Recovery Guide:
1) Download ROM Manager from the Android Market
2) Flash the recovery via the first option in the app
3) Put another ROM on your SDcard
4) Reboot into recovery MANUALLY
5) Format all partitions except the SDCARD in the partitions menu
6) Flash the other ROM
ja ich. Schon ganz nice,jedoch hatte ich noch die ROM mit dem cpu bug.
Muss mal die neue Version testen, aber sonst hat das alles einen soliden Eindruck hinterlassen.
alfalette
alfalette
alfalette
  • Androfan
Androfan
hävksitol
hävksitol
