Probleme beim Flaschen
Mike1234
ich versuche folgender Anleitung zu folgen:
https://www.android-hilfe.de/forum/...-pro.338/guide-e10i-u20i-minicm10.443290.html
Komme aber nicht richtig weiter. Unter Punkt 2 ist bei s1 erom vers R groß geschieben. Was ist hier falsch?
U+OAsAAAAASUVORK5CYII=
Mache ich einfach mit Punkt 3 weiter kommt folgendes Dialogfenster: 15/013/2013 18:13:22 - INFO - <- This level is successfully initialized
15/013/2013 18:13:22 - INFO - Flashtool Version 0.9.10.1 built on 2013-01-09 19:49:47
15/013/2013 18:13:22 - INFO - You can drag and drop ftf files here to start flashing them
15/013/2013 18:13:28 - INFO - Device disconnected
15/013/2013 18:13:31 - INFO - Selected E10_2.6.32.60-nAa-05.ftf
15/013/2013 18:13:31 - INFO - Preparing files for flashing
15/013/2013 18:13:31 - INFO - Please connect your device into flashmode.
15/013/2013 18:13:37 - INFO - Device connected in flash mode
15/013/2013 18:13:37 - INFO - Opening device for R/W
15/013/2013 18:13:38 - INFO - Reading device information
15/013/2013 18:13:38 - INFO - Phone ready for flashmode operations.
15/013/2013 18:13:38 - INFO - Current device : U20i - CB511Q38XP - 1238-8823_R18B - 1235-3411_2.1.1.C.0.0 - VFE-1-8_2.1.1.C.0.0
15/013/2013 18:13:38 - INFO - Start Flashing
15/013/2013 18:13:38 - INFO - Processing loader
15/013/2013 18:13:38 - INFO - Checking header
15/013/2013 18:13:38 - INFO - Ending flash session
15/013/2013 18:13:38 - ERROR - ERR_SEVERITY="MAJOR";ERR_CLASS="SECURITY_CLASS";ERR_DYNAMIC="SIN header verification failed"
15/013/2013 18:13:38 - ERROR - Error flashing. Aborted
15/013/2013 18:13:38 - INFO - Device connected in flash mode
15/013/2013 18:13:39 - INFO - Device disconnected
15/013/2013 18:13:42 - INFO - Device connected in flash mode
15/013/2013 18:13:56 - INFO - Device disconnected
15/014/2013 18:14:06 - INFO - Device connected with USB debugging off
15/014/2013 18:14:06 - INFO - For 2011 devices line, be sure you are not in MTP mode
Was mache ich falsch?:cursing:
Danke für euer Hilfe!
Mike
Hast du USB Debugging aktiviert ?
Das R bedeutet ja, dass dein Bootloader noch geschlossen ist und aus deinem Log geht ja auch hervor, dass der Vorgang abgebrochen wurde.
Aktiviere mal USB Debugging und wiederhole Schritt 2 um den Bootloader zu öffnen.
Gesendet von meinem GT-P3100 mit der Android-Hilfe.de App
Danke! Habe den Bootloader mit
xda-developers - View Single Post - [Dev] Building kernel
ungelockt und den neuen Kernel geflasht.:)
Schritt 2 scheint bei mir nicht zu funktionieren.:confused2:
Nun habe ich den Kernel istalliert, bin beim 1. mal auch hinein gekommen und konnte über die Lautstärketasten unterschiedliche Zeilen auswählen. Der Home button hat nicht funktioniert. Nachdem ich den Akku entfernt habe komme ich nur noch auf den Startbildschirm des Kernels. Neues flashen hilft nicht. Was kann ich machen?
Danke!
Mike
das Problem hab ich selber momentan auch, konnte noch keine Lösung finden ausser öfter hintereinander flashen und zu hoffen das es bootet.
Kann dir da leider auch nicht weiter helfen und goo ist momentan auch noch für mind. ne Woche down :-(
hallo!!
ich habe leider auch ein problem, möchte bei meinen x10 mini pro CM flashen, nur leider zeigt mir das flashtool immer an das ich nicht im fastboot bin, usb debugging ist aktiviert! ich komme einfach nicht hinein, weder mit lauter, noch leider oder auch nicht mit der menü taste.
ich bin schon total verzweifelt
ich hoffe ihr könnt mir helfen
viele grüsse
Das Mini hat kein Fastboot, nur Flashmode zurücktaste gedrückt halten beim anschließen.
und wie bekomm ich dann das neue cm 10.2 drauf?? das ist ja eine .img datei
garnicht, das mini nutzt speziell angepasste cm Versionen die MiniCMs und cm110.2gibt es nicht für das mini
Falsche Custom Rom, ist für ein anderes Handy, bei dem Mini ist der Kernel eine separate ftf Datei die im Flashmode geflasht wird. Eine Boot Image gibt es in den passenden Customs Rom nicht.
habe es mehrfacht mit dem flashen versucht und den Kernel diesmal von goo geladen und keine Veränderungen feststellen können. Kann ich einen anderen Kernel flashen als den da?
Danke und Gruß
Mike
System vorher im CWM formatieren, vorher den passenden nAa 14 Kernel flashen.
This kernel uses a custom mtd partitioning with larger /system partition to hold the extra JB calories. If you are moving from another custom kernel, EXCEPT 2.6.29-nAa-jb to this one, you MUST first format /system /data and /cache via the embedded CWM recovery
Nein, minicm unterstützt nur den nAa kernel da minicm auch von nAa ist und kernel und rom speziell angepasst sind
Mit dem nAa 14 Kernel System, Data und Cache formatieren, danach den JB Kernel flashen von nAa und dann die passende Rom flashen.
Der ursprüngliche Beitrag von 21:38 Uhr wurde um 21:54 Uhr ergänzt:
Mike
@mike1234
Da hast Du den Kernel für das X10 Mini (E10i) geflasht und Du hast ein X10 mini pro (U20i), das geht gar nicht!
ich bin neu hier im Forum und habe das gleiche Problem. Ich habe jedoch ein Xperia Mini Pro (Ohne X10)
Ich hoffe dann darf man hier überhaupt so rein posten :confused2:
29/059/2013 15:59:45 - INFO - Selected ST18 / 4.1.A.0.562 / Kernel
29/059/2013 15:59:45 - INFO - Preparing files for flashing
29/059/2013 15:59:45 - INFO - Please connect your device into flashmode.
29/005/2013 16:05:09 - INFO - Device connected in flash mode
29/005/2013 16:05:09 - INFO - Opening device for R/W
29/005/2013 16:05:10 - INFO - Reading device information
29/005/2013 16:05:10 - INFO - Phone ready for flashmode operations.
29/005/2013 16:05:10 - INFO - Current device : SK17i - BX902T3PMQ - 1249-1887_R1I - 1244-7088_4.1.B.0.587 - WORLD-i_4.1.B.0.587
29/005/2013 16:05:10 - INFO - Start Flashing
29/005/2013 16:05:10 - INFO - Processing loader.sin
29/005/2013 16:05:10 - INFO - Checking header
29/005/2013 16:05:10 - INFO - Flashing data
29/005/2013 16:05:13 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Boot version : R9A028 / Bootloader status : ROOTABLE
29/005/2013 16:05:13 - INFO - Disabling final data verification check
29/005/2013 16:05:13 - INFO - Processing kernel.sin
29/005/2013 16:05:13 - INFO - Checking header
29/005/2013 16:05:13 - INFO - Flashing data
29/005/2013 16:05:13 - INFO - Ending flash session
29/005/2013 16:05:13 - ERROR - ERR_SEVERITY="MAJOR";ERR_CLASS="SECURITY_CLASS";ERR_STATIC="IMAGE_ADDRESS_RANGE";ERR_DYNAMIC="SIN-block eraseblock mismatch";
29/005/2013 16:05:14 - ERROR - Error flashing. Aborted
29/005/2013 16:05:14 - INFO - Device connected in flash mode
29/005/2013 16:05:15 - INFO - Device disconnected
29/005/2013 16:05:16 - INFO - Device connected in flash mode
29/005/2013 16:05:57 - INFO - Device disconnected
29/006/2013 16:06:26 - INFO - Device connected in flash mode
29/007/2013 16:07:07 - INFO - Device disconnected
29/007/2013 16:07:35 - INFO - Device connected in flash mode
29/008/2013 16:08:03 - INFO - Selected ST18 / 4.1.A.0.562 / Kernel
29/008/2013 16:08:03 - INFO - Preparing files for flashing
29/008/2013 16:08:04 - INFO - Please connect your device into flashmode.
29/008/2013 16:08:05 - INFO - Opening device for R/W
29/008/2013 16:08:05 - INFO - Device connected in flash mode
29/008/2013 16:08:05 - INFO - Reading device information
29/008/2013 16:08:15 - INFO - Unable to read from phone after having opened it.
29/008/2013 16:08:15 - INFO - trying to continue anyway
29/008/2013 16:08:15 - INFO - Start Flashing
29/008/2013 16:08:15 - INFO - Processing loader.sin
29/008/2013 16:08:15 - INFO - Checking header
29/008/2013 16:08:15 - INFO - Ending flash session
29/008/2013 16:08:15 - ERROR - Error in processHeader : 2 : Das System kann die angegebene Datei nicht finden.
29/008/2013 16:08:15 - ERROR - Error flashing. Aborted
29/008/2013 16:08:16 - INFO - Device disconnected
29/010/2013 16:10:20 - INFO - Device connected in flash mode
29/010/2013 16:10:21 - INFO - Device disconnected
29/010/2013 16:10:28 - INFO - Selected ST18 / 4.1.A.0.562 / Kernel
29/010/2013 16:10:28 - INFO - Preparing files for flashing
29/010/2013 16:10:29 - INFO - Please connect your device into flashmode.
29/010/2013 16:10:36 - INFO - Device connected in flash mode
29/010/2013 16:10:37 - INFO - Opening device for R/W
29/010/2013 16:10:37 - INFO - Reading device information
29/010/2013 16:10:37 - INFO - Phone ready for flashmode operations.
29/010/2013 16:10:37 - INFO - Current device : SK17i - BX902T3PMQ - 1249-1887_R1I - 1244-7088_4.1.B.0.587 - WORLD-i_4.1.B.0.587
29/010/2013 16:10:37 - INFO - Start Flashing
29/010/2013 16:10:37 - INFO - Processing loader.sin
29/010/2013 16:10:37 - INFO - Checking header
29/010/2013 16:10:37 - INFO - Flashing data
29/010/2013 16:10:40 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Boot version : R9A028 / Bootloader status : ROOTABLE
29/010/2013 16:10:40 - INFO - Disabling final data verification check
29/010/2013 16:10:40 - INFO - Processing kernel.sin
29/010/2013 16:10:40 - INFO - Checking header
29/010/2013 16:10:40 - INFO - Flashing data
29/010/2013 16:10:40 - INFO - Ending flash session
29/010/2013 16:10:40 - ERROR - ERR_SEVERITY="MAJOR";ERR_CLASS="SECURITY_CLASS";ERR_STATIC="IMAGE_ADDRESS_RANGE";ERR_DYNAMIC="SIN-block eraseblock mismatch";
29/010/2013 16:10:40 - ERROR - Error flashing. Aborted
29/010/2013 16:10:41 - INFO - Device connected in flash mode
29/010/2013 16:10:42 - INFO - Device disconnected
29/010/2013 16:10:43 - INFO - Device connected in flash mode
29/011/2013 16:11:24 - INFO - Device disconnected
Nun bekomme ich beim Starten nur noch das Sony Zeichen zu sehen und anschließend diesen Bildschirm:
Ich hoffe jetzt einfach mal, dass man das Handy noch retten kann.
Verwendet hatte ich die folgende Anleitung: [TUTORIAL] Rooting Xperia 2011 devices with ICS(4.1.B.0.587) - xda-developers
Wäre schön wenn mir jemand sagen könnte, dass ich das Handy noch nicht gebricked habe :unsure:
Vielen Dank im Voraus
Benny
@Benny, falsches forum, falsche software ;-)
Repariers mit sus und hol dir die richtige Software
Hab mir deinen log und den link nochmal genauer angesehen (hatte ihn beim ersten mal aus Zeitmangel nur überflogen), scheint so als hättest du den bootloader nicht entsperrt, davon steht nämlich nichts in der Anleitung, auch wenns angeblich funktionieren soll, sobald ein anderer Kernel ins spiel kommt, kann ich mir das kaum vorstellen
ich habe ebenfalls ein Problem beim Flashen meines X10 mini pro und komme nicht weiter. :crying:
Laut Flashtool BLU Vorgang lässt sich der Bootloader nicht unlocken
"06/045/2016 19:45:36 - INFO - Your phone bootloader cannot be officially unlocked"
Mit msm7227 habe ich dies dann angeblich geschafft.
_______
EDIT: Mit S1Tool wird ebenfalls bestätigt, dass der Bootloader nicht mehr gelocked ist. Stichwort "kleines r" (siehe Bild "loader_unlocked")
_______
Flashtool beendet den daraufhin ausgeführten Flash aber mit Fehler (siehe Bild "flasherror").
Was mache ich falsch?? :confused2:
Ich hoffe der Artikel ist nicht zu alt, um diesen noch einmal hervorzukramen und Antwort zu erhalten.;)
Ich würde mich sehr freuen, wenn ich Hilfe erhalte, da ich das X10 gerne als Arbeitshandy verwenden möchte und diverse Apps aber nicht mehr lauffähig sind unter Android 2.1 :bored:
_______
EDIT2: Okay, es war die Firewall. ^^
Jetzt hat er geflashed (U20_nAa-jb-02_2.6.29.6-nAa-jb-02) und nun habe ich allerdings das Problem, nicht in den entsprechenden Kernel Mode zu kommen und das X100 mini pro macht einen Bootloop... :cursing:
EDIT3: Komme weder in die CWM Recovery (durch dauerhaftes Tippen der "Back" Taste) noch kann ich das System wieder Aufsetzen mittels PC Companion. SEUS stürzt direkt nach dem Start mit Fehler ab.
Kann bitte irgendwer helfen...bin am Verzweifeln...
Pure Hate
LordNikon
LordNikon
LordNikon
sgspluss
sgspluss
