[ROM][14-09-2011] The-GingerMOD Vanilla v0.4b[AOSPized XXKG6] Fastest Rom! --patched!
blasen187
Bin sie gerade am testen
Original Thread
[ROM][14-09-2011] The-GingerMOD Vanilla v0.4b[AOSPized XXKG6] Fastest Rom! --patched! - xda-developers
Here it is:
The GingerMOD
What's that?
This is an AOSPized Version of the STOCK firmware, for whoever wants an AOSP experience BUT don't want to renounce to Samsung experience!
What lead me to do that:
GPU Browser
TV-Out
FM Radio
TW Camera
Now thoose are the main reasons I wanted to start from a stock rom and Remove TW from it!
In fact here are the only "samsuningness" left:
Browser
Camera
Radio
Task Manager
Dialer/Phone
Lockscreen
So HERE is What the Rom Offers to you
AOSP Gallery 3D
AOSP Launcher 3D
AOSP Calendar
AOSP Clock
AOSP Calculator
AOSP Email
AOSP Music Player
AOSP File Manager
AOSP MMS.apk
AOSP Sound Recorder
AOSP Live wallpapers (form nexus s
AOSP Keyboard (modded to be BIGGER!)
AOSP Sounds/notifications/Ringtones (form nexus s)
AOSP Bootanimation/Bootsound (form nexus one)
AOSPized Look of ALL the rom:
Original Ginger icons in Framework-> See The Screenshots in Next Post!!
REMOVED ALL SAMSUNG APPS
So this Becomed Almost VANILLA gingerbread 2.3.4
What is left to AOSPize??
Dialer/Phone.apk ---> I'm still working on having AOSP Contacts/Phone working, maybe in next releases!
Lockscreen--> This will be an Hard work! But I'm sure it is possible to do!
The Goal of the Rom is NOT TO HAVE A COMPLETE SAMSUNG EXPERIENCE
BUT To have THE BEST of What Samsung done IN AOSP ANDROID
STILL WANT SAMSUNG APPS???
ok I'll give them to you xD
Those are Flashable ZIP! Just put them on Memory Card, go in CWM and flash them, just wipe Cache/Dalvik cache before boot!
URL=http://dl.dropbox.com/u/25106916/SGS2/TW-calculator.zip]TW-Calculator[/URL]
TW-Calendar
TW-Clock
TW-Keyboard
TW-Email
TW-MMS
TW-Music
TW-Voice-Commands
TW_Gallery
TW_VideoPlayer
SamsungApps(Hubs,Readers,SamsungMarket)
TW-SamsungDIVE
Then for you some FEATURE PACKS!
DLNA
Video_Foto-Editing
Tasks/Memos
Screenshot_Service
MobilePrint & Motion Settings
Swype Keyboard
Swype keyboard from samsung!
Kies Support
This will give back Kies Support to whoever uses it!
Then Some extras
BLN SUPPORT
Because of some aestetical changes, for now BY DEFAULT the rom does not support BLN;
Flash this ZIP to have BLN support (will change colors of notifications and or highlighned text!)
BLN-PATCH
Samsung DIVE
This Re-enables samsung dive support!!
Original AOSP Keyboard
This is already included in the ROM, just in case anyone wants to reflash it back
HTC IME
HTC IME-mod, just enable it in "languages and Keyboards" in settings and will be Fully Working!
Download!
TheGingerMOD_v0.4b_update.zip --> MEDIAFIRE
COMPLETE CHANGELOG
Kernel ninphetamine
Deodexed (Correctly-->GPU Browser Thx Brightidea/jesusfeke
Zipaligned
Optimized
Slimmed down! Only 208.1mb! (Stocks are over 370 )
AOSP Launcher 3d
AOSP Gallery 3d
AOSP Calendar
AOSP Clock
AOSP Calculator
AOSP Email
AOSP Music Player
AOSP File Manager
AOSP MMS.apk
AOSP Sound Recorder
AOSP Terminal Emulator (useful )
AOSP Voice Dialer
Added Latest GTalk with video/sound chat enabled
Added CyanogenMOD Latest DSP Manager (Fully working )
Added AppWidgetPicked modded!
Added Ad blocking via hosts file
Added Stay awake option (under development)
Added install location app option (Internal/external/Auto)
Added Skip Music track with Volume rocker (in screen offmode) thx aerobahn!!
Added 1%steps battery icons (based on AOSP ones)
THEMED Dialer (now AOSP THeme thx to LockedOn!!! )
Status Bar Power Widget 6 icons shortcut--> Thx LeoMar for the Mod
CRT OFF Effect
EdgeGlow Effect (both Thx to Rawat!)
Advanced Power Menu (thx bmarko82 Themed by Me!)
Camera MOD (for better quality THX Potatoman )
Browser MOD (with User Agent thx intronauta DEodexed by Me!)
Build.prop MODS:
Better UI handling
Better Data Handling
Tweaked memory Managing
Other Mods:
Fujutweaks-> Taken from Latest Honeycomb 3.1 build! (Smooth!!)
Sysctl.prop added -->>>MANY Tweaks for Memory and Resource managment!
Tweaked media_profiles.xml -->>> Better Camera Image Quality!!
Tweak Speed Memory card!
Zipalign @Boot on every /system and /data/app APK! (to have ALMWAYS the best!!
Reduced Homescreen wapeup lag (Thx Oliwe!)
Introduced EFS Backup (thx Paul Modaco!)
OC_Daemon
DualCore Scripts!-->> Redone!
Support for Td8f4 Tewaks included!(see his thread HERE for more infos!)
INTRODUCED TheGingerMOD Extras:
Its based on SpareParts compiled from Source and includes:
BatteryHistory fix (now points at GB Battery history)
Then I added the Extra section:
Change Lockscreen Wallpaper (with one in /sdcard/wallpaper)
Mount/Unmount NTFS Partition
Switch Bootanimation on the go!
ADS Blocking/Unlocking
Enable/Disable Stagefright Codec
Enable/Disable Bootsound
Enable/Disable Camera Sound
Calibrate your batery (will automatically reboot!)
This tool will grow and bring with him new features to make your life easier
DISCLAIMER:
Doing This you've to be SURE of what you are DOING!!
ALWAYS DO A BACKUP FIRST!
If your phone does melt, you lose an arm, an asteroid hits you or simply SuperMario pops up from your phone...I'm NOT RESPONSABLE OF THIS!
If coming from another rom REMEMBER TO PERFORM A DATA WIPE!
FAQs , CHANGELOG AND SCREENSHOTS IN NEXT POSTS!
If you like my work, you can buy me a coffe if you want
beicuxhaven
tenzin
nightwatchdog
Pr0TuRk38
Widar
Widar
