[THEME] für Sense ROMs - Revolution DHD - CLOSED
OK, was Du da "treibst" will ich jetz garnich wissen :flapper:
Leider arbeiten...
Couldn`t sleep the 1rst night...
Revolution Theme Update for Runny v3.1
I recoded the Theme, so you only need to swap the following images in order to have your own background. Just open the respective apk with winrar, draw your prefered png (rename it before) in drawable-hdpi folder and close the apk. Then flash it with the empty update.zip
Note: Transparent custom settings is NOT in default theme, you can flash it as add-on
Customization options:
App drawer background - applistbackground.png in rosie.apk
Notifications background - status_bar_background.png in systemui.apk
Quicksettings background - quicksettings_background.png in systemui.apk
Settings background - hestheone.png in framework-res.apk
Download Theme
Multiupload.com - upload your files to multiple file hosting sites!
Download Custom settings:
Download Custom backgrounds - fitted for all 4 parts, just rename accordingly
Download Revolution Skin - for flat dark HTC widgets
Empty update.zip - use this to flash your custom mods
Custom settings transparent background - YOU can change that with the new framework and settings hack.
Revolution Skin for Sense 3.0 GB 2.3.5 ROM`s
Finally a Skin, that themes also HTC widgets for GB 2.3.5 ROM, see screenshots. This Skin enables Revolution widgets (and large parts of the UI) and works both with stock and as add-on for Revolution Theme.
Please don`t ask, whether I can change the dock - the solution is limited, but at least my favorite widgets are back on ARHD.
Copy to SD and install like a market app, then choose Revolution Skin under personalize.
Download:
Hey Stoney. Schön, dass du wieder da bist.
Ich hab gestern Runny 3.3 und dein Ginger Basic Theme geflasht.
Wenn ich jetzt den App Drawer auf 5x5 einstelle in den Tweaks bekomme ich einen 2x4 App Drawer raus, bei 5x4 einen 1x4 App Drawer. Wenn ich dann wieder auf 4x4 zurückwechsel schmiert der Sense Launcher ab und alles muss wieder neu geflasht werden (incl. Full Wipe). Lass ich die Einstellungen unverändert auf 4x4 hab ich keine Probleme.
Hast du vll nen Tipp für mich?
Ich schau mir das mal an. Edit: Hast Du ev Rosie Trans danach geflasht?
Ja.
Sorry hab ich vergessen zu erwähnen.
Das ist die alte Rosie. Pack einfach Rosie_navbar.m10 aus dem assets folder der Trans in die neue Rosie und Du hast beides in einer Rosie.
Reaktionen: Big-Poppa
Mangels Interesse und Feedback stelle ich ab sofort den Support für meine Themes in diesem Forum ein. Das bedeutet nicht, das ich mich komplett zurück ziehe, aber die zusätzliche Arbeit lohnt sich seit längerer Zeit nicht mehr. Es wird leider nur noch fleißig geladen, Danke Buttons werden ignoriert und Feedback ist Fehlanzeige.
Updates und Infos gibt es weiterhin in meinen XDA Threads.
Für die Themes von he_stheone64 nutzt Ihr bitte ab sofort diesen Thread.
  • Chris162
Chris162
Lemmi
  • Lemmi
Lemmi
Lemmi
Phiber2000
