[THEME] Cobalt (Codename-1.3.3) - diverse Roms / AOKP M4
wemsinho
wemsinho
Enthusiast
752
Rootzwiki link: [Theme] Cobalt (Codename-1.3.3) / (AOKP-23) / (GummyNex-0.7.6) / (Revolution HD-2.1.5) / (Liquid ICS-B4) / (RootzBoat 8.1) - RootzWiki
Flashen über CWM --> Vorher zur Sicherheit ein Backup erstellen!!!!
UPDATE: AOKP M4 Support
AOKP Milestone 4: Download Sphere Battery & Speedo Battery, Removed Notification Dimming
AOKP Milestone 4: Download Sphere Battery & Little Android Battery, Removed Notification Dimming
AOKP Milestone 4: Download Sphere Battery & Xoom Circle Battery, Removed Notification Dimming
Codename Android
CodeName 1.3.3: Download Sphere/Speedometer Battery (Removed Notification Dimming)
CodeName 1.3.3: Download Sphere/Blue Android Battery (Removed Notification Dimming)
(AOKP) Android Open Kang Project
AOKP 23: Download Sphere Battery & Speedo Battery, Removed Notification Dimming
AOKP 23: Download Sphere Battery & Little Android Battery, Removed Notification Dimming
Transparent Versions thanks to Idle0095
AOKP 22: Download Sphere/Speed Battery, Removed Notification Dimming (Transparent Status/Nav Bars)
AOKP 22: Download Android/Speed Battery, Removed Notification Dimming (Transparent Status/Nav Bars)
Liquid ICS
Liquid Beta 4: Download(Liquid ported by Jess086 and is a full Cobalt port)
Gummy Nex
GummyNex 0.7.6: Download Sphere / Speedo Battery (Added Fast Key Mod, Removed Status Bar Notification Dimming)
GummyNex 0.7.6: Download Sphere / Android Battery (Added Fast Key Mod, Removed Status Bar Notification Dimming)
Android Revolution HD
Android Revolution HD 2.1.5: Download
RootzBoat
RootzBoat 8.1: Download Sphere Battery (Removed Status Bar Notification Dimming)
RootzBoat 8.1: Download Speedo Battery (Removed Status Bar Notification Dimming)
RootzBoat 8.1: Download Blue Andy Battery (Removed Status Bar Notification Dimming)
This theme includes themed SystemUI, Framework, Settings, and Browser
Ausprobiert habe ich selbst das Theme für Android Revolution HD. Obwohl es im CDMA Bereich bei Rootzwiki zu finden ist funktioniert es auch für die GSM Version:
Screenshots ARHD:
Screenshots AOKP:
Weitere Downlaods für AOKP:
AOKP 22: Download Sphere Battery & Speedo Battery, Removed Notification Dimming
AOKP 22: Download Sphere Battery & Little Android Battery, Removed Notification Dimming
AOKP 22 Droid Font Soft Keys: Download (Includes Sphere/Speedo Battery and replaces the SoftKeys with White Font Keys)
AOKP Milestone 3: Download Sphere Battery & Speedo Battery, Removed Notification Dimming
AOKP Milestone 3: Download Sphere Battery & Little Android Battery, Removed Notification Dimming
AOKP M3 Transparent Builds (Thanks to Idle0095 for Transparent Base)
AOKP Milestone 3: Download Sphere Battery & Speedo Battery, Transparent Status and Navigation Bars, Removed Notification Dimming
AOKP Milestone 3: Download Sphere Battery & Little Android Battery, Transparent Status and Navigation Bars, Removed Notification Dimming
AOKP Mlestone 3 Mods - Flash OVER a Full Cobalt Theme
Vortex Animations: Download (Replaces the Animations with Vortex Animations) (Thanks to Thepsyntyst for Animations)
Chaos Revenge Animations: Download (Replaces the Animations with Chaos Revenge Animations) (Thanks to Thepsyntyst for Animations)
AOKP 21: Download(Sphere Battery) (Removed Status Bar Notification Dimming)
AOKP 21: Download(Speedo Battery) (Added 100% Battery, Removed Status Bar Notification Dimming)
AOKP 21: Download(Blue Android Battery) (Added 100% Battery, Removed Status Bar Notification Dimming)
AOKP 21: Download Transparent (Sphere Battery)
AOKP 21: Download Transparent (Speedo Battery)
AOKP 21: Download Transparent (Blue Android Battery)
AOPK Milestone 2: Download
Alle Credits gehen an dustinb17 von RootzWiki und seine fleißigen Helferlein :)
Spenden and dustinb17--> HIER KLICKEN
Gefällt mir von den Screenshots her sehr gut. Ich glaube ich werde das Heute Abend mal ausprobieren.
Ich frage mich nur gerade, kann ich die Version die für AOKP B23 gedacht ist, auch mit der M3 nutzen?
Edit: Frage hat sich gerade erledigt... Wenn man weiter runterscrollt, findet man auch die Versionen für ältere ROM's :)
Aber immer schauen, ob für GSM. Meistens ist das so aber ohne Gewähr. Nandroid empfohlen. Ich selbst habe nur die ARHD ausprobiert!! Wenn Du es weißt kurz posten und ich werde es ergänzen!!
Edit: AOKP funktioniert!
Hallo, bei mir funktioniert das Theme für AOKP M3 nicht....
nach einem Reboot habe ich keine Softkeys und keine Dropdown Leiste mehr...
Habe ich irgendwas falsch gemacht?
Ansonsten würde ich gleich mein Nandroid zurückspielen
Okay, auch mit Dalvik und Cache Wipe besteht bei mir weiterhin dieses Problem.
Ich spiel mein Nandroid zurück und such mir ein anderes Theme ;)
Es gibt ja auch diverse Versionen. Das hier zum Beispiel: AOKP Milestone 3: Download Sphere Battery & Little Android Battery, Transparent Status and Navigation Bars, Removed Notification Dimming
Das könntest Du probieren oder halt restoren :)
@ wemsinho
Ich habe die transparente Version ausprobiert. Villeicht war das der Fehler.
Jetzt muss ich aber erstmal weiter arbeiten :p
Eventuell versuche ich es Heute Abend noch einmal.
Hi.
Ich habe das blaue Themes schon länger auf meinem GN (AOKP) und bin sehr zufrieden. Jetzt habe ich auf das GN meines Bruder auch AOKP geflasht und wollte ihm das rote Themes installieren. Ging soweit außer daß die Navigationsleiste nicht die Farbe angenommen hat. Um einen Fehler auszuschließen habe ich bei meinem auch mal die Farbe geändert. Jetzt geht bei mir auch nichts mehr. Hab deinstalliert, neu installiert, öfter neugestartet und und und. Es geht einfach nicht. Könnte evtl jemand die Navigationsleiste in Rot und Blau uppen oder andersweilig helfen?
Nachtrag: Mein Bruder hat es rausgefunden. Bei der Farbauswahl muß #00000000 stehen.
links sind alle tot...
Was mir aufgefallen ist, ist das Buttons im Playstore nicht exakt passen. Sie schließen nicht komplett ab. Aber sonst perfekt :):thumbup:
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
MoRtAl
Pierro
Pierro
Pierro
jenso77
  • jenso77
jenso77
jenso77
