Chuwi Hi12 (Dualboot) Neues BIOS released (Wifi/Battery fix)
kwisi
Gast
[Official Version][Dualboot] Chuwi Hi12 Android + Windows10 + Bios + driver - Firmware - Chuwi Forum - Forum.chuwi.com
Tutorial zum flashen von DigitalMD:
READ THIS: Make very SURE you have the correct BIOS for your device. Flashing the wrong BIOS WILL BRICK your device and make it unbootable.
CHECK AGAIN
1. Get an empty USB thumb drive.
2. Format USB drive FAT32, name it WINPE
3. Extract all files and then Copy all the files from the BIOS .rar onto the USB drive. Your USB drive should look like the picture below all files at the root directory.
If your BIOS is already set to boot USB thumb drive as 1st prioroty, then the deivce will go directly to step 5 automatically
4. Boot into BIOS boot manager using F7 key
5. Select and Boot the USB thumb drive
6. New BIOS will be flashed, the script doe snot exit properly so you will see an error about IA32, but it is finished correctly. Remove the USB drive once BIOS flash is complete. You can type exit here or just hold down the power button
7. Remove the USB drive once BIOS flash is complete. If you leave it in, then BIOS will be flashed again on boot.
Ulrich B.
DarkAngel
DarkAngel
Luise33
Luise33
Luise33
O
Wattsolls
Wattsolls
