[FLASH-ABLE MODS][JAN 08][5.1.1][UNIVERSAL]G-FLEX2-MODS-V1.5 by bountyman334
HenkerLenker
HenkerLenker
Dauergast
113
Bravia Engine v4 - X-Reality Engine v4
This rom is the product of 5.1.x Lollipop Linux 3.10.x STOCK Testing 1 2016-01-07 2015-12-21 2016-01-07
Code:
#include
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
The Sony Mobile BRAVIA Engine 4 is a video enhancement program for Sony phones. It uses filters and algorithms to create a clearer and more contrasted picture and an overall smoother experience. This is perfect for the huge HD screen but can be a little to saturated for people like photographers who want to see how the photo looks exactly with out any enhancements. The change is not huge but is definitely noticeable if two devices are compared.​
-CHANGELOG-
Code:
××××××××××××××01/08 [V1.5]××××××××××××××
××-FIXED FONTS
××FIXED GRAPHICS GLITCH
××ADDED GPU MOD TO LIBS
××××××××××××××01/07 [1st]××××××××××××××
×××INIT.D SUPPORT ON LOCKED BOOTLOADER(SCRIPTS THAT RUN AT BOOT]
×××LATEST BUSYBOX INSTALL PLUS BATTERY SAVER INSIDE XBIN
×××15+ FONTS
×××REMOVED SPRINT BLOAT...EVEN HANDS-FREE POP-UP[NEXT-TIME]
×××V10 APPS AND BUILD.PROP MODS
×××HIGHER VIDEO RECORDING BIT 60 FPS
×××SELINUX SET TO PERMISSIVE FOR FULL ANDROID CONTROL
×××USERS MOD FROM CM
×××TEXT-A-LINK FROM G PRO 2
×××UNLOCKED FULL 60 FPS MOD
×××NEWEST GOOGLE EMOJI...
××××I HAVE MORE COMING...AM JUST NOT TRYNA BRICK AGAIN...SO PLS BARE WITH ME....××××××
[CENTER]
IF YOU HAVE TROUBLE WITH CALLERS HEARING YOU ....
[A]------- Settings > Call (under Networks) > activate Noise Suppression
-------- Go to GOOGLE SEARCH >google card settings -> Voice -> "Ok Google" detection
Turn off "From Any Screen"
:::::::::STOCK-LOLLIPOP FLEX 2 [1ST]:::::::
-----------------------[FLASHING STEPS----VIA FLASHFIRE APP]---------------------------------------------------
[1]--DOWNLOAD FLASHFIRE & INSTALL
[2]--MAKE SURE YOUR CURRENT SYSTEM IS BACK-UP TO INTERNAL STORAGE [SYSTEM.IMG]
[3]--DOWNLOAD G-FLEX2-MODS-V1 FROM DOWNLOADS OR HERE
[4]--AFTER FLASHFIRE REBOOTS CHECK INTERNAL STORAGE FOR THESE {Everything-Wrkn.txt}{Cleaner.txt}...
BOUNTYMAN334!!
XDA:DevDB Information
DOWNLOAD:
[XDA]:::[LS996]:::::FLASH-ABLE MODS V1.5 STOCK-LOLLIPOP FLEX 2
[MEGA]:::[LS996]:::::FLASH-ABLE MODS V1.5 STOCK-LOLLIPOP FLEX 2
[XDA]:::::::[H995[::::::FLASH-ABLE MODS V1.5 STOCK-LOLLIPOP FLEX 2
[MEGA]:::::::[H955]:::::FLASH-ABLE MODS V1.5 STOCK-LOLLIPOP FLEX 2
Er uppt grad ne neue Version die wohl die Grafikbugs behebt...
Werde es hier dann aktualisieren ;)
Scheint aber nicht bei allen er Fall sein. Ich habe keine Probleme bis jetzt feststellen können außer man versucht die letzte Xposed Framework zu installieren dann heißt es BOOTLOOP ohne ende :p
V2...COMING SOON
Hatte letztens durch div probieren ein Problem das das Flex nicht mehr booten wollte. Habe dann den ganzen Aufwand mittel Stock .kdz und erneuten rooten machen müssen. Würde gern mal diesen mod testen aber habe bedenken das es wieder irgendwie hängen kann. Meine Frage, gibt es eine Möglichkeit das derzeitige (gerootete) System als .kdz zu sichern um es letztlich per LG Flashtool wieder einspielen zu können. Kann man gegf ein Recovery installieren (TWRP). Damit sollte es ja auch gehen. Danke für Hinweise bzw Links.
frank42502
DerUneinsichtige
  • DerUneinsichtige
1907
1907
  • frank42502
frank42502
