Flash und Root Anleitung MK809
serv-r
serv-r
Hallo Neptune23, danke für Info.
Da steht HTC-T002-V0- das heißt das die Software für MK809 Passt- sehr überaschend gut! hab den für 45 eur gekauft inkl. versand von deepin-de !!!
Die Flashanleitung über MK809 / T002 Smart TV (Typ HTC-T002-V0) stimmt nicht so ganz im vorherigen Beitrag.
und die beiden Links von "Tool & kurze Anleitung, Treiber" funktionieren nicht.
Anleitung
[Rooting]
Only needed if you want to run root access apps (Driodmote, VNC server, Set DNS etc..)
I followed the instructions on XDA Developers but ran in a little problem so I've rewrote them here.
1) Install Android SDK - Install only the 2 support packages - USB Drivers and platform support. - Download here
Edit you system variables PATH string (located under system properties) and add on the <Andriod SDK> - platforms-tools directory
2) Download the attached files on the forum post ***
3) Add lines to the file located in <Your Android SDK location>\extras\google\usb_driver\android_winusb.inf
Under the [Google.NTx86] and [Google.NTamd64] section:
Code:
; WINDOW/YUANDAO MK809
%SingleAdbInterface% = USB_Install, USB\VID_2207&PID_0010
%CompositeAdbInterface% = USB_Install, USB\VID_2207&PID_0010&MI_01
4) Connect the USB DC port to your computer USB port (I found using my laptop with the TV stick still in the television the easiest way to do this)
5) Once the MK809 is powered up turn on USB Debugging under Developer Settings and allow installations from unknown sources under Security settings.
6) Start the Installation of the PDA.net (ADBDriver) drivers.
Select Other for the type of device you have when prompted.
When prompted to plug your device use the "Connect to PC" option under Settings->USB on your MK809.
In the android status bar a little Jelly Bean icon should display saying you are debugging applications via. USB.
Close down the PDA.net driver program that is now running in your Windows system tray.
7) Extract the TPSarky 7zip file and run the TPSarkyRoot.bat
This will reboot the device 3 times, after each reboot you need to go back in to settings > usb > Connect to PC. before continuing.
If this worked, Your Rooted!
8) Visit the app store and install Super User.
Das ist nur Copy Past Anleitung von XDA... , nach der Anleitung habe ich meine Software gerootet- hat gut funktioniert, trotz dem übernehme ich keine haftung über ev. enstehende Schäden.
MFG
Hallo Serv-R,
ich weiss, dass die Links nicht funktionieren. In der Übersicht der Modelle kann ich leider nichts ändern. Nur der Ersteller, Heikonet, kann die Links korrigieren.
Meine Dongles habe ich mit dem Zhoudashi tool über Windows innerhalb weniger Minuten gerootet. Habe es auch zuerst mit dem SDK probiert. Habe aber eine schnellere Alternative gewollt.
Danach habe ich geschaut, welche Root-Methoden sonst noch für RK3066-Devices angeboten werden.
Mit der Anleitung zum Rooten des Teclast A10 Tablets hat es bestens geklappt (google: rk3066 root teclast a10). Das Tool ist halt komplett Chinesich.
Den nötigen PDAnet Treiber hatte ich von XDA, aus dem von Dir verlinkten Post.
Moborobo hat zwar auch gemeldet, dass der Rootvorgang erfolgreich war, aber der Check mit RootChecker war negativ.
Rooten erfolgt immer auf eigene Gefahr!
Habe mittlerweile über stick Praktische Informationen gesammelt,
Muss sagen das die Optional angebotene Software von der Seite MK809 MINI PC GOOGLE TV
Viel besser läuft, übersichtlicher ist als die im ausgelieferten Zustand war (ist natürlich Geschmacksache), aufgefallen ist mir noch dass der Stick minimal wärmer wird, weil durch die Soft die volle 1.6 Ghz ausgenutzt werden.
Flashen der Firmware: MK809 / HTC-T002-V0
Auf die Webseite MK809 MK809II MINI PC GOOGLE TV wird auch ein Tool mit zusätzlichen Treibern zum Flashen eine neue Firmenware angeboten (MK809 Recovery instruction and tools). Tool ist auf Chinesisch und Englisch einstellbar, dazu muss man im Ordner „mk809 recovery tool“ die config.ini bearbeiten: Lang1File=Chinese.ini auf die Lang1File=English.ini umbenennen, abspeichern, fertig.
Zum flashen muss der Stick am Fernseher über HDMI angeschlossen sein.
Verbindung normal zwischen Laptop/PC per MicroUSB Kabel herstellen-( dass der Dongle Strom vom PC/Laptop kommt).
Startet ganz normal den Dongle, im Einstellung Menü / In den "USB Einstellungen" des Dongle "Connect to PC" einstellen.
Dann die Treiber für Euer Betriebssystem Win 32 oder 64 Bit installieren(geg. wird automatisch installiert-Internet Verbindung erforderlich)
Startet das RKBatchTool.exe, Conectet Devices müsste (1)in Farbe Gelb erscheinen
Den Button Switch anklicken, das System versucht neue Treiber installieren, vergeblich, die Treiber über Geräte-Manager installieren, die Treiber befinden sich im RockusbDriver Ordner.
Wen die Treiber installiert sind, muss unter Conectet Devices Symbol 1 jetzt in Grün dargestellt sein.
Im Tool FW Path zum Firmware browsen, .img Datei auswählen und Upgrade Button drücken, warten bis neue Firmware geflasht wird.
Updates installieren:
Packt den Update.zip in den Root Verzeichniss euren Dongle
Dongle "Connect to PC" ausstellen.
Android System fragt dann ob Updates Installiert werden
Bestätigen, und abwarten.
Bei mir hat es alles wunderbar funktioniert, dennoch übernehme ich keine Haftung über ev. entstehende Schäden.
Moin
ich hab auch den gleichen stick aber hab immer noch das problem was die richtigen schritte sind.
Die treiber sind schon auf meinen Rechner und funktionieren auch bestens.
hab auch schon das MK808 finless 1.6 ROM einmal drauf gespielt/geflasht.
Aber ich werde nicht schlau wie ich später Ubuntu.....picuntu..... etc booten kann -.- . Ich habe schon viele fohren durchsucht und bin auf keinen richtigen tutorial gestossen was mir zum linux boot geführt hat.
hat jemand eine anleitung die schritt für schritt beschreibt was ich machen muss soll bis ich linux von einer sd karte booten kann ?!?
vill ein rom was schon fertig ist oder sowas änliches ?!?
bin schon an verzweifeln. weil das dingen ist einfach hart hartnäckig XD
DBox2 war Kein prob
Xbox 360 Kein prob
Wii Kein prob
aber dieses kack dingen kriege ich nicht hin -.-
Ich danke schonmal in vorraus:thumbsup:
Ich bedanke mich :thumbsup::thumbsup::thumbsup:
Die seite hab ich mal aufgerufen gehabt aber nicht genau gelesen.
ich habe immer vergessen die recovery zu flashen :angry:
so aber jetzt funktioniert es bestens.
Noch mal tausend dank an euch
guten morgen an alle und hier bin ich wieder
ich habe kein dual boot und ich weis nicht wie ich den kernel unter linux flashen kann -.-
Habt ihr ne ahnung wie es geht ?!?
Hilfe!!! Mk 809 Habe neuste Firmware drauf gemacht nur der App Spreicher von 1GB auf ca. 504MB geschrumpft WARUM? was habe ich falsch gemacht ?
Auslieferung zustand
CPU: RK3066 DualCore 1.2Ghz
Ram: 1GB
Interner Speicher: 4GB
OS: JB 4.1.1
Hersteller: mk809.com
Hallo Navik,
das mit den 504MB ist richtig. Hast nichts falsch gemacht.
Beim Original ROM ist der interne Seicher insgesamt 1GB gross. 504MB hast Du frei für Apps. Den Rest belegt das Betriebssystem.
Mehr Speicher für Apps bietet z.B. Finless ROM 1.7. Hier können bis zu 2GB als interner Speicher zugewiesen werden (ca. 500MB Android, ca. 1.5GB Apps).
Gruss, Neptune
Hallo Leute, ich habe ein Probleme mit meinem MK809ii, Rockchip 3066.
Treiber sind alle vorhanden.
Und zwar wenn ich denn Stick ins Recovery starten mag, sagt er mir “keine eingabe“ und das Android Männchen liegt dabei auf dem Rücken mit offenen Bauch, darüber erscheint ein rotes Warndreieck.Ich würd jetzt aus dem Stand sagen das kein stock recovery vorhanden ist. Was mich jetzt aber brennend interessiert ist wie bekomme ich SuperSU binary installiert... ich habe es bereits mit den rkflashtool probiert und mit der SFSparky.bat von xda und auf den Bug in der .bat habe ich auch geachtet. Aber beim letzten von 3 Bootvorgängen zeigt er mir am Laptop das SU installiert wird jedoch ist der Tv Stick dabei im laufenden Betrieb, des kommt mir schon spanisch vor, in dem original thread bei xda steht das ich auf eine fehlende zeile in der .bat achten soll aber wenn ich editiere ist genau diese schon vorhanden Gibt es vielleicht noch einen anderen weg?
O
hagex
hagex
Droijaner
  • Droijaner
Droijaner
Droijaner
  • haare-raufer
kaputnik33
kaputnik33
