Layout performance probleme
  • 3 Antworten
tim1602
Hi, ich bins wieder,
Ich hab massive Probleme mit der Performance meines Layouts:
Das Layout sieht wie folgt aus:
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="vertical" android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:background="@drawable/hintergrundbild">
    <LinearLayout
        android:orientation="horizontal"
        android:layout_gravity="center_horizontal"
        android:layout_weight="4"></LinearLayout>
    <LinearLayout
        android:layout_weight="1">
        <LinearLayout
            android:id="@+id/llKLkg3d">
            <include
                android:layout_width="fill_parent"
                android:layout_height="fill_parent"
                layout="@layout/getnormdata_dialog_layout_row" />
        </LinearLayout>
        <LinearLayout
            android:id="@+id/llKLga3d">
            <include
                android:layout_height="fill_parent" />
        </LinearLayout>
        <LinearLayout
            android:id="@+id/llTiStFVK_Kombinationen">
            <include
        </LinearLayout>
    </LinearLayout>
</LinearLayout>
Hier das Layout welches inkludiert wird:
    android:layout_height="match_parent">
    <LinearLayout
        android:layout_weight="1" >
        <RelativeLayout
            android:layout_weight="2">
            <TextView
                android:layout_width="wrap_content"
                android:layout_height="wrap_content"
                android:textAppearance="?android:attr/textAppearanceMedium"
                android:text="Titel(se)"
                android:id="@+id/incTvTitle"
                android:layout_centerInParent="true" />
        </RelativeLayout>
        <LinearLayout
            <LinearLayout
                <RelativeLayout
                    <TextView
                        android:textAppearance="?android:attr/textAppearanceSmall"
                        android:text="Bohrungsgroesse (se)"
                        android:id="@+id/textView20"
                </RelativeLayout>
                <LinearLayout
                    <LinearLayout
                        <RelativeLayout
                            <TextView
                                android:text="Min (se)"
                                android:id="@+id/textView21"
                        </RelativeLayout>
                        <RelativeLayout
                            <TextView
                                android:text="Max(se)"
                                android:id="@+id/textView22"
                        </RelativeLayout>
                    </LinearLayout>
                    <LinearLayout
                        <RelativeLayout
                            <TextView
                                android:text="Small Text"
                                android:id="@+id/incTvBohrgrMin"
                        </RelativeLayout>
                        <RelativeLayout
                            <TextView
                                android:id="@+id/incTvBohrgrMax"
                        </RelativeLayout>
                    </LinearLayout>
                </LinearLayout>
            </LinearLayout>
            <LinearLayout
                <RelativeLayout
                    <TextView
                        android:text="Passung(se)"
                        android:id="@+id/textView25"
                </RelativeLayout>
                <LinearLayout
                    <LinearLayout
                        <RelativeLayout
                            <TextView
                                android:text="Spiel(se)"
                                android:id="@+id/textView26"
                        </RelativeLayout>
                        <RelativeLayout
                            <TextView
                                android:text="Press (se)"
                                android:id="@+id/textView27"
                        </RelativeLayout>
                    </LinearLayout>
                    <LinearLayout
                        <RelativeLayout
                            <TextView
                                android:id="@+id/incTvPassungSpiel"
                        </RelativeLayout>
                        <RelativeLayout
                            <TextView
                                android:id="@+id/incTvPassungPress"
                        </RelativeLayout>
                    </LinearLayout>
                </LinearLayout>
            </LinearLayout>
        </LinearLayout>
    </LinearLayout>
</LinearLayout>
Wäre super wenn jemand der Erfahrung mal drüberguckt warum das Layout so träge ist.
Danke im voraus!
Hinweis des zuständigen Moderators: Bitte Code-Fragement in den Code-Tag packen, sonst ist es furchtbar zu lesen
@tim1602
Dein Problem liegt in der reichlichen Benutzung des Node android:layout_weight. Das muss alles berechnet und gezeichnet werden.
Sprich Dein Layout ist viel zu verschachtelt. Versuche ein einfacheres Layout zu benutzen
Schade, Hatte ich mir schon fast so gedacht....
Hättest du ne Idee wie ich das gleiche Layout, bzw nen ähnliches Layout, erzeugen kann so das es performanter ist?
Über nen relative Layout?
Jedoch sollten die Komponenten auf jedem Smartphone Bildschirm im Verhältnis gleich groß sein.
Danke auf jeden fall schon mal!
