Aram95
MIUI.us v4 ICS
This Build is for Xperia and it's from me ideosdev@MIUI.USV4 on MiniCM9 4.04
This is an pre-alpha build(Testing) and don't complain thing don't work
I don't this little device to do testing or more
Like the Xperia X8 Miuiv4 as i build is depending on skill and not tested
You can help me by Donating me to buy me a Xperia X10 Mini
Any donation or can be made to me or over forum at miui.us (IdeosDev) /Twitter: @IdeosDevZack
Working ::Latest Xperia X10 MINI
Requirements:
Installation
ICS Kernel Link: [KERNEL] nAa-ics-04 [5/7/12] Custom ICS kernel + CWM Recovery - xda-developers
- Boot
- Touchscreen
- MIUI Apps and Launcher
- Sd-Card
- Wifi
- Sms and Call -2g/3g
- Bluetooth
- Accelerometer
- Audio
- headphone
- Superuser root updated and works
- Installing Apps
- GPS
- Virtual Keys
- Led
- Brightness
- Sensors
- Charger
- Camera
- USB Connection
- Browser
- Other's
Requirements:
- Latest 2.1.1.A.0.6/2.1.1.C.0.0 SE firmware / Baseband: M76XX-TSNCJOLYM-53404015
- Unlocked bootloader
- Latest version of the ICS nAa kernel
Installation
- Download the update-MIUI-xxx.zip from the release link that follows
- Backup your /data contents: contacts, apps, sms, etc. or backup via recovery
- Move the update-MIUI-xxx.zip to the root folder of your sdcard.
- Make sure you are using the nAa-ics kernel
- Enter CWM and:
- - Select 'backup and restore -> Backup'
- - Select 'wipe data/factory reset' (MUST DO)
- - Flash the zip. To do this, Select 'install zip from sdcard -> choose zip from sdcard' and select the update-MIUI-xxx.zip
- - Flash gapps if you want them!
- Reboot (first boot will take ~2 mins)
