WarpigtheKiller
DarkForest Sensation XE 6.5.0
Before flashing this ROM, you NEED to upgrade your firmware to 3.32.401.105
Features:
- One ROM for all - Sensation 4G/Orange U.K/XE versions all in one ROM with the interactive setup in 4EXT Recovery (madmaxx82) and Aroma Installer (by amarullz)
- Completly re-done from the 3.32.401.5_R and 3.32.401.105_R HTC RUU (thanks Football
- Based on Ice Cream Sandwich (Android 4.0.3 + Sense 3.6)
- Dice App works - The FIRST Sensation XE based ROM to support a fully functional Dice App
- Optimized and zipaligned apks with newest SDK R19
- Removed Debugging Info from apk's - makes the dalvik cache smaller + faster (Huge thanks to mudhi for the program)
- ZipAligned on boot for max RAM efficiency
- Newest Busybox installed (1.20.0)
- Lots of speed tweaks
- Sony Bravia Engine
- Removed all HTC Bloatware/junk apps
- youtube fixed
- newest market and other standard apps like facebook, twitter etc
- Full init.d support - busybox run parts
- Updated SuperUser to latest apk and binaries
- Updated and moved to /data/apps all 3rd party apps (like Facebook, Dropbox etc.)
- Included AdAway
- Updated Hosts
- init.d tweaks - mixture of LeeDROiD, baadnwz and virtuous - Thanks guys
- Beats Audio with more bass - libbeatsbass.so file from Rezound ICS Leak
- Virtuous setup scripts
- Completly Removed HTC OTA software update stuff - doesnt work in custom ROM
- Added Bash Support
- Added Nano, sysrw, sysro
- Added Build.prop tweaks for general speed and responsivness
- Fixed the downanimation bug where it ran at 15 FPS and stuttered, new one runs at 30 FPS
- Lots of Stability tweaks
- WiFi Calling
- Added Tmous ICS support
- Added option of Orange UK signal boost in setup
- Fixed Tiny MMS
- Huge amount of XML cleanups
- Stock % Battery
- Added Blue Overscroll
- Added CIFS and UTF8 modules (thanks LEEDrOiD)
- HTC Quietly Brilliant Black boot/down animations included
- Advanced Power Menu (ALL credits to capychimp for the hours of hard work he put in to make this mod!)
- Wake Up by Volume Key mod (compatable with APM - capychimp/robocik)
- Added Extended Quick Settings v3.20 mod by j4n87
- Using Aroma Installer - by amarullz
- Support for OTA Updates via the DarkForestROM Updater app (Thanks to KeiranFTW)
- You tell me?
- Huge thanks to user homeworlder for providing me with an FTP account
- robocik and capychimp for the base ROM and RUU's - thanks soooo much guys
dsixda for the excellent kitchen - baadnwz, robocik, capychimp, LeeDROiD, showp1984, faux123, ChainsDD - all you guys got me interested in joining in the developing
- any other member who has helped me or who i cant remember right now, thanks a lot guys
Download
DarkForest Sensation XE ICS 6.3.2
v6.3.2 MD5 CheckSum: D7B60490A7D9C66D800621A98FA1C763
- For v6.3.2 DO NOT Super-Wipe because it is Incremental
- For v6.3.1 Super-Wipe is optional but highly recommended
This ROM comes courtesy of The DarkForest Group
Banner (made by n7of9 - thanks a lot
) - for users who wish to show support for my ROM
Donors List - Many thanks to all, very much appreciated
- goatee84
- Isis111
- teknomar7
- budeone
- Astrates
- sugarray21
- vernon092487;24975289
- emjaytee
Sharing Policy
I reserve no rights on the content of this ROM as all of it (aside from some libs and Aroma Installer) originally came from HTC.
You may use any files includes in this ROM and have permission to mod them yourself
All I ask is that if you use something which you yourself did not port/make (eg, Dice App on XE versions) that you credit the ORIGINAL modder (in this case me)
Change Log:
v6.5.0 - 28th July 2012 (Full ROM)
- Fixed Boot issues (I hope again!)
- Redone completely from the 3.32.401.105_R2
- Used memnoc's RAM hack - memnoc
- Merged Tmous Exchange Fix
- Re-ZipAligned with latest SDK Release
- Hopefully fixed boot issues with superwipe, If issues still persist I need aroma log so please save the log file within aroma
- Updated bricked kernel to v1.31 - showp1984
- Rebased to 3.32.401.105_R2 RUU - Thanks Football for the RUU
- Fixed tweaks
- Merge some more Tmous stuff
- Fix issues with build.prop files
- Added XLOUD system - Thanks darkmantra
- Updated Bravia Engine - Thanks XxXPachaXxX
- Updated SuperSu to v0.92
- Re-added HQ camera mod
- Fixed issues with init.qcom.post_boot.sh
v6.3.2 - 22nd May 2012 (Incremental Update)
- Fixed Tweaks icon in settings
v6.3.1 - 18/19th May 2012 (Full ROM)
- Hopefully fixed tweaks clock bug
- Added Tmous ICS files
- Fixed Orange UK and Sensation Build.prop
- Added HQ Camera 1.5 - Nando-GT
- Added Amaze Camera v2 by Steve0007 & chrisd1a1
- Updated BusyBox to v1.20.0
- Fixed some errors in init.d scripts - Better Battery life
- Re-ZipAligned all apk's
- Fixed Aroma typos - now flashes correct options
- Fixed all bugs I am aware of
v6.3.0 - 14th May 2012 (Full ROM)
- Updated Tweaks to v4.3
- Updated Bricked Kernel to v1.1
- Disabled fast dormancy – baadnewz
- Added Orange UK XE option
- Re-enabled Bass boost & Bass Enhance
- Added Amaze Camera v1 by chrisd1a1 and Steve0007
v6.2.0 - 13th April 2012 (Full ROM)
- Fixed several bugs
- Added Tweaks v4.0 - m0narx
- Updated AdFree
- Updated Hosts
- Added Bricked Kernel(s) 0.856
- Major overhaul of Aroma
- ZipAligned with latest SDK R18
- Added Multi-Langauge Support back
- Based off 3.32.401.105_R RUU
- Included newest Settings OTA
- All previous tweaks/mods/addons included
- Much more I forgot (I hate having a crap memory lol!)
- Generally Better and more awesome
v6.1.0 - 14th March 2012 (Full ROM)
- Rebased from the new 3.32.401.105 RUU - Thanks to Mike1986.
- All Previous mods that are still compatible have been included.
- All previous tweaks/mods/customizations have been included.
- Fixed Unknown Sources Issue.
- Fixed No Status Bar Issue.
- DarkForest OTA App updated (Thanks to KeiranFTW for the app)
- Lots more I have forgotten.
v6.0.0 - 8th March 2012 (Full ROM)
- Rebased from the new 3.32.401.5 RUU - Thanks to Mike1986 and rmk40 for the bases
- Re-Created an XE ROM from the NON-XE base
- Cleaned the ROM
- XML Cleanups
- Removed Debug Information from APK's (thanks mudhi for the batch files)
- Added EQS 3.2.0 mod by j4n87
- Added APM mod by capychimp
- Added option for stock battery (No Percent)
- Added OverScroll and Battery % mods
- Using latest Aroma Installer build
- boot.img tweaks
- Re-Hex Hacked the CIFS and UTF8 modules for the new kernel
- Fixed ALL Issues/bugs I am aware of
- Included Beats Mod 5.1 by mudhi
- Used 2 APK Optimisation Script
- Fixed APM Issues
- Changed Updater-script and Aroma config for better stability
v5.5.0 - 26 February 2012 (Full ROM)
- Rebased from the new 3.30.401.101 RUU - Thanks baadnewz for sharing and Mike1986 for the RUU
- Cleaned the ROM
- XML Cleanups
- Any mods Incompatible have been removed (Keyboard arrows/non-paginated Rosie etc)
- Added EQS 3.2.0 mod by j4n87 - ported by baadnewz
- Added APM mod by capychimp - ported by baadnewz
- boot.img tweaks
- 1.5 GHz Kernel thanks to SebastianFM
- Updated Hosts file
- Updated YouTube
- Updated Twitter
- Updated Facebook
- Updated AdAway
v5.3.0 -20 February 2012 (Full ROM)
- Hex Hacked the CIFS and UTF8 modules for the new kernel
- Cleaned updater-script to hopefully get rid of errors
- Hopefully Fixed stupid WiFi issue's user's keep having (yet again lol)
- Added option for Pure Stock Battery (No percentage)
- Added option for keyboard arrows (jerrytan93)
- Added option for non-paginated rosie
- Changed and Added some init.d scripts - more optimizations
- Updated ES File Explorer
- Update YouTube
- Updated FlashPlayer
- Updated Google Maps
- Updated Facebook
- Updated AdAway
v5.2.0 - 12 February 2012 (Full ROM)
- Added Support for Updates via the DarkForestROM Updater app (Thanks to KeiranFTW)
- Added a new and better libbeatsbass.so from the newest Rezound ICS Leak
- Fixed Dice app - The FIRST ROM based on an XE RUU to support Dice app
- Fixed Wake By Volume Rocker (Yet Again!!!) - Tested and fully working this time
- Updated Market Apps
v5.1.5 - 9 February 2012 (Full ROM)
- Added Extended Quick Settings v1.5 - by j4n87, huge thanks
- Fixed Small MMS issue (thanks to the testers )
- Removed some more useless stuff to make the ROM lighter
- Fixed Wake by Volume Key not working (Thanks to ziggy1001 for making it)
- Adapted some init.d script from here http://forum.xda-developers.com/show....php?t=1227269
- Many more tweaks added over the weeks that i cant remember right now
- No this version does not use Aroma Installer (yet) still a few things to do to get it perfect
- Super-Wipe is HIGHLY RECOMMENDED because of the MMS Fix - Explanation see here http://forum.xda-developers.com/show...&postcount=416
v5.1.0 - 31 January 2012 (Full ROM)
- Added Advanced Power Menu - by capychimp, huge thanks
- Added a couple more beats related files for a better sound
- Added option to use mudhi All Sound Effects mod (Beats_ICS_4.5 on his thread)
- Added Wake by Volume Key mod (compatible with ICS)
- Removed some more junk that the user never ever see's (its just part of the jpgs in the customize folder that are never visible unless using Root Explorer etc)
- Lots of other fairly minor tweaks/fixes for stability and performance etc
- Any user with WiFi issues, it is not the ROM, just ICS in general (see here: http://forum.xda-developers.com/show....php?t=1445766)
v5.0.0 - 28 January 2012 (Full ROM)
- Rebased from 3.25.401.101 RUU (Thanks capychimp )
- Included CIFS and UTF8 modules (LEEDrOiD and hex edited by baadnewz)
- Fixed WiFi issues
- All my tweaks/optimizations from previous builds
- Added option to install 1.5 GHz kernel (SebastianFM)
- Added option to install an older Rosie.apk (fixes HTC Sense Force Close Issues)
- Added option for HTC Sense Holo (Green) thanks to omar302
- Beats Audio with more bass - using libbeatsbass.so from Rezound
- Version bump to avaoid confusion with Android OS versions
- Super-Wipe is Highly recommended due to new base
v3.2.1 - 16 January 2012 (Full ROM)
- Fixed Beats Audio Notification on Sensation XE build
- Added option to install Beats Audio ICS mod in recovery (Sensation User's only - It is Automatically installed for Sensation XE user's)
- Added WiFi Fix - Untested since I live in England I have had no WiFi issues
- Fixed Orange UK signal Loss - Untested because I am on O2, not Orange
- Added my Beats Audio ICS 2.0 mod - enhanced bass
- Build.prop tweaks for extra dalvik cache heapsize and general responsiveness - thanks baadnewz
- Improved my Updater-script (It was getting far too complicated to write more code so i cleaned it out - It is still interactive though )
- Added a Tmous apk file for Sensation 4G User's - thanks baadnewz
- Cleaned and Improved the ROM Structure
- Removed conflicting lines of code in build.prop to maximize performance
v3.2.0 - Full ROM
- Re-based on the NON XE RUU as well as the XE RUU - To enable an all-in-one ROM (The first ROM do do so )
- Fast and Smooth as HELL
- Dice app works
- Sensation /4G/Orange U.K/XE verisons included!
- Sensatin XE has beats Audio, for sensation user's, if they want Beats, just flash the Beats Audio ICS mod in my signature
- Fully-Working, no boot issues like other versions
- Added a fully working smooth stock % battery framework-res.apk (Thanks Wanhao for the original file)
- Added Green overscroll
- Same as in other version's (ZipAlign, Nano, Bash etc)
- Removed init.post_boot.sh file to comply with mike1986's wishes (its kinda useless on stock kernels anyway and doesnt do anything init.d scripts wont )
v3.1.1 - Incremental Update
- Added Green Overscroll in Framework-res.apk
v3.1.0 - Full ROM
- Fixed slightly slow downanimation - now runs at 30 FPS
- init.d tweaks - mixture of LeeDROiD and baadnwz
- Stock % Battery - thanks to gbzbar
- My Beats Audio ICS Mod
- Other minor fixes and tweaks i forgot
v3.0.0 - Full ROM
- Completly re-done from the 3.12.401.102 XE RUU (Beats Audio)
- Based on Ice Cream Sandwich (Android 4.0.3 + Sense 3.5) (thanks Baadnwz for RUU )
- Optimized and zipaligned apks with newest SDK R16
- Newest Busybox installed (1.19.3)
- Sony Bravia Engine (thanks to an addon for ARHD - TripNRaVeR for the port and kevin001111 for telling me the user)
- youtube fixed
- Updated SuperUser to latest apk and binaries - Correct as of 01.01.2012
- Updated Facebook, Google Books, ES File Explorer, Adobe Reader, Flash Player - Correct as of 01.01.2012
- Updated Hosts file - correct as of 01.01.2012
- Interactive Updater-script flashing setup - Tanks mike1986 (I may not particually like you but i can still admire and make use of your work!)
- System Wide Volume Level tweaks - BIG thanks to mudhi for these
- Fixed the downanimation bug where it ran at 15 FPS and stuttered, new one runs at 24 FPS
- Fixed wifi calling - thanks to casper200519
- Added Tmous support
- Fixed Tiny MNS
v2.1.0 - Full ROM
- Fixed booting problems by using baadnwz's boot.img file as mine didn't seem to like being decompiled to add init.d support
- Re-done completely from the RUU again to fix some stupid bugs
- Zipaligned and RAM Optimizations (zipaligned with SDK 16)
- Nano support, sysro/sysrw
- Bash Support
- More useful build.prop tweaks and removed some useless and duplicated code
- Fixed the battery % problems by using AndroidManifest.xml, resources file, 2 xml files in drawable and the battery images from LeeDROiD's framework-res.apk
- Other minor tweaks and improvements
Danke Jonny für die Erlaubnis zum kopieren des Threads von [ROM]DarkForest Sensation/XE 6.3.2|Tweaks|Sense3.6|Speed|Beats|SuperStable[22 May] - xda-developers .
