GalaxyMax90
HINSWEIS:Flashen und Testen auf eigene Gefahr. Weder Ich noch Android-Hilfe.de übernehmen keine Haftung für Schäden und Probleme die durch das Flashen auftreten können und somit euere KONX-Counter von 0 Auf 1 getriggert!! wird somit besteht keine Garantie mehr.
Der Entwickler Hat auch vor die Rom immer auf Den neusten Stand zu Halten.
Changelog:
BeanStalk 4.4.275- 4/12/2014
Kernel updated
Set some GC parameters only for dalvik
base: Add blacklist provider permission
Frameworks: SlimRecents pass gesture detector to the cardslistview
Frameworks: add 1dp more bottom padding
Frameworks: SlimRecents: Make expanded layout pretty
Framework: Allow Power Notification Sounds For Wireless
Settings: Mock SMS
settings: Add blacklist provider permission
SoundSettings: Assigning a null to an unnecessary variable
cm: sepolicy: Allow ueventd to load WiFi and audio irmware
cm: sepolicy: Allow ueventd to properly handle cpufreq changes
Other cm stuff
BeanStalk 4.4.270- 3/18/2014
Home button to answer call ( setting ---> accessibility )
bump to beanstalk 4.4.270
Optimizing system app used ram
DeskClock: Support double-digit hours for timers
Don't fetch deleted messages from IMAP folder
audio: Added lock during closing of direct output
ifdef "stagefright: Enable GraphicBuffer usage to decoder before querying formats
Keyguard: Fix configuration change observer
Don't recreate keyguard for MCC/MNC changes.
FWB: Allow disabling of FC dialogs
Remove double tap, make long press to enable torch
Settings/Wifi: Add support for Ad-hoc (IBSS) networks
Fix resource IDs being added to the android namespace
Other cm stuff
BeanStalk Features:
CM based
Xposed framework
Gravity box
Temasek kernel as default
Custom unlock button
Halo
Lockscreen Notification
Lockscreen background options (Color fill, Custom image, Transparent)
Customizable Lockscreen text color
Lockscreen rotation
Option to enable all widgets
Minimize lockscreen challange
Use widget carousel
Slider Shortcuts
Static Lockscreen shortcuts
Lockscreen button actions
LCD Density
Scroll elasticity options
Default App grip option
Custom Carrier label
Dual Pane options
Customizable boot animation (off, default, set your own bootanimation)
BeanStalk Wallpapers
BeanStalk bootanimation
Status bar color and transparency
Clock and date options which includes color, location, style
Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
Breathing SMS option
Battery styles - Includes specific colors and styles. Also includes battery bar
Do not disturb option
Show notification count
Pie controls (need to have lockscreen background set to something other then default to work correctly (dont ask why) )
Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
Quick settings color settings, tiles per row, Quick pulldown, text color
Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
Keyboard and input method options which include disable full screen keyboard and auto rotate
Kil app back button with customizable timeout values
High end graphic effects option
option to disable/enable vibrate on expand for notifications alerts
Low battery warning customizable options
Recents RAM bar fully customizable with color styles
Clock widget for LockClock including extra options to fully customize every feature of the lockclock
Build.prop MOD options to enable/disable tweaks as preferred
Less frequent Notification sounds options
CRT screen off/on options to specify how the animation shows
Enable/disable wake up on charge option
Superuser fully embedded into the build and accessed from settings menu
CM Performance options and features
About BeanStalk option with links to github source and facebook for beanstalk. Also links to my twitter and donate.
insane amount of edits/tweaks/fixes to make this build absolutely fly
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Numerous other options hidding throughout the build
SPEN:
Für Alle die den S Pen mit der Rom benutzten wollen hat@Sakaschi
eine Anleitung geschrieben,wofür ich ihn nochmal´s Danken will
Zu Finden Auf seite 2,Beitrag #14
MOD´s VOM Entwickler:
Custom font
______________
DOWNLOAD LINKS:
Kernel-Einstellungen
Beanstalk Download Link
Vorher dran Denken ein EFS BACKUP zu machen
1)Backup
2)Wipe data,wipe cache,wipe dalvik,wipe system
3)Flash Rom
4)Reboot Phone
Auf die neuste BeanStalk Updaten:
1)Wipe cache,wipe dalvik
2)Flash Rom
3)Reboot phone
Was noch nicht Funktioniert:
scott.hart.bti for the rom
temasek for the kernel
BaNkS for gapp
C3C076 for gravity box module
XDA LINKS: [AOSP][CM11][4.4.2][ROM]BeanStalk UNOFFICIAL Build - xda-developers
Changelog:
Kernel updated
Settings: Mock SMS
Other cm stuff
Other cm stuff
BeanStalk Features:
CM based
Xposed framework
Gravity box
Halo
Lockscreen rotation
Use widget carousel
Slider Shortcuts
LCD Density
Dual Pane options
SPEN:
Custom font
______________
DOWNLOAD LINKS:
1)Backup
3)Flash Rom
4)Reboot Phone
2)Flash Rom
3)Reboot phone
BaNkS for gapp
