[TEST][ROM][4.2.2] CyanogenMod 10.1 for Samsung Galaxy SL (Experimental)
Mario1974
Mario1974
Hier habe ich mal die neue CyanogenMod 10.1 ROM für euch. Mehr infos und Testergebnisse heute nachmittag.
CyanogenMod is a free, community built, aftermarket firmware distribution of Android 4.2 (Jellybean), which is designed to increase performance and reliability over stock Android for your device.
Code:
#include <std_disclaimer.h>
 * Your warranty is now void.
 * I am not responsible for bricked devices, dead SD cards,
 * thermonuclear war, or you getting fired because the alarm app failed. Please
 * do some research if you have any concerns about features included in this ROM
 * before flashing it! YOU are choosing to make these modifications, and if
 * you point the finger at me for messing up your device, I will laugh at you.
CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. Linked below is a package that has come from another Android project that restore the Google parts. CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit out Gerrit Code Review. You can also view the Changelog for a full list of changes & features.
* PLEASE READ THE ENTIRE TOPIC BEFORE FLASHING THE ROM.
* THIS IS NOT AN OFFICIAL RELEASE BY DHIRU, IT IS BUILT BY ME WITH HIS CODE AND FIXES BY OTHERS AS BASE. DON'T BUG HIM OR ADI WITH PROBLEMS WITH THIS ROM UNLESS THEY'RE RELATED WITH THE KERNEL.
ROM Downloads
Download
Google Apps - Download from ROM Manager or from Here
Builds are hosted on my own build server and you could also see other builds. I make several builds a day to test new fixes, but they could not be usable. I'll just provide support for the builds posted here.
Changelog
Test 1 - 02272013 - Experimental (with 3.0 Kernel).
-This first release includes omapzoom 3.0.8 Kernel by Dhiru1602 and Adi_Pat.
-I've decided to label it as Test instead of Alpha as this is NOT a release made by Dhiru and since he hasn't released his CM 10.1 yet, I wanted to avoid confusion.
-Can be upgraded from CM10 (Read the notes below).
-This ROM is like CM 10 Alpha 5 so, of course, it is still experimental. I won't consider it a daily driver yet.
-Also, It is configured to use my own GetCM server (which is still not available yet), so you would be able to update from new releases directly from the system and it would tell you when a new update is available. Although I don't think it should work due to the reboot bug on Kernel 3.0.8.
Known bugs
-Almost everything that works in CM 10 Alpha 5 works here.
-Except Bluetooth, which is still not working due to the new bluetooth stack that comes with Android 4.2. I'm working on it.
-There were some issue with WiFi, which I have fixed, so it should work well now. In case you find any problem, report it here.
Upgrading instructions
Stock ROM
1. Flash CWM Compatible Kernel (CF ROOT)
2. Reboot to Recovery.
3. Wipe Data / Factory Reset.
4. Select the ROM zip from your SD Card and flash.
5. Go to Advanced -> Reboot Recovery.
6. Mounts and Storage -> Format dbdata
7. Flash Google Apps.
8. Reboot
Any other AOSP ROM (CM7/MIUI/CM9)
1. Reboot to Recovery.
8. Reboot
Upgrading from CM10
It is possible to update directly from CM 10 Alpha 5 or Alpha 4 without wiping data, if you upgrade from any pre-Alpha 4 CM10 based ROM, your data will be wiped due to new MTD partitioning system. Anyway, a wipe is always recommended although it is not necessary.
1. Shut down the phone.
2. As reboot doesn't work on the new kernel, take off the battery and reinsert it.
3. Boot from recovery (Vol+, Home, Power button).
5. Flash Android 4.2 Gapps.
6. Once it have finished, take the battery off the device again.
7. Boot the phone.
8. If you didn't wipe data, go to Settings-->Applications-->All-->Clock (not cLock, which is the lockscreen widget), and delete app data from that menu. This is needed due to Android 4.2 native improvements to the clock are incompatible with Cyanogenmod's improvements to the clock on CM10.
9. Enjoy CyanogenMod 10.1!
Sources
https://github.com/rodero95
https://github.com/teamhacksung
https://github.com/dhiru1602
https://github.com/adipat
https://github.com/sconosciuto
Thanks to
codeworkx
Dhiru1602
Teamhacksung
waleedq
Adi_Pat
LoSconosciuto (I couldn't have done this without his great patches. Thank you so much!)
LoLaTiOn (For helping me testing the ROM)
Please, note that I started this as an internal release for me just to learn and test things, I'm just releasing it for the people to test the goodness of CM-10.1 and see how it works on our device and due to the interest shown by all that people who have requested it. Thank you all for the interest!
Der Link zum Orginal Post: [TEST][ROM][4.2.2] Cyanogenmod 10.1 for Samsung Galaxy SL (Experimental) [28/02/2013] - xda-developers
@Update:
Ich habe einmal den Link zum Ordner eingebunden, wo alle ROM Versionen hochgeladen wurde.
Und ich hatte das ROM vor einer Woche auch schon noch einmal kurz angetestet. Und da ich ein Hitachi Display habe, das Probleme macht, lief soweit ganz gut. Das Deep Sleepproblem war da auch noch nicht gelöst wurden. Aber einige Sachen konnte man schon nutzten/einstellen.
  • Zum Beispiel konnte man die Lockscreen Widgets konnte ich ohne Probleme einrichten.
  • Das Handy ist auch nicht abgestürzt
  • Sehr flüssige Bewegungen, auch waren es gute Startzeiten der APP
Gesendet von meinem GT-I9003 mit Tapatalk 2
Reaktionen: frankie78 und Ricc346
Wie schauts denn aus mit der Rom, taugt sie schon was??
Bekomme mein Handy nicht zum Laugen mit der ROM und das andere was ich hier habe hat keinen internen Speicher mehr. Und ich bekomme es nicht umgeschrieben auf die SD karte :( mit sdk und adb shell kp warum
Das hört sich nicht gut an, vielleicht teste ich es mal am Sonntag, morgen hab ich keine Zeit dafür.
Ich hatte schon die Hoffnung das warum auch immer, da sich dein Display Problem erledigt hätte.
Mal schauen wann er Version 2 veröffentlicht, ist ja schon richtig fix der Junge.
Wundert mich schon das dhiru nicht die Version veröffentlicht hat, die auf seinem Facebook zu sehen war
hatte ich ja auch gedacht das das Display-Problem gelöst wurde. Aber es war bei mir mit der 4.2.2 schlimmer als mit der 4.1.2 und dem 3er Kernel.
Das andere 9003 was ich habe hat nen Sony-Display darum ärgert mich das das ich den Speicher nicht auf die SD umstellen kann ;( und das wurde auch hier schon beschrieben aber das bekomme ich nicht zum laufen damit
Das ist natürlich ärgerlich das das Display so viele Probleme macht, bei dir..
Was mußt denn alles bei dem anderen Gerät ändern über adb??
Ach schade, Ladylike ist hier nicht mehr Moderatorin. Sie hat beim letzten mal schnell reagiert wo ich sie ums verschieben gebeten hatte..
In den richtigen Bereich verschoben.
Reaktionen: frankie78 und Mario1974
wird es eigentlich mal ne richtige firmware geben die nicht abstürzt ist nur ne frage da ich etwas neues haben will :D
Welche Firmware soll denn abstürzen?
Cm9/10 hatte ich so gut wie nie Abstürze.
Reaktionen: Mario1974
ich meine also 4.2.2 das wird ja noch getestet und da wollte ich fragen ob es eine stabile bald gibt die für den altag taugt
Also da kann ich mich auch nicht beschweren. Läuft alles soweit recht stabil.
@patsem: ich denke das wird noch etwas dauern, aber wenn der Kernel 3.0.8 erst mal gefixt ist und soweit alle Fehler behoben sind wird die Version bestimmt recht stabil laufen.
habe mich irgendwie verlesen weis nicht warum eigentlich lese ich genau sry
wan wird den nach euren ehrfahrungen die finale version von 4.2.2 zum flashen rausgebracht?
Alles was auf Cm10A5 basiert ist derzeit nur ein Release um die Fehler im kernel3 zu erfassen und auszubügeln.
Und diese Cm10.1 ist eigentlich auch noch nicht für den täglichen Gebrauch da, da sie ja ebenfalls mit dem kernel3 bestückt ist.
Bei beiden kannst nicht erwarten das sie stabil funktionieren.
So wie Mario schon schrieb, Cm10A4 in Verbindung mit dem qwerty-kernel ist die beste Lösung
Reaktionen: Ricc346 und Mario1974
hm also kann ich nichts gescheites zur zeit runterladen damit ich 4.2.2 bekomme oder?
Wenn du jetzt meinst das nur das aktuellste Android das beste ist, dann muss ich dich enttäuschen, selbst auf Nexus Gerate gibt es probleme.
Was willst du denn?
In den 35 seiten im Cm10 thread findest genug links zu unterschiedliche Roms die auf cm10a4 basieren und insgesamt 4 kernel.
Schau die letzten 15 seiten mal an, da findest genug Material inkl. Android 4.2 apps die problemlos auf a4 flashen kannst
Nein kannst du nicht
Die beiden erwährten Roms
Mit dem 3kernel sind noch voll mit Fehler
Dass beste was du deinem Galaxy antun kannst ist wie bereits empfohlen 4.1.2 a4 mit dem querty kernel
finde gerade nicht den CM 10 thread könntest link posten?
I
  • iSchneiderle
2 3
simple-red
frankie78
  • frankie78
11 12 13
Ricc346
frankie78
frankie78
