[ROM] MiniCM-1.0.0-Beta1, Froyo Cyanogen 6.1 Port für das Mini [E10i]
Matthias87
nobodyAtall schrieb:
Visit Project's page @ google code
Sources @ github
MiniCM6
is the most stable and feature-complete ROM for the mini for day to day use
This ROM is for the X10mini only. It is custom-built based on Cyanogen 6.1 and code from Floyo-CM 1.2.0. This rom runs Froyo on top of stock SE kernel and is stripped off as many SE 2.1 stuff as possible.
Special thanks to my friend DaRk_dOg who is helping with testing this ROM. He is also theming for MiniCM. His creations are trully magnificent :D
To cookers: If you use parts or all of this ROM for your custom cooks, please reference this thread
To everyone: Please don't mirror this ROM
Notes:
Working:
  • Everything
Features:
  • App2sd / Dalvik2sd compatible with 2.1 (storing to ext2/3/4 pre-existing partition is detected and mounted as such)
  • Froyo native App2sd (storing to fat)
  • ClockworkMod recovery v. 3.2.0.0-r3 and option to reboot into Recovery
  • Undervolting and Overclocking handled CM Settings menu (by default none is active)
  • Extra CM Performance Settings menu for SD Read Cache Speed
  • Ultra brightness mode via CM Settings -> User Interface
  • Arabic support for Browser / Gmail
  • Mddi lag fix thanks to doixanh
  • CRT screen on / off animations ported from Gingerbread thanks to doixanh
  • Fake Dual touch thanks to doixanh and andrej456
  • Overclocking thanks to doixanh
Bugs: (Please use the project's tracker for reporting bugs.)
  • The notorious 'Reboot bug' is now fixed
Requirements:
  • Root and CWM recovery already installed (flash it from here)
  • Latest 2.1.1.A.0.6/2.1.1.C.0.0 SE firmware / Baseband: M76XX-TSNCJOLYM-53404015 due to kernel dependencies. Check this once and twice. There is no point to proceed if you don't have this.
Instructions:
  • Download the latest ROM from the release link
  • Rename the <release>.zip file to update.zip
  • Copy the update.zip to your sdcard (top level). E.g via your PC or via 'adb push update.zip /sdcard/'
  • Reboot to CWM recovery
  • Keep a backup of your current status using CWM's Backup & Restore in case you want to restore.
  • Select 'wipe data/factory reset' if you were not already using MiniCM6
  • Select 'apply update from sdcard' from the top menu of CWM recovery
  • Reboot (first boot will take ~2 mins)
If you don't stick to the above instructions you might get various problems (WiFi, Data traffic, Bluetooth etc).
In that case, and before reporting an issue, select 'Factory Reset' from the top menu of CWM recovery & Reboot
Downloads: Please do NOT mirror
MiniCM6-1.0.2.zip
If you would like to multiboot this ROM, use the attached MiniCM6-multiboot.zip. Don't flash this normally!!! Instead use the multiboot menu of the CWM recovery to flash it.
Do not report any issues regarding multiboot on this thread or on the issue tracker. Instead, use the designated thread.
Thanks to DaRk_dOg for making the multiboot zip for MiniCM6
Note that MiniCM6 updates are using Edify *only* and thus don't work with xRecovery, you need to flash CWM recovery from here.
Themes:
MiniCM6
Floyo
Stock
Other themes (might not work correctly, use them at your own risk!):
Dark Theme for MiniCM
Ginger-Wallx MiniCM
BeautyBlue MiniCM
Red Theme MiniCM
MarksTheme MiniCM
Purple Theme MiniCM
HTC Hero Mix MiniCM
Lucid Froyo MiniCM
GingerBread MiniCM
Extremely Blue MiniCM
Simplistic MiniCM
Donate:
If you are enjoying this ROM please consider donating: .
Donations are voluntary but allow me to spend more time on this device.​
Disclaimer:
I can't be held responsible if this ROM bricks your device or makes it explode in your hands! Use it at your own risk!
If any of the apps included in the ROM is copyright-protected, please let me know so I can remove it.
Changelog:
- 14/6/11 MiniCM6-multiboot.zip
- 13/6/11 MiniCM6-1.0.2 build
- 1/6/11 CWM Recovery
- 15/5/11 MiniCM6-1.0.1 build
- 24/4/11 MiniCM6-1.0.0 Released
- 14/4/11 MiniCM6 RC2 build
- 29/3/11 MiniCM6 RC1 build
- 14/3/11 MiniCM6 Beta2 build
- 5/3/11 Posted fix for T9 suggestions and Theme
- 5/3/11 MiniCM6 Beta1 build
- 26/2/11 MiniCM6 Alpha3 build
- 22/2/11 MiniCM6 Alpha2 build
- 21/2/11 Posted fix for data traffic
- 20/2/11 MiniCM6 Alpha1 build
Bemerkungen:
Fähigkeiten:
  • Alles was mit 2.1 mitgeliefert wurde
  • App2sd / Dalvik2sd kompatibel mit 2.1 (auslagern auf bereits vorhandene ext 2/3/4 Partitionen wird erkannt und gemounted)
  • App2sd von Froyo 2.2 (Fat - Partition)
  • xRecovery vorinstalliert
  • CyanogenMod Performance - Einstellungsmenü zum Übertakten des CPU und einstellen des Caches der SD-Karte
  • Vorgetäuschtes Dual - Touch (Danke an doixanh von xda)
Bugs:
  1. Es sollten keine Bugs mehr enthalten sein. ;-)
Vorraussetzungen:
  1. Aktuelle SE Firmware (Build Nr. 2.1.1.A.0.6) Baseband: M76XX-TSNCJOLYM-53404015 installiert
  2. Root
  3. xRecovery installiert
Installationsanweisung:
  1. Die neueste Rom aus dem xda - Beitrag herunterladen
  2. Archiv in update.zip umbenennen
  3. Archiv ins Root Verzeichnis der SD Karte kopieren (/sdcard/update.zip)
  4. Gerät neustarten und xRecovery starten
  5. Unter "Backup & Restore" / Backup auswählen um eine Sicherung zu erstellen
  6. Via "install update zip" die Rom installieren
  7. Nach der Installation im xRecovery - Hauptmenü "Factory Reset (full wipe)" auswählen (Nicht nötig, wenn eine vorherige MiniCM - Version schon installiert war)
  8. Danach "Reboot Phone" klicken (1. Neustart dauert ca. 2 Minuten)
  9. Spass haben :thumbsup:
QUELLE: [ROM] MiniCM6-1.0.2 [Update 13/6/11], Froyo 2.2.1 / CM 6.1.3 port for the mini - xda-developers
Reaktionen: anime, Cool Ivan, x-dealer und 3 andere
So langsam kommt mir das Forum hier wie ein xda-dev. Abklatschforum vor. Alles wird rauskopiert und nichtmal übersetzt.
Echte Neuigkeiten erwarte ich eh nicht (kann ja selbst nichts zu beitragen).
Reaktionen: ronny33
wofür soll jetzt der threat sein wenns den gleich schon gibt?
Das habe ich schon ein paar mal gesagt!
Irgendwo etwas tolles was ich grade finde zu kopieren und hier im Forum dann zu posten,kann ich auch.................
Und wer kein englisch kann,ist hier im Deutspachigen Android-hilfe forum wohl auch etwas aufgeschmissen.
Davon abgesehn gibt es für Custom Roms und Xrecovery schon ein paar Threads.
@ Pukidukie
Diese Beiträge / Themen aus dem XDA Developers Forum habe ich zitiert, damit auch die Leute was davon haben, die weder bei XDA angemeldet sind, noch besonders der englischen Sprache mächtig sind.
Anscheinend hast du meinen Post nicht durchgelesen sonst wäre Dir aufgefallen das ich die Installationsanweisung übersetzt habe.
Was sollte man deiner Meinung nach noch übersetzen? Ich hoffe mal das jeder was mit den Wörtern "Working" & "Bugs" anfangen kann, das sind zwei gängige Begriffe.
@ ronny33
Ich habe für dieses Projekt/Rom ein eigenes Thema gewählt, weil es in https://www.android-hilfe.de/forum/root-hacking-modding-fuer-xperia-x10-mini-mini-pro.160/froyo-port-nimmt-langsam-gestalt-an.77234.html
ursprünglich um das Mini Pro Projekt ging.
Das sind zwei unterschiedliche Projekte, für zwei verschiedene Geräte von zwei Autoren.
Warum sollten wir das im selben Thema behandeln? So hätte jeder, der ein Mini hat, diesen Thread und die Mini Pro Leute können im Konterpart dazu schreiben.
[Alpha]CyanogenMod7-v0.1 für Mini Pro [U20i] Gingerbread
Selbes Beispiel hier. Das ist keine Froyo sondern Gingerbread. Warum in ein Sammelthema stecken wo, dann später keiner mehr was dazu findet?
Bei unseren X10i - Nachbarn läuft's genauso. :thumbup:
Reaktionen: kurhaus_ und ilovemoney
Wie du meinst. Aber beeil dich
[BETA]Cyanogenmod 6[usbmounting][11.02.2011] (2.2.1)
ist raus! Schnell in den anderen Beitrag zitieren, sonst machts noch jemand anders.
Was soll der Quatsch? Er hat doch begründet warum er es hier reingestellt hat und ich finde es gut so. So kann man wenigstens mal auf deutsch darüber reden und muss es nicht auf englisch im XDA-Forum tun. Matthias danke für deinen Beitrag so passiert hier wenigstens mal was. Letzte zeit ist es hier ziemlich ruhig geworden. Und wem der Beitrag nicht passt muss hier nicht reinschauen und Kommentare dazu abgeben. Wenn das Thema keinen interessiert dann rutscht der Beitrag von ganz alleine nach unten!
ilovemoney
PS: Sorry für Offtopic, kann ruhig später gelöscht werden :)
Reaktionen: Cool Ivan, anime, kurhaus_ und 4 andere
Hmm, na dann reden wir halt jetzt einfach drüber (auf deutsch) ;)
Hat schon irgendwer eine dieser neuen Versionen probiert?
Ich werde mich hüten eine Alpha oder Beta auf mein mini raufzumachen, weil ich im Moment etwas im Stress bin und keine Zeit habe stundenlang das Handy wieder flott zu machen.
Aber hoffentlich kommt bald ne richtige Version vom CM raus.
Habs mal getestet. Bis auf die Bugs läufts super schnell und flüssig.
@ pukidukie
Wow, ich muss schon sagen, du bist ja ziemlich schlagfertig. Bessere Argumente sind dir, dann wohl auf die Schnelle nicht eingefallen. :rolleyes2:
Matthias87 schrieb:
@ pukidukie
Was soll ich mit dir diskutieren? Ich kann Englisch und verstehe dementsprechend was bei xda geschrieben wird. Mein Ziel war es nicht Dich in irgendeiner Form runter zu machen. Ich habe meine Meinung gesagt und das genügt mir. Nur sollte man evtl. auch mal die eigentlichen Verfasser der Posts fragen, ob sie es ok finden wenn man deren Beitrag Wort für Wort in andere Foren transportiert (falls du das nicht gemacht hast).
Dem kann ich nur zustimmen. Schade das Kopfhörer und die Kamera noch nicht gehen! Dann wäre es schon fast perfekt.
Das ist es was mich NOCH abhält... auf die Cam kann ich erstmal noch verzichten. Aber ohne mein Streaming Radio im Bus geht garnicht :glare:
Aber super das da so dran gearbeitet wird :thumbup:
Mfg
Dann hättest du mal auf deine Wortwahl achten sollen.
Keine Sorge, das geht schon okay.
Die Entwickler haben selbstverständlicherweise was dagegen, wenn man ihre Arbeit als die eigene ausgibt.
Wie man am Autorennamen und an der Quellenangabe sehen kann ist das hier nicht der Fall.
Jenes hat was mit dem Geist, der Grundidee der "Freien Software" zu tun.
Das ist bei mir ähnlich. Im Gegensatz zu Petflasche brauche ich zwar keine Kopfhörer, aber ohne Kamera geht leider garnicht. Wenn ich mal Zeit habe werde ichs mal aber trotzdem testen. Ich finds jedenfalls gut, das sich was tut *hach ich Poet*:lol:
Gruß Kai
Meine Wortwahl war mMn schon ok. Aber lassen wir das.
Weiß einer von euch wie wahrscheinlich es ist, dass bald eine ordentliche, voll lauffähige Version kommt? Ich kann leider den Arbeitsaufwand der verbleibenden Bugs überhaupt nicht einschätzen.
Das ist eine gute frage, die arbeiten ja schon eine weile daran. Soweit ich das mitbekommen habe ist die eigentliche Grundlage ja vom X8 und in der Version nur auf das X10 angepasst. Man sollte vielleicht die Entwicklung für das X8 beobachten und dann kann man damit rechnen wann es ungefähr für unser Mini kommen wird. Wenn ich mich nicht irre sollte es dieser Beitrag sein. Da du ja gut englisch verstehst könntest du es dir ja mal durchlesen und kurz sagen wie weit die da sind :)
[ROM] X8 | Sense | 2.1 | 2.2 | 2.3 | xRecovery [WiP] - xda-developers
Ok, ich habe mich gerade mal durch den von dir geposteten Link gearbeitet, bzw. habs überflogen. Folgendes finde ich für uns interessant (das wurde da gesagt und ich habe keine Ahnung obs wahr ist):
- das X8 hat fast die gleiche Hardware wie das Legend (ausser Kamera und LED) --- hoffentlich ist das fürs mini nicht negativ
- man muss um soundmixer, Kamera und LED beim X8 zu haben die Floyo Versionen vom Legend und Hero mixen, dies heißt viel Arbeit und noch mehr Rechenzeit (darum scheinen die bei xda gerade zu versuchen ihre Rechner zusammenzuschalten als "Rechennetzwerk".
IMHO ist die Schlagzahl von den Jungs doch schon beachtlich:
- Thread erstellt am 06.02 mit der ersten Beta
- heute Abend (5 Tage später) haben wir einen RC1 mit einer doch recht übersichtlichen Bug-Liste (Changing media volume, Headphone jack detection, LED Flash, Camera)
Ist doch ganz ordentlich. Ob und wann der Rest behoben wird, kann man nicht abschätzen. Es ist die Frage wie schwierig die Fehlerbehebung ist, vergiß nicht es sind Laien welche das nebenberuflich machen.
Gruß Kai
Leider sind die Bugs für mich schon recht erheblich.
Aber mit der Schlagfertigkeit muss ich dir Recht geben. Die sind im Moment sehr fleißig.
Und dass das alles Laien sind würde ich beinahe nicht nennen. Was die leisten ist beinahe professionel, ausser dass sie Geld für ihr tuen bekommen. Wenn man bedenkt wie lange die "Profis" von SE brauchen um auf ein 2.1 Update ihre dämliche Oberfläche draufzusetzen ;)
Z
zakorr
Z
Aaskereija
Aaskereija
Kryotech
Aaskereija
Aaskereija
