[Sammy-ROM] *09.06.12* [XWLPG] Pure ICS v7.5
Kjetal
Kjetal
Mitglied
10.214
In Anlehnung an diesen Thread [OFFURL]https://www.android-hilfe.de/custom-roms-fuer-samsung-galaxy-s2/205351-rom-fuer-alle-die-ics-pur-erleben-wollen.html[/OFFURL]
" Danke an Quelle für die Info, war nur leider sehr lieblos " :)
Ich habe die wichtigsten dinge grob ins Deutsche übersetzt.
download latest version :
Pure ICS Rom & Addons (special thanks to pawmadsen)
changelog version 7.3.1 :
- based on XWLP8 (actually i worked on xwlp9 but its not fast and smooth as xwlp8)
- No wipe method (so u can install it over 7.3 without loosing ur apps)
- syiah kernel 3.2.2
- new ics theme (v4.3) solved over 95% of issue also no balck on grey (thanks to vertumus for new ics theme)
- call recording mod (thanks to wanam & lidroid)
- themed mms app
- update apex launcher to 1.1.1 and modify it (solved messaging shortcut issue)
- percentage battery level
- update gapps to last version (street , google play ,...)
changelog version 7.3 :
- based on XWLP8
- full wipe method (no need to wipe your device , the rom will do that)
- CF-Root BULPC kernel
- new ics theme solved over 95% of issue also no balck on grey (thanks to vertumus for new ics theme)
- update apex launcher to 1.1beta2 and modify it (solved messaging shortcut issue)
- update gapps to last version (google play , google music ,...)
- change status bar icons (send-recive data on wifi visible)
changelog SE v2.0 :
- based on Lidroid ZSLPE
- Multilanguage
- XXLPS Modem
- Aosp contacts,phone,mms,calendar,browser,clock,email...
- Call recording mod
- ICS Lockscreen with home button lag fix
- update apex launcher to 1.1beta4 and modify it (solved messaging shortcut issue)
- Percentage battery+15 Statusbar toggles
[ROM][XWLP4] Pure ICS v7.2 [05-Apr-2012]
- Based on latest ics released rom
- fixing known issue of every release
- Pure ICS feeling
- Fully deoxed and zipaligned
- improved battery life
- optimized framework
- fast smooth and stable
- Rooted by proper tweaked kernel
- no sms in call log
- no sms to mms convert
- latest SU update
- latest google apps update
- seprate mods for more personalizing
- removed unnecessary samsung app
- ICS themed including icons crt dialler
- and many more not remember right now
Pure ICS v 7.2
aosp mms&contacts 7.2 (wipe cash and dalvik before install)
addons for 7.2 (creadite go for vertumus wanam sbulema and chatrat) read before installing addon
mirror
changelog version 7.2 :
- based on XWLP4
- update apex launcher to 1.03 and modify it
- full ics ringtone
- home buttone lag fix
Pures Android ICS RoM
[ROM][XXLPQ] Pure ICS v7.0 [16-Mar-2012] - xda-developers
Features : Funktionen
- Pure ICS UI
- Better battery life & smoothness
- Rooted and latest SU
- Apps and framework optimized
- Integrated with Google Addons
- Android ICS stock icons
- ICS keyboard
Added : ( Zugefügt )
- Last Google addons
- ICS Launcher
- Google Music 4.1.511
Removed : ( Entfernt )
- Touchwiz and depends apps
- Clock package days,dlna,sammy email,X-hubs,kies,kobo.maps,minidiary,music player,press reader,zinio,...
Download :
Spike.Pure.ICS-v6.0
MD5: 9E479CAFFFCCFCA5D055EA4848ED1A94
Installation Guide :
- Nand backup
- Full wipe your device (wipe data/factory reset - wipe cache - format system (in mount and storage) - wipe dalvik cache ( in advanced)
- Install rom via cwm recovery
Übersetzt :
- Backup erstellen
- Data / Factory Wipe - Cache Wipe - System Format - Dalvik Cache Wipe
- RoM via. Recovery Flashen.
Be Watchful :
- you must install last sammy ics rom first and then install this rom
- if you have issue like rebooting or many fc use new installation Guide
- if u have a battery draining first full your battery and goto recovery and select wipe battery stats , second use task manager and close runing programs every time you feel its needed
- and finally word that i must say , Do not expect me to do a miracle , sammy ics roms are in beta mod now and they have bugs ....
Übersetzt :
Es muss vorher ein ICS Stock RoM geflasht werden .
Sollte nach dem ersten Boot ein starker Akku verlust auftreten ins Recovery gehen und Batterie Stats wipen.
Bedenkt das alle ICS RoMs noch den Status " Beta " haben, daher kann es nach wie vor zu problemen kommen.
Addon :
Percentage battery+15 Statusbar toggles for version 5 ( special thanks to lidroid & Sboulema )
Changelog :
version 7.0 :
- based on XXLPQ
- ics ui improvement (thanks to vertumus for new ics theme)
- replace trebuchet with apex launcher (fast , more customizable , ...)
- remove crt animation (because of bug in it)
- ics lockscreen (thanks to vertumus)
- ics bootanimation
- change status bar icons (send-recive data on wifi)
- themed mms , tw calendar , tw calculator ...
Download :
Spike Pure ICS v7.0
MD5 : 3B5C9ECD37A4C476F503DE5CCC21E9BA
Mirror for version 7.0 :
Mediafire (thanks to AdaVS)
Rapidshare (thanks to malavan)
Torrent (thanks to marshall39)
version 6.1 :
- based on XXLPH
- back to no wipe method
- ics calendar & calculator
- crt animation
- ics bootanimation
- edit some png in mms
- new wallpaper and lockscreen wall
version 6 :
- based on XXLPH
- back t wipe method
- themed calendar & calculator & my file
- memo back
- update gapps
- change quick launch & status bar icons
- back to sammy music player
- remove bloatware (polaris office,kies ...)
- replace sammy keyboard with ics one
version 5 :
- based on XXLPB
- crt animation
- replace memo with gnote
- update gapps
- change quick launch icons
version 4 :
- based on xxlp6
- replace music player with google music
Credits :
Special thanks to :
google
sammy
dsixda for great kitchen
my forum ,saeid & naser for hosting rom
chainfire for kernel
bigbang hd & vertumus for theming
other i forget
Hier noch ein Video zum RoM .
Quick video of the rom (thanks to sleeves007)
Reaktionen: gonzo110288, Drielander, Phoenix-CGN und 8 andere
Und zu der FW hab ich eine Frage. Ist das eher so eine AOSP wie CM9 oder vergleich mit anderen Custom FWs, die auf Touchwiz FWs basieren?
Hab sie selbst noch nicht getestet, ich gehe aber anhand der Erläuterungen von AOSP like aus .
Edit : Um den Thread " sauber " zu halten werde ich die OT Beiträge nun entfernen , ist ja soweit geklärt :)
Es muss ja eine Sammy-ROM sein, da sie auf die LPH basiert und zum anderen deodexed ist... ;)
Hm, vielleicht teste ich die mal die Tage. Omega 3.0 läuft grad so schön. :)
Bin begeistert bis jetzt läuft alles gut bis auf Navigon und TV Spielfilm App....
Habe mir aber den Nova Launcher installiert weil ich finde der läuft flüssiger beim Seitenwechsel.... :)
hey leute
habe den rom installiert und bei geht das nicht ich sehen nur den warndreieck und galaxy s2 stehe weis nicht mehr weiter kann mir jemand mal helfen.
danke im voraus
MFG
@trafalgar,
ses schrieb:
Rechtschreibung:
Falsch geschriebene Wörter können von anderen Benutzern nicht über die Suchfunktion gefunden werden und führen ggf. zu Missverständnissen. Bemüht euch bitte um korrekte Rechtschreibung und Grammatik in unserem Forum. Wenn ihr euch Mühe bei der Formulierung eurer Beiträge gebt, werdet ihr auch entsprechend qualifizierte Antworten erhalten. Unser Forum ist kein Chat, die dort üblichen Kürzel sind hier deshalb unerwünscht. Bitte verzichtet auch auf die übermäßige Nutzung von Smilies, Ausrufe- und Fragezeichen. Rechtschreibfehler lassen sich z.B. durch Korrekturlesen oder die Nutzung einer Rechtschreibprüfung verhindern.
trafalgar schrieb:
hey leute
danke im voraus
MFG
hattest Du den bereits im Vorfeld ein ICS Rom auf deinen S2 am laufen? Wenn ich mich nicht irre ist das Pflicht.
Zitat:
Übersetzt :
Reaktionen: trafalgar und Kjetal
Deswegen habe ich es sogar extra noch Übersetzt :)
Ich habe den ICS XXLPH heruntergeladen und geflasht via Odin zählt das als Stock Rom oder nicht.
Hab mir das auf mein Device gemacht muss leider sagen bei mir funktioniert es üüberhaupt nicht ich bekomme egal was ich mache einen "freezze".
Liebe Grüße
es gibt übrigens nun eine Version 6.1!
Reaktionen: Kjetal
Dank dir, hab den Thread aktuallisiert :)
Hallo ich finde ROM echt Klasse, hab nur ein kleines Problem ich würde die fernwartung gerne nutzen leider funktioniert sie nicht mehr. Ich hab schon versucht die Samsung sync nach zu installieren leider ging es fehl.
Hi ich will dich wirklich nicht Ärgern nur ist es die gleich version die auch schon auf der ersten seite steht.
So wie ich es verstehe, ist es eine Samsung-Rom bei der Dinge wie Touchwiz entfernt wurden. Im Gegensatz zu AOSP dürfte man aber ohne weiteres die Samsungapps per Apk wieder hinzufügen können.
Aber die v7.0 mit der offizellen Samsung-Rom als Basis ist fertig, gibt nur Probleme beim Upload. Ich werde daher mit dem flashen noch warten.
Laut den Kommentaren auf Xda scheint die Rom wirklich gut zu laufen.
Warum muss man das eigentlich? Vorallem basiert doch diese Rom sogar auf der Originalen!?
Hab grad mal bei XDA rein geschaut, die 7.0 kann man jetzt wohl schon runter laden, auch Mirrors sind vorhanden.
Bin leider heute Nacht arbeiten, kann es also leider nicht ausprobieren.
Ich hab mir die 7.0 gerade installiert. Videoaufnahme und Wiedergabe funktionieren. Bin positiv überrascht von der ROM. Das einzige was mir nicht gefällt ist die Schrift im Auswahlmenü - schwarz auf dunkelgrau ist schlecht lesbar.
debaki
smooth 123
Chris1996
mecss
mecss
debaki
debaki
debaki
