Increase Head Phone Volume x10
Q
quercus
Gast
Ich habs im Sony Blog gefunden - und es klappt tatsächlich.
Allerdings scheint es abhängig von der Rom (Custom, usw) zu sein.
Versucht mal Euer Glück
QuellUrl: Xperia X10: Increase Head Phone Volume For X10
mfg Quercus :smile:
Here is a quick fix to increase the headphone volume on the X10, and this will work on other Android devices as well. So go to your market and install a application called "Louder Volume Hack", "hint google is your friend.
After installing it press on the speaker and you will get the following screen.
Note - Do not play anything and have headphones plugged in when doing this​
Now in order from top to bottom hit the circled buttons. After you press a button it will apply the mod to your phone and then on the bottom of your screen you will get a message saying "successfully applied to phone" or something. If you get a error message just try it again until you get the successfully applied message. Once you are done hit exit and you are done.​
I tried this method when I was on the bus to see if it works, and surprisingly it did. I noticed a significant increase in headphone volume. I am not sure about the head set volume thou.​
"kuhl" wäre noch die Quell-URL :) Damit man sich auch das mal anschauen kann.
MfG
UKSheep
Mikemr
  • laugfred
Benji96
Teknicker
