[KERNEL][12-03-2013] ~=~ EliteKernel OXP~=~ (adv. s2w, extreme powersaving)
blackline2008
blackline2008
Stammgast
164
EliteKernel OXP
Über den Kernel:
- slide2wake
- HTC Sense 4 +.
- schnellere Geschwindigkeit bei niedrigeren Frequenzen
- weniger Hitze bei starker Belastung
- Optimierung CPU, Memory, I/O und native Performance
- sehr stabil
- vieles mehr
Changelog:
130312 EX3
- smartmax back as default governor and fine tuned
- power saving frequencies bugfix
- LED duration multiplier at /sys/kernel/notification_leds/off_timer_multiplier (0=infinite, 1=default, number = multiplier)
130312 EX2
- defaults fall back to ondemand for now
- updated to latest Blade commits
130312 EX1
- rebased the kernel on Maxwen's AOSP Blade kernel
- added all former EliteKernel tweaks
- added Extreme Power Saving (improved HTC power saving - 1.15GHz cap and 3-core, no floor cap for audio when enabled)
- released as experimental branch until proven stable
130119
- attempt to smooth out audio crackling outside powersaving mode
- added NFS-related modules
130116
- added GPU overclocking
- added CIFS module as per a request
130106
- hardcoded default per-core frequencies so that tegra can't reset them (1400-1500-1600-1700 in order of activation)
- added rngd to completely eliminate system lags connected with cryptography, network communication and other stuff that rely on random number generation (thanks to lambgx02 for this idea)
130102
- s2w ignores swipes that originate in or go through the screen space (better gaming with virtual sticks)
- extreme powersaving update: power saving now limits the CPU to 3 cores while awake
121215
- fixed freezing bug
- s2w sysfs tunables interface by maxwen
Code:
/sys/android_touch/s2w_register_threshold - button panel locks to s2w after this distance
/sys/android_touch/s2w_min_distance - screen turns on/off after this distance
/sys/android_touch/s2w_allow_stroke - when set to one, direction of the swipes doesn't matter
- increased s2w_register_threshold for better button sensitivity
- rebased on ARHD6 boot.img
- fixed randomly broken init.d support
121212
- fixed sound cracking
- more battery when sleeping in power saving mode
- added my "stroke 2 wake" algorithm (basically free swipe alg. where direction doesn't matter)
- s2w length 25px shorter
- fixed some random startup and module injection bugs
121210
- S2W free swipe algorithm
- HTC Power Saving feature now underclocks to 1.15GHz and allows CPU to go all the way down to 51MHz when playing audio (this may cause crackling noises but saves battery while playing)
- fixed per-core async CPU settings. Be aware that SetCPU and similar progs will break this, they are not designed for tegra drivers. Nothing is -.-'
121209b
- revert to SLAB allocator for testing
- new experimental line for better battery while playing audio
121209
- reverted all the edits to tegra drivers to try a more subtle approach
- switched to SLUB memory allocator
- decreased default wifi power to save battery
- removed tegra drivers CPU hardcoding for: USB plugged in CPU speed, vibrations CPU ramp up, 2 cores only on USB
- decreased media playback perflock to 102MHz minimum
- modified S2W to ramp up the CPU momentarily on wake
121203
- Crippled another huge chunk of hardcoded Tegra CPU management
- more relaxed smartass to prevent lockups on lower quality chips
121202
- XZ kernel compression for smaller download and faster boot
- AES calculations are now hardware accelerated by Tegra chip
- memory compaction properly activates when needed
- improved I/O throughput and latency
- improved ondemand responsiveness
- improved file transfer speeds over USB for both MTP and ADB
- crippled part of Tegra hardcoded CPU management (USB connection, screen on/off)
- other minor performance and battery improvements
- smoother frequency ramping for ondemand
121201
- s2w overhaul by maxwen (fixed touchscreen in some games)
- changed s2w to only require roughly 60% of the swipe length for one-handed viability
- hopefully fixed kernel module injector to work always
- rebased boot.img on ARHD 5
121127:
- fixed installer package bug.. or not
121126:
- added slide2wake support
- changed default frequencies for better performance/battery(heat) ratio (1400-1600-1600-1400/204-51-51-102 since cores activate in order 0-3-2-1)
121125:
- initial release
XDA-Thread: [KERNEL][19-01-2013] ~=~ EliteKernel OXP~=~ (adv. s2w, extreme powersaving)
Reaktionen: Nocturne1984, crit69 und _DIORDNA_
Wie ist s2w? Irgendwelche Probleme? Läuft es mit dem aktuellen InsertCoin 2.1.0??
s2w ist slide2wake
sollte schon laufen mit allen Roms
läuft mit insert coin 2.1
Ruckeln Youtoube-Videos immer noch? Bei den XDA-Devs wurde davon mal gesprochen und ich hatte es bei den ersten zwei Versionen auch. Bin jetzt wieder auf Stock.
v121202 ist verfügbar.
Changelog:
121202
-> Download
PS: Habt ihr es für InsertCoin repackt? Oder einfach das boot.img aus der zip geflasht?
die neuste version ist bereits verlinkt.
du brauchst nichts repacken.
installiert wird es so wie oben angegeben
Hallo @ all
Geht das Boot.img auch mit dem Stock Rom (Vodafone Branding) ?
MfG Bubiwutha
musst du ausprobieren. es ist für das HTC One X+ International (enrc2b)
Wie kann ich das denn überprüfen ob der Kernel auch für mein One x+ geht ?
Im Hboot steht gleich oben enrc2b xxxxxxxxx drinne.
Gesendet von meinem HTC One X+ mit der Android-Hilfe.de App
dann wird er funktionieren
Wie sehen die praktischen Erfahrungen mit dem Kernel aus ?
Habe auch mit dem Stock Kernel wenig Probleme
- Spiele
etc.
er funktioniert, da er s2w hat, ist er schonmal effektiver als stock
Youtube-Videos laggen aber leider immer noch ein wenig. Stock funktioniert da tadellos. Habs gestern mal probiert.
also bei mir hängt nichts. glaube kaum, dass dies mit dem kernel zu tun hat.
Mit was sonst? Wechsle ja nur den Kernel und nicht die ganze Rom. Ist ja auch nicht immer. Im XDA-Thread dazu wird es sogar kurz erwähnt.
eventuell am HTC Browser?
der YouTube App?
dem ganzen HTC Gedöns?
es kommen viele Faktoren in Frage...
Sicherlich kann das alles in Frage kommen. Vorerst kann man die Apps aber ausschließen, da diese ja überhaupt nicht verändert wurden.
Hatte nach dem flashen kein Netz mehr
1.14.206.16
Wahrscheinlich weil es nicht die internationale Version war.
Flashe demnächst mal auf Maximus , wenn die V4 rauskommt und dann den Kernel.
Zurück auf Stock ist alles wieder verfügbar!
Hatte auch andere Versionen von dem Kernel probiert, immer kein Netz?
das wird irgendwo bei XDA schonmal erwähnt, ich glaube da gab es auch einen Lösungsansatz dafür
Nocturne1984
Nocturne1984
Nocturne1984
chris11
  • Gesperrt
  • Angepinnt
  • maxwen
Flo95
Flo95
