Overclocking Help
  • 20 Antworten
nizam1
Ok..
Im really starting to pull my hair out with this.I really hope someone on this forum can explain it to me.
Up until yesterday, I had the old EU 2.1 firmware, and I managed to get overclocking to load on boot no problem using the instructions provided in this thread.
https://www.android-hilfe.de/forum/...milestone-uebertakten-overclocking.27887.html
However. Once I flashed the Shols 2.36 UK firmware, I am not able to get overclocking on boot with either of those scripts.
The phone just hangs on the boot logo
I have the latest milestoneoverclok.apk installed.
Also I had app2sd installed both times.Before 2.36 and after 2.36
The GOT open recovery mod also doesn't help.
The phone just hangs on the Motorola boot logo whatever I try :(
Any help would be appreciated:)
Anzeige
  • Gerade eben
  • Neu
Just look into this thread: https://www.android-hilfe.de/forum/...to-vsels-mpu_opps-etc-overclocking.28049.html, exspecially to this part:
ES HÖRT NICHT AUF MIT DEN HINWEISEN: G.O.T. Open Recovery (25.06.10)
Falls Ihr zum overclocken die G.O.T. OR verwendet habt, !NICHT! die obigen Werte in die mot_boot mode eintragen!!! Bei GOT OR die Werte bitte in der folgenden Datei einfügen: /system/bin/boot_script/71_overclock.sh
Sonst läuft man Gefahr, eine Rebootschleife zu erzeugen. Zur Info: In GOT ist die 1.2er Version des overclock.ko schon verwendet. Update also nicht nötig.
You gotta change your frequencies in /system/bin/boot_script/71_overclock.sh if you are using G.O.T. Open Recovery. Don't change them in the old file mot_boot mode.
I hope, you understand, what i mean - otherwise wait for someone with better english skills. ;)
Thanks for your help..
But I only used GOT as a last resort.
Shouldn't I be able to manually enter it in mot_boot_mod manually using instructions given in the thread i referred to?
as Nudelholz already told you: you have to make changes here: /system/bin/boot_script/71_overclock.sh
NOT
in mot_boot_mode likeyou did in 2.34.....
The mot_boot_mode has to look like this.
Code:
#!/system/bin/sh
export PATH=/system/bin:$PATH
#run original script
mot_boot_mode.bin
insmod /data/data/pt.com.darksun.milestoneoverclock/files/overclock.ko omap2_clk_init_cpufreq_table_addr=0xc004e4b0
echo 68 > /proc/overclock/max_vsel
echo 800000 > /proc/overclock/max_rate
Reaktionen: nizam1
yes, without OC-Script from G.O.T-OR, you have to make it like scheichuwe wrote....the cpufreq_table_addr changed from 2.34 to 2.36...
Code:
#!/system/bin/sh
mot_boot_mode.bin
insmod /data/data/pt.com.darksun.milestoneoverclock/files/overclock.ko [B]omap2_clk_init_cpufreq_table_addr=0xc004e4b0[/B]
I think I found my mistake.Not sure though..What does that bit in bold do?
I didnt have to enter it the last time :confused:
I see eyebee answerd my question already. Let me give it a try and report back to you.
Thanks a lot for the replies guys
Still no luck :(
My mot_boot_mode now looks exactly like the one posted above with the exception of the app2sd script added
The phone at least started this time but the frequency remained at 550 Mhz.
I can't see what I'm doing wrong
Any other ideas ?
ok, try with OC-script in G.O.T.-OR, afterwards do your specific mods in /system/bin/boot_script/71_overclock.sh:
Code:
The thing is..
When i use the overclocking option on GOT -OR, my phone doesnt even boot.
Doesn't even get past the Motorola boot logo.
Have to perform a nandroid restore to get my phone back
So..theres no way I can access that script or folder.
read this:
KernelModule - milestone-overclock - How to use the kernel module - Project Hosting on Google Code
here is the part you must do:
Autodetect
You may also supply the addresses of the two needed in-memory kernel structures which may change with each firmware build and will probably have to be supplied either at load time with the freq_table_addr and mpu_opps_ptr_addr parameters or with their respective /proc entries. You can also ask the module to try to autodetect them if you give it the address of omap2_clk_init_cpufreq_table. The app does this automatically. You can easily find it manually with:
# grep omap2_clk_init_cpufreq_table /proc/kallsyms
c004e498 T omap2_clk_init_cpufreq_tableSo now you can load the module with:
insmod overclock.ko omap2_clk_init_cpufreq_table_addr=0xc004e498
Yeah..I read that.
Can't I type out that command in ADB ?
When I do that though it just says
grep : not found
What i did was-
adb shell
su
then the command
you must have busybox installed or may use the follow command:
/pathtobusybox/busybox grap omap2_clk_init_cpufreq_table /proc/kallsyms
I tried the above command without installing busybox
and it returned
/pathtobusybox/busybox not found
Then, booted into open recovery by GOT. Chose -install buybox in system/sbin option
Rebooted, tried the original command..
Still says
grep : not found
Im sure its something simple i'm missing
Getting damn frustrating :(
wenn you have install busybox to /system/sbin, just boot normaly...
then open the adb shell and use the original command...
you must use the command when you device is normaly running, not i recovery
That is exactly what I did.
Although,should I use this command ?
grep omap2_clk_init_cpufreq_table /proc/kallsyms c004e498 T omap2_clk_init_cpufreq_table
or this ?
this
when it says command not found use this:
/system/sbin/busybox grep omap2_clk_init_cpufreq_table /proc/kallsyms
Success !!! Finally !!
The last command given by Fufu worked.
Think busybox was the key !!
Thanks a lot Fufu and the rest..
Cheers!!
