[ROM] Android Open Kang Project - Tenderloin
Sk!llz
AOKP CustomROM mit Ice Cream Sandwich
features
-- there are many many more tweaks/adjustment throughout the whole ROM, take a look at the -change logs ​
-- built from AOSP -- using 4.0.3
-- power menu (source: source)
-- ICS style toggles
-- superuser & busybox built from source, included
-- deodexed & unsecure boot.img (for adb remount)
-- Facebook contact sync
-- ROM Control application lets you take control of your ROM. Customize it how you want it.
Navigation Bar options (choose color, button glow animation, etc)
IME Switcher toggle (show/hide notification when you type)
Customize your carrier label
Override lockscreen timeout (ie, use Android's timeout when turning the phone off, so it won't lock itself)
Statusbar toggle options
Lockscreen options including 8-way with custom targets
much much more in there
-- battery mods built in (including circle mod)
-- Check out all the options in ROM Control
change log available here: https://sites.google.com/site/androidopenkangproject/home
flashing instructions
1. MAKE A NANDROID
3. wipe data/factory reset in recovery and system -- THIS MUST BE DONE!
4. flash ROM
5. flash Gapps
6. reboot and select "Boot AOKP"
download: https://sites.google.com/site/androidopenkangproject/milestones
Find builds & milestones here
known bugs
OMX software decoding isn't working properly
Pending list to come in the AM, need to get some sleep
Join us on IRC for AOKP chat/support. #TeamKang @ freenode
obligatory
Countless hours were spent on this project. Posts, views, and donations encourage me, and everyone else who helps out.
Donate to ProTekk
Donate to Whitehawkx
Donate to Roman
Donate to Jonathan Grigg
Donate to Zaphod-Beeble
Every donation is cherished and loved. <3 XOXO <3
May the source be with you.
Check out the ROM source on github. Open source, in the spirit of community kangage.
Oh, probably moar sourceage here and here.
If you'd like to help with AOKP, please don't hesitate to contact me. I'd love to get as many developers in on this as possible!
Quelle: [ROM] Android Open Kang Project - Tenderloin - Milestone 3 - RootzWiki
Reaktionen: DirtyIdiot
Schon jemand getestet?würde mich mal interessieren wie es läuft und ein Vergleich z.B mit CM9.
ich tue mir immer schwer damit rein aus dem Text heraus zu erkennen was da die großen Unterschiede sind.
Finde den 8-way-Lockscreen klasse! Kann man den irgendwo seperat finden? Hätte den gern auf meinem Galaxy S mit CM9!
Hab auf meinem Nexus S auch ein AOKP-Rom, bin sehr zufrieden damit.
Hat jemand dieses hier bereits probiert, und kann was davon berichten?
Beim TP ist das der komplette CM9 Unterbau und nur die AOKP Änderungen wie den Unlockscreen reingefummelt. Wenn man Frische Roms und Support will sollte man bei CM9 bleiben.
Der "Dev" des Roms fürs TP hat eh einen sehr zweifelhaften Ruf, der war auch schon beim Touchdroid-Projekt dabei, die ausser Donations sammeln nichts zustande bekommen hatten.
EDIT: (Nur um das klar zu stellen: Ähnlich wie bei CM gibts hier für die Geräte verschiedene Betreuer. Auf anderen Geräten soll das AOKP ja gut sein.)
Hi, ich bin neu hier im Touchpad-Forum. Hab gestern ein gebrauchtes TP bekommen und gleich AOKP build 23 geflashed.
Allerdings habe ich jetzt das Problem, dass der Akku unter ICS nicht geladen werden kann. Es wird zwar die Ladeanimation angezeigt, der Akkustand verringert sich trotzdem immer weiter. Unter webOS funktioniert das Laden problemlos.
Ich möchte allerdings nun nicht immer zu webOS booten, nur weil der Akku geladen werden muss ;)..
Gibt es noch andere mit meinem Problem oder kennt jemand eine Lösung dafür?
EDIT: Man sollte erstmal bei rootzwiki gucken, bevor man hier postet ^^: Das Problem haben mehrere mit der 23, soll wohl bei Bug sein. Bei der 22 tritt es nicht auf..
jonono
GeoBroker
  • GeoBroker
Touchbenutzer
phreakkk
Muhtant
Muhtant
