Scum
Moderator
Teammitglied
- 6.431
[ROM][24 JUNE][Evolver 3D v1]|Themed|Beats|3.28.707.1|Sense 3.6 Android 4.0.3| - xda-developers
Evolver 3D v1
Goal of this rom is to provide a themed, customizable, stable and fast rom.Focus will be mainly on appareance and functionallity of the rom.
- Wifi hotspot only works without security enabled.
Install:
*Before flashing the rom make sure you read if you need to full wipe or not.If you install something new do a full wipe but if it is optional then it's optional! However if a full wipe is not mandatory you are still going to want to reboot into recovery and clean cache and clear dalvik cache before installing the new rom build.
*After you install the rom the first boot is going to take longer (sometimes it can take up to 10 minutes) This will also be the case after you clear cache and dalvik, likely not 10 minutes but it will take longer and all your apps will be updated.
*Give a newly installed rom time to settle and build caches and allow system files to find their places.
*After your device boots for the first time it is good to let it sit 5-10 minutes before touching it (let it settle). Once 5-10 minutes has passed pick it up and go through setup procedure. Be sure to set up only email and google accounts at this time.
*After setup is done click on market and accept terms this will allow your device to populate backed up app. Once all apps populate you should reboot your device, once rebooted go ahead and setup the rest of your accounts.
*At this point you can reboot recovery if you plan to add themes or mods. Install mods to your device one at a time and reboot after each install. This is also a good time to install a custom kernel.
*Last but not least you are all set up and can enjoy your new rom.
Customizations:
PLEASE NOTE: You MUST uninstall any updates that were installed from the market (Play Store) before flashing this zips with recovery.
Thx to Tkruzze and Sergio for creating the themed apps.
Original thread: http://forum.xda-developers.com/show....php?t=1684909
Clocks:
1. http://forum.xda-developers.com/show....php?t=1558736
2. http://forum.xda-developers.com/show...0&postcount=16
3. http://forum.xda-developers.com/show....php?t=1499517
Wallpapers:
http://s246.photobucket.com/albums/g...00/Wallpapers/ [/spolier]
Evolver 3D v1
Screenshots:
Specifications:
- Base: RUU 3.28.707.1 HTC Evo 3D GSM X515m (SHOOTER_U)Android Version: 4.0.3 HTC Sense: 3.6
- Kernel: Stock - 3.0.16-ge733189
- Recommended Radio: 11.77.3504.00U_11.25.3504.06_M
- Recommended Recovery: 4EXT Recovery
Features:
- Fast and smooth.
- Latest Htc kernel. (23 May)
- Fully themed.
- Deodexed, tweaked
- Rooted and busybox.
- V6 SuperCharger script implementation.
- Battery calibration script.
- aGPS patch.
- Tweaks.
- Full init.d Support.
- Sony Bravia Engine (HQ Image and Movie improvement. see 3th post)
- Sony xLoud Audio Enhancement Engine
- Camera Mod (thx to Coolexe) http://forum.xda-developers.com/show...&postcount=307
- Dim capacitive buttons script.
- Tv out animation. (not crtanimation, crt is not possible (yet?) for ics)
- Amazing batterylife !!
- Advanced power menu & extended quicksettings.
- Extended Beats. (Beats on musicplayer, streamingvideo and htc videoplayer).
- Advanced Beats Control. (Thx to Lyapota).
- Beats working over bluetooth.
- Musicplayer with Beats, Dolby Mobile, Srs and Equalizer options. (see screenshot 4)
Features:
- Fast and smooth.
- Fully themed.
- Deodexed, tweaked
- aGPS patch.
- Tweaks.
Downloads:
Romlinks:
Evolver 3D v1 - Dev-Host - Evolver 3D v1.zip - The Ultimate Free File Hosting / File Sharing Service
* After install choose blue sky skin (screen 1) or Paint the world skin (screen 2) to enjoy fully Sense skinned.
Older versions:
- Blue Ics v4 - Dev-Host - Blue Ics 3D v4.zip - The Ultimate Free File Hosting / File Sharing Service
- Blue Ics v3 - Dev-Host - Blue Ics 3D v3.0.zip - The Ultimate Free File Hosting / File Sharing Service
- Blue Ics v2.5 - Dev-Host - Blue Ice 3D v2.5.zip - The Ultimate Free File Hosting / File Sharing Service
- Blue Ics v2 - http://d-h.st/Njg"
- Blue Ics v1 - Dev-Host - Blue Ics 3D v1.zip - The Ultimate Free File Hosting / File Sharing Service
Romlinks:
Older versions:
Changelog:
- Evolver 3D v1 - New base (3.28.707.1), theme updated. latest cammod added (thx to Coolexe). (23 june)
- v4 - 3d cam fixed, Extended Beats fully implemented, Cam-mod v2 added. (14-June)
- v3 - New base, bassmod v11 added. (13 June)
- v2.5 - Sony Bravia Engine added. (1 June)
- v2 - Cameralibs and gpu drivers updated to latest. (31 May)
- v1 - Initial release (27 May)
Bugs: - Evolver 3D v1 - New base (3.28.707.1), theme updated. latest cammod added (thx to Coolexe). (23 june)
Install:
- If you are coming from another Sense 3.6 ROM, wiping data should not be necessary.
- The install formats system, cache, etc. so there is no need for super wipe scripts.
- If coming from a Sense 3.0 ROM (or other version), please backup your apps using Titanium Backup and perform a nandroid backup.
- While flashing the ROM, make sure you wipe data which can be performed during the install
- Download the ZIP file to your SD card
- Reboot into recovery and "Install ZIP from SD Card".
- Reboot
Helpful Tips and Suggestions:- The install formats system, cache, etc. so there is no need for super wipe scripts.
- Reboot
Customizations:
Themes:
Beats Theme:
Download: Dev-Host - Lozonian+Dic3ptor_Themes-Beats.zip - The Ultimate Free File Hosting / File Sharing Service
Flash with recovery, then choose paint the world skin.
Cornered Theme:
Download: Dev-Host - Lozonian+Dic3ptor_Themes (Cornered)RV1.zip - The Ultimate Free File Hosting / File Sharing Service
thx to Dic3ptor and Lozone.
Original thread: http://forum.xda-developers.com/show...5#post22577765
Themed apps:Beats Theme:
Cornered Theme:
- Titanium Backup 5.3.1 - http://forum.xda-developers.com/atta...1&d=1339542617
- Playstore 3.5.19 (market) - http://forum.xda-developers.com/atta...8&d=1338568916 (already included in rom)
- AdFree 0.8.44 - http://forum.xda-developers.com/atta...3&d=1338604625
- Google maps 6.8.1 - http://forum.xda-developers.com/atta...6&d=1339014373
- Appcachecleaner 1.1.3 - http://forum.xda-developers.com/atta...8&d=1338568660
- WifiCalling - http://forum.xda-developers.com/atta...5&d=1337118475
- Twitter 3.2.2 - http://forum.xda-developers.com/atta...7&d=1338568901
- Facebook 1.9.6 - http://forum.xda-developers.com/atta...0&d=1339863694
- Gmail 4.0.5 - http://forum.xda-developers.com/atta...1&d=1338569089
- Dropbox 2.1.5 - http://forum.xda-developers.com/atta...8&d=1339384615
- Adobe Reader 10.2.1 - http://forum.xda-developers.com/atta...1&d=1338781040
- GooglePlus 2.6.1.30454518 - http://forum.xda-developers.com/atta...7&d=1338568630
<----Big Blue Sense 4 Clock| Abstract Sense 4 Clock---->
New Clock:
Download: Dev-Host - Lozonian+Dic3ptor_Themes (Black Clock)RV1.zip - The Ultimate Free File Hosting / File Sharing Service
- Download Big blue Sense 3.6 clock: Dev-Host - Big Blue Sense 3.6 Clock.zip - The Ultimate Free File Hosting / File Sharing Service
- Download Abstract Sense 3.6 clock: Dev-Host - Abstract Sense 3.6 Clock.zip - The Ultimate Free File Hosting / File Sharing Service
New Clock:
Splashscreens:
Download: Dev-Host - PG86IMG.zip - The Ultimate Free File Hosting / File Sharing Service
Thx to xintel.
Thx to sahandv1989
Install; Copy to sdcard, reboot in bootloader. After install delete/rename the zipfile.
Original thread: http://forum.xda-developers.com/show...1502748&page=4
Links for more themes:Download: Dev-Host - PG86IMG.zip - The Ultimate Free File Hosting / File Sharing Service
Thx to xintel.
Thx to sahandv1989
Wallpapers:
